Sputtering
Discussion in '1st Gen Tundras (2000-2006)' started by Spread5150, Jul 1, 2025 at 8:49 AM.
  1. Jul 1, 2025 at 8:49 AM
    Spread5150
    Spread5150 [OP] New Member
    Dave
    2000 Tundra 4x4 SR5 V8 2019 Tundra TRD Pro 1994 Toyota Pickup 4x4
  2. Jul 1, 2025 at 9:12 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Sure sounds like it's in a tube. Ide double check those plugs first.
  3. Jul 1, 2025 at 9:38 AM
    Just pinpoint the origin of the noise. Sounds like an air pump, so look for things that do that. Doesn’t sound exhausty, sounds intake-y
  4. Jul 1, 2025 at 9:46 AM
    bfunke
    bfunke Tundra Curmudgeon
    My bet is loose vacuum hose. Zoom out and post some stills include the evap canister on the driver side
    Jack McCarthy and KNABORES like this.
  5. Jul 1, 2025 at 9:50 AM
    bfunke
    check where my finger is pointing. Note the new hose. Old one kept slipping off and made same sound.
  6. Jul 1, 2025 at 10:45 AM
    Sounds like your EVAP hose (vacuum) is loose. Do you have the EVAP canister next to the brake master cylinder, i.e. the black box to the right of Bryan's hand above? If so, that's where you need to be looking first, then tracing back toward what he's pointing at. It could be any of those S-shaped hoses on the canister, or anything up to that thing he's pointing at.
  7. Jul 1, 2025 at 10:54 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    I have a HUGE screen.... 20 seconds mark. you guys got it :thumbsup:
  8. Jul 1, 2025 at 11:07 AM
    bfunke
    Couldn’t see on my regular size phone
    shifty` likes this.
  9. Jul 1, 2025 at 12:56 PM
    Spread5150
    Dave
    Dang I’ll check it when I get back to the truck.
    The truck sat a month. The battery died. They just replaced it under warranty at Walmart. The kid must have knocked it off.
    Jack McCarthy and BroHon like this.
  10. Jul 2, 2025 at 1:28 PM
    Spread5150
    Dave
    Sure enough it was unplugged. Might be time to change out a few vacuume hoses.
    bfunke likes this.
