Rear window door weather channel seal strip exterior corrosion so soon? 2024 Hybrid Limited
Discussion in '3rd Gen Tundras (2022+)' started by ubybc, Jun 30, 2025 at 10:39 AM.
  1. Jun 30, 2025 at 10:39 AM
    ubybc
    ubybc [OP] New Member
    2024 Tundra Hybrid Limited
    2024 Tundra Hybrid Limited is showing some corrosion on the rear window door channel run. I am not sure if this part is the window panel run, window seal or weather stripping as the parts diagrams online diagrams are all over the place. This truck only has 16,000 miles on it and is not old, so any ideas why this corrosion is showing up? I tried rubbing it off with some different corrosion remover products, but they made minimal improvement. Appears as iff it's rapid oxidation of the finish or similar to rust. Any ideas? Thanks for any advice.
  2. Jun 30, 2025 at 10:48 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Trees, I see plenty in your reflection. If you frequently park under trees and don't specifically wipe those areas when you wash it, it'll build up. To me, it doesn't look like corrosion, but mold from trees.
  3. Jun 30, 2025 at 6:33 PM
    ubybc
    I'll look closer at this suggestion, although I do not park under trees regularly (very rarely) and this trim is the only area on the entire truck corroding like this. The rest of the trims and body are all in good condition.
  4. Jun 30, 2025 at 7:15 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I have a 2024 and mine has the exact same issue. My truck is outside most of the time but the closest tree is 40 feet away. I just bleached the crap out of it and used meguires ultimate black to restore it back to somewhat normal
  5. Jun 30, 2025 at 7:17 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    That’s interesting..if I were to guess (and I am) I would say it wasnt treated/sealed properly on build. Should be covered under warranty?
  6. Jul 1, 2025 at 9:06 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    If this in fact corrosion, it's covered. Return to dealer.
