Ball joint broke on the highway....help....
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Jun 22, 2025.
  1. Jun 27, 2025 at 1:54 PM
    #121
    Just as long as you didn’t buy Mevotech lower control arms as a replacement for OEM. I could go off on a two page rant on how bad they suck.
    bmf4069, PNW15 and w666 like this.
  2. Jun 27, 2025 at 2:11 PM
    #122
    Aerindel
    Aerindel [OP] New Member
    Montana
    I didn't buy anything front end wise on this truck but an inner tie-rod a few years ago and an upper ball joint. Probably MOOG, but I don't remember honestly. I guess I don't know if the control arms are OEM or not. Previous owners could have replaced them I guess.
  3. Jun 27, 2025 at 5:32 PM
    #123
    Aerindel
    Montana
    New parts in hand.
    Tertiary backup vehicle, a 96 subaru, died on me on the way to get them, I suspect fuel pump. Was able to get it restarted and limp out the rest of the trip.
  4. Jun 27, 2025 at 6:06 PM
    #124
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    You're having a bad week aren't you
    Best of luck to 'ya pal.
  5. Jun 27, 2025 at 9:31 PM
    #125
    Aerindel
    Montana
    Oh yeah, don't forget, I was on the way to town to get parts for my wife's primary car, 2005 subaru, with a wrecked engine....when my truck lost a leg.
    BroHon and Bought2Pull like this.
  6. Jun 28, 2025 at 6:28 PM
    #126
    You know what the best part about vehicles breaking on you?
    Chances are you won't be dealing with failures again.
  7. Jun 28, 2025 at 6:33 PM
    #127
    Aerindel
    Montana
    Truck......home......Didn't even drive wonky. Might be my imagination, but the alignment seemed better than it was before.
    Thanks everybody. I mean it. Even I might have been able to get through this without techical support, I needed the emotional support.
    I have to redo the brake line, and do the BJ's on the other side. And shop for tires. But at least it's home, where it can sit in peace while I work things out.
    My wife mentioned this to me today, and I think its true, I think I'm in the 'valley of despair' on the dunning kruger diagram. I know enough, to think I don't know anything.
  8. Jun 28, 2025 at 7:01 PM
    #128
    You know what the best part of being in the 'valley of despair' is?
    The only way from there ... is up.
    Holler if you need anything, you've got a lot of bretheren here, if you feel the inclination. And congrats on getting your truck home, I've met/known many a dude in my lifetime who would've simply said, "FUCK THIS SHIT!" and posted it on Craigslist "as-is". I've seen plenty of 1st gens with snapped LBJ posted on there and FB Marketplace and OfferUp since buying my 1GT. I'm often tempted to buy them, but I'd like to retire before I hit 55, and I'm running out of years :rofl:
    bmf4069 and Aerindel[QUOTED][OP] like this.
  9. Jun 30, 2025 at 4:47 PM
    #129
    Aerindel
    Montana
    Re-plumbed the brake line last night.
    Replaced the drivers side ball joints today.
    Discovered a slight play in the inner driverside tie rod.
    Who makes a good aftermarket tie rod end? OEM seems crazy expensive.
  10. Jun 30, 2025 at 4:49 PM
    #130
    I’m afraid to ask. What are they charging now? Last time I paid $50-55 for each.
  11. Jun 30, 2025 at 4:50 PM
    #131
    I went OEM last time. Paid $49 each
  12. Jun 30, 2025 at 5:24 PM
    #132
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    For the inner tie rods? I paid about that for the outers, but inners are almost $200 each Of course, there's 20% off right now at Serra and others.
    Aerindel[OP] and FirstGenVol like this.
  13. Jun 30, 2025 at 6:17 PM
    #133
    He said inner tie rod. Those are crazy expensive. I went with Moog. They work but make a lot of unsettling noises.
    Outer tie rods are not that expensive. Even cheaper if you order this week.
    Aerindel[OP] likes this.
  14. Jun 30, 2025 at 6:27 PM
    #134
    Let's be real: Inners are expensive enough that it's smarter to just buy a new OEM rack, which comes with new inners, than it is to buy the inners alone. Not dissimilar from how it's smarter to buy new OEM LCAs than it is to buy OEM LCA bushings, the bushings themselves cost damn near half as much as the assembled arms.
  15. Jun 30, 2025 at 6:27 PM
    #135
    A tie rod end is the outer tie rod, not the inner. May be just a typo I guess though especially if the price hasn’t changed much.
  16. Jun 30, 2025 at 6:33 PM
    #136
    My inners are Moog. Seem fine.
  17. Jun 30, 2025 at 6:41 PM
    #137
    This is why I prefer acronyms of ITR/OTR. You'll see me use "TRE" for the OTR quite often.
  18. Jun 30, 2025 at 8:37 PM
    #138
    Aerindel
    Montana
    My outers are fine. Yeah, inner whatever you want to call them are $180 each OEM. If I was going to buy OEM,s I see why getting whole rack would make sense as its only twice the price of a pair of inners.
    But is also almost 1/3rd what I paid for the truck....as far as I can tell mine is fine so just getting ends.
    But anyway, this is all because I have to buy new tires, as the one that came off is damaged. Still driveable, but it has a chunk ripped out down to the cords in one spot, and a flat spot on the corner/sidewall on the other. Makes a wawawa at low speed and sings at high speed now. Need to get everything in order though for new tires and an alignment at the same time.
    shifty` likes this.
  19. Jun 30, 2025 at 9:27 PM
    #139
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    You deserve a few days off with nothing to do but relax. Glad you're home
  20. Jun 30, 2025 at 11:20 PM
    #140
    Aerindel
    Montana
    I do. Not getting it.
    Starting today things get crazy busy at work....I might not sleep until the 7th.
    shifty` likes this.
  21. Jul 2, 2025 at 4:04 PM
    #141
    Fragman
    Fragman New Member
    Fireworks and alcohol........
  22. Jul 2, 2025 at 4:27 PM
    #142
    Moog for inners. I’ve had mine for years; no issues.
    G_unit3000 likes this.
