Secondary Injection system - CEL - help
Discussion in '2nd Gen Tundras (2007-2013)' started by BreckTundra, Jun 26, 2025.
  1. Jun 26, 2025 at 10:37 AM
    BreckTundra
    BreckTundra [OP] New Member
    2010 Toyota Tundra TRD Off Road 4.6L
    Remote start
    HI All. New to this forum for posting, but I have used the threads for help with things in the past. Thanks
    I have been having this issue for over a1 year. Basically I got the CEL and ran the codes. I got P2442 (Secondary Air injection system switching valve stuck open bank 2) and P0418 (Secondary air injection system Control A circuit) It throws up the CEL which was fine for a while, but then if I did not clear the codes, it would put into limp mode. I now have to stop if happens while driving or before and clear the codes, so it comes out of limp mode. I did the research o this and I know replacing the system from dealer cost like $3K or that is what I was quoted. Since it is a 2010 and 160K miles, it is no longer under the warranty or recall. Apparently there was a recall, but it was past the mileage already so they won't honor it. I need some advise because this has become really annoying. Once codes clear, it's fine. I am ok with CEL on, but limp mode is an issue, unless constant CEL on is an issue. I would not be able to replace the pump myself if I bought. Would a non-dealer shop be worth looking into? I had one tell me they wouldn't do it. Is it worth investing in the Bypass kit from Hewitt Tech? https://hewitt-tech.com/product/sec...apAk0L726PF4PU7Oiu2v81CmYvEGUZLX0UAJOeWuRPAny advice is appreciated.
    Any advice is really appreciated. Thanks! Steve
  2. Jun 26, 2025 at 10:48 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    That’s your answer ^^^ get the bypass and be done. You’ll have to install the blocking plates since you’re valve is stuck open
    I’ve had the bypass on my 07 going on five years now no issues even with MA inspections
    Mdl likes this.
  3. Jun 26, 2025 at 10:58 AM
    BreckTundra
    Remote start
    Mike, thanks. That's what I figured, but good to hear from someone that has done it. It looks like I would definitely need the Gen 2: Bypass Kit, which is fine, $450 is better than a few thousand, lol. Did you install yourself? I'm mechanically handy enough that I believe I could do it, but was pretty easy or straightforward to install?? Thanks
    Leo's first likes this.
  4. Jun 26, 2025 at 3:25 PM
    Leo's first
    Groton ma
    I have a relative that owns a shop so I had them install the blocking plates for me
    Search here for the Hewitt bypass you should find some diy for the blocking plates
    They can be a pia but doable
    BreckTundra[OP] likes this.
  5. Jun 30, 2025 at 3:26 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    hewitt 2nd gen kit. $450 i think? easy peasy.
