Starting in high gear
Discussion in '3rd Gen Tundras (2022+)' started by Luna, Jun 29, 2025.
  1. Jun 29, 2025 at 3:22 PM
    Luna
    Luna [OP] New Member
    Is it normal for the new tundra to feel like it's starting in high gear? It reminds me of when I had a manual transmission and would try to start off in 2nd gear. High RPM's no power. It does this when I don't come to a complete stop, slow right hand turns for example. A good example is when I turn right into my driveway, my driveway is uphill and the truck seems to struggle climbing unless I manually downshift to first. Is this normal?
  2. Jun 29, 2025 at 3:49 PM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    Definitely not.
    Luna[OP] likes this.
  3. Jun 29, 2025 at 4:22 PM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Yes, perfectly normal. Truck starts off in fourth gear. Has to do with the torque. Sport or Tow+ will help.
  4. Jun 29, 2025 at 5:41 PM
    DRP
    DRP Old Member
    Dave
    From a stop, mine always starts in first gear. Rolling stops it might start in third. Have Never seen it start off in fourth. Mode doesn't matter.
  5. Jun 29, 2025 at 5:43 PM
    Retroboy1989
    Northern Utah
    I thought it was third gear....That's what I was seeing on the car scanner app.
    Anyway, you don't get a full downshift to 1st until 2 or 3 mph or slower, from my observation.
    It's annoying, for sure. Not sure why Toyota did that. The worst is when you hit the gas right as it downshifts and it hesitates for a split second.
    DRP likes this.
  6. Jun 29, 2025 at 7:40 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    Unfortunately this is how they have it programmed. It won’t shift into first unless you go 3 mph or less. I wish Toyota would change this. It is a heavy rig and should drop into first sooner to help get the mass moving at slow speeds. Poor engineering from a drivability point of view.
  7. Jun 29, 2025 at 7:50 PM
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    Starting in high gear would mean low rpm’s not high rpm’s. But yes at lower speeds it’s normal for it to down shift to lower gears when it needs power and show higher rpm’s. At higher speeds it seems to use turbos more unless you really goose it.
  8. Jun 29, 2025 at 8:00 PM
    PERRY1060
    Perry
    Indiana
    What he was referring to is the trans stays in 2 or third gear at very low speeds instead of dropping into 1st. When you try to increase speed again or climb a grade the torque converter has to slip a lot to get truck moving again. So you hear engine reving as torque converter slips to keep engine from stalling.
  9. Jun 29, 2025 at 9:14 PM
    Retroboy1989
    Northern Utah
    The engine revs up as the TC slips trying to get the truck moving in 3rd. It takes more revs to get it going in 3rd than in 1st.
  10. Jun 29, 2025 at 11:18 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Agreeing with what pretty much everyone here has said. The only times I’ve experienced the “throttle lag” is when I’m slowing to a stop but then get going again before getting under 3-5mph. From a dead stop, scan gauge has always shown being in 1st gear. If I’m slowing down, it stays in 3rd until you’re basically stopped. As Perry and retro said, the torque converter slips until you’re at an appropriate speed to lockup for a moment and then shift into 4th. It’s annoying for sure, but it doesn’t happen often enough for me to care about it too much. At least the yota 10 speed only skips gears (mostly 2nd gear from my experience) on downshifts and not upshifts too like fords’ 10 speed.
    CringyDad likes this.
  11. Jun 30, 2025 at 12:40 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I don’t know anything about any of this.
    When would you notice this? Doing a rolling ‘stop’? I’ve never noticed an issue with mine? Is this a problem? Or does it work as intended, but you just don’t like it?
    Soupbean77 likes this.
  12. Jun 30, 2025 at 2:24 AM
    Luna
    Thanks everyone. Seems odd Toyota would engineer it that way, I guess I'll manually drop it to first when I pull into my driveway.
  13. Jun 30, 2025 at 2:50 AM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    If you have to manually shift your automatic transmission into first gear to pull into your driveway, you should go straight to the dealer.
  14. Jun 30, 2025 at 6:43 AM
    Retroboy1989
    Northern Utah
    Or slow down to 3 mph as you enter your driveway so it will drop to 1st.
  15. Jun 30, 2025 at 6:48 AM
    Retroboy1989
    Northern Utah
    It's noticeable when you slow down to 4-8mph then try to accelerate again. It's drivable, just annoying that's it's overgeared for a few seconds. I also think it's a waste of fuel. It probably wastes more fuel being overgeared than it saves with the autostop.
    chrisgibbs707 likes this.
  16. Jun 30, 2025 at 10:40 AM
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
    Rolling stops going uphill are usually where I notice it. When you’re going downhill and do a rolling stop it’s actually nice to have. Even on flat ground, it’s fine. The only time I notice it is when I’m getting on the freeway (inclined on-ramp) and the meter is on so I’m carrying a tiny amount of speed into taking off. If you stomp on the gas really quickly and let off a bit, it will downshift to second, so it’s not a big deal.
