Rear window door weather seal frame exterior corrosion so soon? 2024 Hybrid Limited
Discussion in '3rd Gen Tundras (2022+)' started by ubybc, Jun 30, 2025.
  1. Jun 30, 2025 at 10:39 AM
    ubybc
    ubybc [OP] New Member
    2024 Tundra Hybrid Limited
    2024 Tundra Hybrid Limited is showing some corrosion on the rear window door channel run. I am not sure if this part is the window panel run, window seal or weather stripping as the parts diagrams online diagrams are all over the place. This truck only has 16,000 miles on it and is not old, so any ideas why this corrosion is showing up? I tried rubbing it off with some different corrosion remover products, but they made minimal improvement. Appears as iff it's rapid oxidation of the finish or similar to rust. Any ideas? Thanks for any advice.
  2. Jun 30, 2025 at 10:48 AM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Trees, I see plenty in your reflection. If you frequently park under trees and don't specifically wipe those areas when you wash it, it'll build up. To me, it doesn't look like corrosion, but mold from trees.
  3. Jun 30, 2025 at 6:33 PM
    ubybc
    I'll look closer at this suggestion, although I do not park under trees regularly (very rarely) and this trim is the only area on the entire truck corroding like this. The rest of the trims and body are all in good condition.
  4. Jun 30, 2025 at 7:15 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I have a 2024 and mine has the exact same issue. My truck is outside most of the time but the closest tree is 40 feet away. I just bleached the crap out of it and used meguires ultimate black to restore it back to somewhat normal
  5. Jun 30, 2025 at 7:17 PM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    That’s interesting..if I were to guess (and I am) I would say it wasnt treated/sealed properly on build. Should be covered under warranty?
    kamaaina1 and Tundrastruck91 like this.
  6. Jul 1, 2025 at 9:06 AM
    Adam B
    Adam B New Member
    2022 Tundra TRD OFF-RD LIMITED- Green & 2024 Tundra TRD OFF-RD LIMITED- Silver
    If this in fact corrosion, it's covered. Return to dealer.
    Tundrastruck91 likes this.
  7. Jul 16, 2025 at 10:42 AM
    ubybc
    I cleaned and inspected best I could, and the black finish is certainly wearing down allowing the oxidation. I'm not sure what what is causing it. I feel confident it could be taped off, sanded and recoated/painted carefully, but it would be one of those tedious, take your time, PITA jobs. I should be coming up soon on the dealership schedule for the squeaking front breaks TSB and will ask the dealer when I go in for that.
  8. Jul 28, 2025 at 12:37 PM
    ubybc
    Finished up the brake squeal TSB at the dealership and I asked them to look at the window frame corrosion. Seems this is not overly common but does occur on other third gen tundras. We looked at some others on the lot doing the same thing. So no answer as to a possible warranty fix yet, or possibility of a TSB. They said its still functioning, and replacing the part would be quite significant. Best bet is to contact Toyota corporate and start there with a request for a resolution. I'm going to write Toyota, and hope others do as well.
  9. Aug 3, 2025 at 12:01 PM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    Dealership will warranty this, it's covered.
  10. Aug 15, 2025 at 6:18 PM
    ubybc
    Heard back from Toyota and they said this trim piece is corroding faster than it should, as with other same age trucks in my location. It is still within spec, so no warranty. They more or less said the UV sunlight is damaging the finish, and replacing the piece would be such a significant repair for a cosmetic issue it is not a valid warranty item. I understand, since the same thing happened on my previous Tacoma. The direct sun in the south can eat away at a finish not manufactured to withstand the extreme heat and sun harshness. They did admit I had a valid concern and it should help towards solving this problem going forward. I hope so and hope it helps to make these vehicles more heat tolerant for hot climates in the future.
  11. Aug 15, 2025 at 7:14 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    What could this black deposit be in this area? If this is just resting on top of the paint this could be what is eating away at the painted trim surface. I checked mine and and this frame is definitely made of steel (magnetic) so most likely just painted with black trim paint.
    I would go back to your dealer and ask them what they mean by "still within spec"? Still within spec to what? Did they put a paint thickness gauge to it and take a some readings? Ask them to provide some details, looks to me they are just brushing you off. The truck is made in Texas, damn hot there and you would think it would last a bit longer than just one year?!
  12. Aug 16, 2025 at 5:20 AM
    hudrock
    So Cal
    25 MGM Limited
    That is such a BS response from Toyota....sorry to hear that.
  13. Aug 16, 2025 at 5:36 AM
    Double DC
    Double DC New Member
    2005 DC & 2021 DC
    No kidding. At this point, Toyota should have plenty of experience with different materials, paints, sun exposure, tree piss, etc. Anything new should undergo plenty of testing prior to release. They shouldn't need OP's help to solve the problem going forward. Hope they make this right eventually.
  14. Aug 16, 2025 at 5:43 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I had some under carriage bolts that were rusting from the get go. Visible from the rear wheel wells. Never had that on a vehicle before. Looks like the factory ran low and got some untreated bolts at Home Depot. Dealer blew off. So If am periodically wire brushing rust and painting it just as I do with my stick smoker.
    I don't think I buy another Toyota because of the service of the only dealer near me. The local GM and Ram dealers for trucks I have had since I lived here and was better.
  15. Aug 17, 2025 at 8:00 PM
    ubybc
    It's just dirt, I cleaned it better and took new photos. It was a bit darker and later in the day. The other shots were in brighter sunlight.
