End the debate
Discussion in 'Suspension' started by Samoan Thor, Oct 27, 2017.
  1. Oct 27, 2017 at 11:30 AM
    Samoan Thor
    Samoan Thor [OP] God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Did the delta joint de-throne total chaos as the best UCA? Give your thoughts and reviews, thanks
  2. Oct 27, 2017 at 11:34 AM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I’m no expert on suspension, but it seems like an apples to oranges type of comparison.
  3. Oct 27, 2017 at 11:38 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    All you did was post pictures. Care to explain how the "delta joint" is better than a fk uniball?
    If you are just looking for opinions, then get total chaos.
    trayday, TheBeast and Samoan Thor[OP] like this.
  4. Oct 27, 2017 at 11:43 AM
    Samoan Thor
    Thanks, just wanted to see some reviews and opinions
    Yes I posted pics, it’s part of the post, I have no idea which one is better that’s why I asked.
  5. Oct 27, 2017 at 11:53 AM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Depends on the application. I would run ball joints, I live in CA and don't see winter salted roads.
    GNTundra likes this.
  6. Oct 27, 2017 at 12:20 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Ill add this...I prefer Camburg :)
    Baja Mike likes this.
  7. Oct 27, 2017 at 12:20 PM
    TheBeast
    TheBeast The Beach
    I have the TC and I like them :notsure::notsure:
  8. Oct 27, 2017 at 12:21 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Plus, from what I believe, Icon will be releasing the Delta Joint for TC/Camburg and possibly other mfg uppers.
    trayday and TheBeast like this.
  9. Oct 27, 2017 at 12:21 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    TC all the way
    theboy12 and TheBeast like this.
  10. Oct 27, 2017 at 12:22 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Or SPC has a their sealed greasable option, albeit that the delta is suppose to have better articulation. -Jon
  11. Oct 27, 2017 at 12:25 PM
    spudd74
    spudd74 New Member
    Judd
    N.W. Pa
    2016 CM Inferno
    I wonder if the Delta Joint would fit in the Total Chaos arms?:notsure:
  12. Oct 27, 2017 at 12:36 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Not yet
  13. Oct 27, 2017 at 12:37 PM
    TheBeast
    TheBeast The Beach
    but they will...14burrito is our ICON insider :spy::spy:
  14. Oct 27, 2017 at 1:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Let me rephrase, as I said it correctly the 1st time. Maybe**
  15. Oct 27, 2017 at 1:07 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS, ADS front and rear, Total Chaos UCA's, CB tie rods
    Depending on the materials used. TC from what i remember uses chromoly tubing and is stronger than the other contenders for UCA's. The uniballs all use the same diameter shaft which would most likely be the first part to break, not the uniball. I'm happy with my TC UCA's; no grease, just spray! I also ditched the poly bushings and replaced with uniball pivots.
  16. Oct 27, 2017 at 1:16 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I just installed the Icon Delta joint. I like the idea of articulation without frequent maintenance. Also, sand from Pismo won't be an issue. TC, and Camburg make great stuff too. I think TC uses a 1" uniball and Camburg uses 1.5".
    joonbug likes this.
  17. Oct 27, 2017 at 1:19 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    The Delta Joint was designed for the climates that the uniballs have not been able to stand up in. I.E snow, road salts, high moisture, etc. The Delta Joint in simple terms is a "sealed uniball" that is greased instead of using a teflon liner. ICON is estimating these to have life spans of at least 100K. The benefit of the Delta Joint is that you don't get the noises that are accompanied with a dried out or worn out uniball.
    When comparing the uniball straight across to a Delta Joint, the Delta joint does have quite a few advantages.
    1. No noise with the Delta Joints
    2. The Delta Joint has a stronger pull out strength compared to the uniball.
    3. The Delta Joint is a one piece design, so no more misalignment spacers or broken spindle adapter spacers.
    4. Comes with a 5 year/100k warranty when used with Icon suspension kits
    5. Delta Joint gives you the same high misalignment angles of a uniball.
    Only con would be cost of the delta joint vs a replacement uniball. But how many sets of uniballs will you go through in 100K miles? I would say ICON has the upper hand in this battle. They are in testing phase with the WSSX16T delta joint size which would be for the Total Chaos products and some Camburg. Mid to late next year they will have the larger Delta joints that replace the 1.5" uniballs. I like to think of myself as the Icon insider. :p
    End of the day, an arm is an arm. They all pretty much do the same thing. The difference are so minut that 99.9% of people can't tell. Its just people knit picking small specs.
    CM-LENNY, blizz86, jc153 and 7 others like this.
  18. Oct 27, 2017 at 1:22 PM
    sdhq_offroad
    GILBERT, AZ
    Both Camburg and TC use 4130. Icon uses DOM. But with that being said, I've never seen either bend or break under non-race circumstances that wasn't in a wreck, etc.
    T-Rex266, zcarpenter92, Newm and 3 others like this.
  19. Oct 27, 2017 at 2:36 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well that made me feel good about buying the Delta Joint. Even better 'cause I got 'em from SDHQ.
  20. Oct 27, 2017 at 5:38 PM
    spudd74
    spudd74 New Member
    Judd
    N.W. Pa
    2016 CM Inferno
    So you’re saying there’s a chance?!?!?!?!
  21. Oct 27, 2017 at 5:52 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    What are the official articulation angles on a 1" uniball and the Delta Joint?
  22. Oct 27, 2017 at 7:41 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    4x4_Angel likes this.
  23. Oct 27, 2017 at 7:51 PM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I'm looking for UCAs for an 8-10" lift.. any ideas guys???
  24. Oct 28, 2017 at 8:15 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    Total Chaos with heim joints or Icon Billets should work. My TC w/o heim joints didn't work on my 7" lift, I had the ends hacked off and replacted with adjustable heim joints.
  25. Oct 28, 2017 at 12:01 PM
    Judd1980
    Judd1980 New Member
    Judd
    2014 Tundra Platinum
    I've been debating on the Chaos' for awhile now as I'm sure it would only add to my KING lift, but I have been cheap. Since I recently moved back to PA, the Icon's seem like a good choice since snow/road salt will be a yearly thing. Especially since PA loves to salt up the Turnpike :)
  26. Oct 28, 2017 at 12:09 PM
    SullyMoto19
    Tyler
    Houston, Texas
    Definitely something I'm looking into.. it's all stock right now cause I have an 8" ready lift, so I was able to keep all stock coils and UCAs.. but I'm waiting to get coils so gonna go ahead and replace UCAs as well
  27. Oct 30, 2017 at 2:29 PM
    Samoan Thor
    Yea Im in CA as well out in the desert and the benefits of both a balljoint and uniball make the delta joint look better for people that move a lot(military)
    yea their uniballs as well as regular balls look good too
    most likely going with TC
    I hope they do, it would increase the survivability of the TC UCA in other weather conditions I think
    yup, will be going that route
    yea I considered them too but probably getting the TC
    hmmmm fill us in with more info when you get it
    k, let us know pretty please
    good to know breh, I knew TC has the best materials, thanks for confirming my decision
    yea i love speeding in the desert and my kings need a good uca to make them travel more, i think im set on TC
    Thanks for your expertise good sir, TC will most likely be my choice, might order them from yall and get them cool stickers
    yup, thanks very much
    thanks for the reply, might make a road trip to AZ check out their shop
    good question, im thinking the uniball would still offer more articulation but dont quote me on that
  28. Oct 30, 2017 at 2:30 PM
    Samoan Thor
    Ladies and Gentlemen, ahem.....thank you for the replies and the knowledge that has been dispersed. My decision will be to purchase the total chaos fabrication upper control arms, yall are awesome and I give you all free air hugs
    CM-LENNY, TheBeast and 4x4_Angel like this.
  29. Oct 30, 2017 at 8:23 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
