Regular Cab Standard Bed Camper Shell Sizing... RCSB vs DCSB?
Discussion in 'Tonneau Covers, Caps and Shells' started by upcountry, Oct 5, 2020.
  1. Oct 5, 2020 at 3:21 PM
    upcountry
    upcountry [OP] New Member
    Hi there, I've got a question that I've yet to find an answer to after scouring the various boards for a while. I've got my eye on a Regular Cab 2008 Tundra with the 6'6" bed. After chatting with a local guy who has one, and has a shell on his, he mentioned that he believed the shell was off of a double cab(not Crew Max obviously) truck.
    So, Can anyone confirm that the shells are similar for both of these trucks?
    They're both listed as 6.5" beds. I know cab angle can be a bit different, but it's common for Tacoma guys to use various configurations without too much issue.
    In my research it looks like only one of the four big manufacturers list a shell compatible with that truck configuration, yet I've seen some random photos on here and elsewhere of Leer, ARE, and even a Snugtop all on RCSB...
  2. Mar 1, 2021 at 9:45 AM
    Johntayl33
    Johntayl33 New Member
    Also have a 2008 regular cab. We’re you able to find an authoritative answer to this question?
  3. Jan 7, 2025 at 2:16 PM
    OregonRCSB
    OregonRCSB New Member
    I have a 2007 RCSB with a Snugtop cap. I bought it off someone who had it on his double cab. It fits, but is very close to the back-top of the cab. No squeaking or rubbing against the cab, but maybe only 1/4" or 1/2" gap at the closest spot.
  4. Jan 7, 2025 at 8:37 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I actually mounted a Leer cap from a 2013 DC onto to 2010 RCSB. Both 6’6”. The Leer
    would not fit my truck. The DC has rounded cab corners. RBC is a bit flatter across the back.
    The upper front corners of the cap rested right on the outside edge of my cab. If I’d slid
    the cap back 1/2-1” it would not have sealed the back door. So after looking for months,
    I’m still looking. Resigned to probably ordering new next year.
  5. Jan 14, 2025 at 9:00 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I just found a 2012 DC Leer 100XL canopy for sale. It doesn’t fit. The lower front will not seal on top of the front of the box. It’s less than 1/4” from the cab corners up top and because it can’t come all the way forward it’s almost an inch behind the rear of the box. So I’m going to sell this to someone with a double cab. Bummer.
    So I’ve put an old style 100XR and a new style 100XL both on my 2010 RC. They won’t fit. Really need a reg cab canopy.
  6. Feb 9, 2025 at 1:15 PM
    FarmerFrederico
    FarmerFrederico New Member
    Following. I’m picking up a RCSB next weekend. Might consider a Softopper until I can save up for a pop-up shell like TOPO Topper.
    Cruiserpilot likes this.
  7. Feb 9, 2025 at 1:20 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Seems like the Leer fits long. On the RCSB thread a guy just fitted an ARE cap from a DC. Tight
    but doable. Snug top looks like it fits different. The only two that I found, that I could actually
    put on to try were Leer, one older and the newer 100XL I got. Good luck.
  8. Jun 29, 2025 at 5:53 PM
    grant318is
    grant318is New Member
    Connor
    07 RCSB 5.7L 4x4
    Since this thread was helpful to me in searching, here is my ARE on a regular cab. It looks very close but in reality, you can fit a finger behind the cab and the topper.
