Spark plug replacement then weirdness.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraMcGov., Jun 29, 2025.
  1. Jun 29, 2025 at 4:09 PM
    TundraMcGov.
    TundraMcGov. [OP] Your friend. Your foe. Not yo Ho.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Seeking words of wisdom from the collective.
    Replaced all eight spark plugs and now I have starting issues.
    Prior to this routine maintenance it ran perfect.
    2015 3UR non flex
    190,000 miles on the engine
    What I used: Toyota dealer supplied Denso OEM plugs. Checked the gaps for compliance.
    What I did:
    * disconnected the battery
    * removed the air box lid and snorkel for access to bank #2.
    * one-by-one removed each coil, then plug, then installed new plug, then installed coil.
    * reinstalled snorkel and air box lid.
    * reconnected the battery.
    Started it up and it immediately ran rough and idled low.
    Turned it off. Waited a few seconds and repeated. Started up and ran rough.
    Turned if off again.
    Disconnected the battery for 20 minutes. Reinstalled and it cranked, winding out but never catching.
    Upon inspection of the fuse box I found the 10A INJ fuse was blown (see photo below identifying the fuse). Replaced it and repeated. It did it twice more.
    Enough of this shiznit. Plugged up the Xtool D8S bi-directional scanner and it's giving these four codes:
    * P0352 primary/secondary circuit of ignition oil B permanent.
    * P0353 primary/secondary circuit of ignition oil C permanent.
    * P0355 primary/secondary circuit of ignition oil E permanent.
    * P0358 primary/secondary circuit of ignition oil H permanent.
    At 190,000 miles I'm not sure if I should be of the belief that all the coils need routine replacement and the spark plug replacement just tipped the whole system far enough to throw codes.
    Below is confirmation of the fuse it keeps blowing. And then a shot of the plugs I removed.
    Thanks in advance.
  2. Jun 29, 2025 at 4:26 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I would go back and double check every plug to ensure:
    1. It’s firmly seated and clipped
    2. You didn’t bend any of the male side pins when plugging back in
    KNABORES likes this.
  3. Jun 30, 2025 at 4:05 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The scanner DTC reports the coils as letters. "B." "D." Etc. Who knows how the coil letters match up with the cylinder #'s? Does coil "A" go, for sure, with cylinder "1?" I can't find anything to confirm the relationship between the two.
  4. Jun 30, 2025 at 4:23 AM
    Retired...finally
    It makes me think that one or more of the coil electrical connectors got damaged somehow or one or more of the coils has a very low resistance causing that cylinder to not fire and ultimately blowing a fuse.
  5. Jun 30, 2025 at 5:18 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I have no advice but am interested in the outcome. Getting ready to change mine at 188,xxx.
  6. Jun 30, 2025 at 5:32 AM
    Danman34
    Danman34 New Member
    Danny
    Same. A damaged pin could be bent and arcing in the connector. That would certainly blow a fuse.
  7. Jun 30, 2025 at 11:52 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    The letters correspond to numbers A=1, B=2, etc. You have codes on both banks, cylinders 2,3,5, and 8. I see two possibilities.
    1) Your coils were on their way out and pulling them to do the plugs did them in.
    2) The ignition coil wiring was damaged during the job
  8. Jun 30, 2025 at 12:06 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Did you unplug each coil pack wire harness or no? I just did mine on my 2015 non-Flex Fuel and only unplugged #3 on the drivers side because it was wrapped around the main harness and there wasn't enough slack to remove the coil pack to get to the plugs. If you did indeed unplug each harness I would double check the connection. They "Seat" and seem ok but there is a resounding "click" when they are down all the way.
    Henry1jg likes this.
  9. Jun 30, 2025 at 12:17 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Unplug the coil packs for the affected cylinders, inspect the connections, replace the fuse again and see if it blows or not. If it does not, plug the coil packs back in, one at a time until it blows.
    I am assuming that the fuse is blowing in “Key on, engine off” state.
    Idling very low, stalling, and being grumpy to start are all par for the course after disconnecting the battery on these, until the ECM relearns the idle.
  10. Jun 30, 2025 at 12:52 PM
    1794Rookie
    1794Rookie New Member
    White 2017 1794 Edition
    Stock
    My son got a bad coil pack once.
  11. Jun 30, 2025 at 12:59 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    UPDATE 1
    I did unplug most of the electrical connectors.
    I went back around and rechecked all the connections to the coil sticks.
    All were good until I dug back deep for cylinder #8. This is passenger side nearest the firewall. Coil #H. And one of the DTC's that is thrown. I had the connection on backwards. Yes. Backwards. How in the hell? Well. This cylinder #8, coil #H, has a rubber boot over it. With how it is all assembled it is very stubborn on you sliding the rubber cover back. Then the natural orientation of the female connector is f'n backwards. And it slides right on backwards (weird). And I'm guessing in the heat of the day I spaced on listening carefully for "the click."
    Now.........getting it on in the correct orientation is proving to be stubborn. I think that the prongs have been pushed aside a bit. The access is an absolute bitch and the temp here in central Bamaland is 102*. So I'll try again in the morning when it is cooler.
    Thanks to all for the insights.
    Here's what the lil' rubber hood looks like:
  12. Jul 10, 2025 at 11:43 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    UPDATE 2. Solved.
    I have solved this conundrum by "going for it" and replacing all eight (8) coils and spark plugs with new.
    I used new Toyota OEM coils (part #90919-A2005) and new Denso plugs from a Toyota dealer (Denso SK20HR11).
    Made sure the coil lead wires were orientated correctly, turned the key and she fired right up like she always had.
    It may have only been the #8 coil and plug but rather than onesy-twosying it I figured at 190,000 miles and I'd just do all the coils. And I already had the plugs.
    So problem solved. But good grief what an (baseball term) unforced error. :angrygirl::angrygirl::angrygirl:
    ID-Matt, Henry1jg, JLS in WA and 3 others like this.
  13. Jul 10, 2025 at 1:05 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yowza! Thanks for sharing the experience and finding the solution! I'm glad you figured it out!
  14. Jul 10, 2025 at 2:26 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    I’ve learned that it’s best to just replace coils with plugs; especially for long-life plugs that are a PITA to get at.
    I recently did plugs on my Saturn Outlook before handing it over to my son. I replaced the Bosch coils (one was failing) and original plugs about 70k mile previously with Denso (OE supplier) coils. Less than 5k miles after replacing the plugs, one of the Denso coils went bad so had to re-do the job.
    HulkSmurf14 likes this.
  15. Jul 11, 2025 at 6:30 AM
    birdman076
    Chuck
    Montana
    I recently did the plugs on my wifes 2018 Jeep Wrangler. What a nightmare that is. The upper intake has to come off and all kinds of fun. It took about 3-4 hours in total. By comparison I did the tundra in about an hour.
