No electrical power to cab
Discussion in '2nd Gen Tundras (2007-2013)' started by jtg1441, Jun 27, 2025.
  1. Jun 27, 2025 at 8:41 PM
    jtg1441
    jtg1441 [OP] New Member
    HagerHill, KY
    2008 Tundra 4.7
    My 08 Tundra lost all electrial power to the cab after I unhooked my trailers light hook up. Ive checked all fuses & relays under the hood & replaced all in cab fuses and still no power. I got a new ignition switch today. Going to replace tomorrow. Anyone with any similar issues and if so what was the fix
  2. Jun 27, 2025 at 8:55 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like the main fuse. Got a multimeter? Check your battery voltage. Check for power going into the fuse box.
    also, just for fun check for corrosion on the battery terminals.
  3. Jun 28, 2025 at 9:13 AM
    jtg1441
    HagerHill, KY
    2008 Tundra 4.7
    Yes I have a multimeter and battery voltage is 12.4V I am getting readings between 8.2V-9.4V on my fuses in engine compartment and the light barely comes on when checking fuses in the cab. Ive replaced the ignition switch this morning and still nothing. I have tested some of the relays with a multimeter and most relays the reading went from OL too 0.00. But my starter relay reading never changed from OL.
  4. Jun 28, 2025 at 8:36 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    You should be reading at least 11-12 VDC (fully charged battery should be 12.6 or a little higher) on the fuses in the engine compartment. Are you sure that the main fuse in the engine compartment fuse box is not blown?
  5. Jun 28, 2025 at 9:03 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining Cooper Discoverer ATP II LT275/70R18 TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    Don't forget to check your grounds and the wires/connectors between the battery and the main fuse box
  6. Jun 28, 2025 at 9:08 PM
    vmkeith
    Vince
    Clark County, Wa
    Oh, and check your trailer light hook up. You might have something shorted to ground
  7. Jun 29, 2025 at 9:52 AM
    jtg1441
    HagerHill, KY
    2008 Tundra 4.7
    I have checked the engine compartments main fuse and its good. I never even thought to check my grounds. I'll check the grounds, wires and connectors today. Although I did replace the ACC Cut Relay along with replacing a few other relays and fuses that just looked rough but not blown and got power restored shortly. that i until I went to start it and either a fuse blew or the acc relay is out again. Im just at a loss. I get all my repair info from Identifix and try to do all the repairs myself. I have to say that its been an awesome truck. shes pushing 480,000
    ZappBrannigan likes this.
  8. Jun 29, 2025 at 10:00 AM
    vmkeith
    Vince
    Clark County, Wa
    Damn, 480k :thumbsup: Anyway, be sure to check out the trailer light hookup. You said power to the cab was lost after disconnecting the trailer light connection, something there could be the cause. You could also reconnect it and see if power returns.
  9. Jun 29, 2025 at 4:04 PM
    jtg1441
    HagerHill, KY
    2008 Tundra 4.7
    Thank you vmkeith for mentioning checking the trailer light hook up. It never even crossed my mind to even start looking there, because the power for the trailer lights obviously come from the fuse box. I guess I was just dead set on it being 100% a fuse or relay, but I can honestly say that I'm 100% glad I didnt take an interest in auto mechanic in school lol.
  10. Jun 29, 2025 at 4:06 PM
    vmkeith
    Vince
    Clark County, Wa
    Not a problem at all. Happy to help, especially if it leads to fixing the issue.
    jtg1441[QUOTED][OP] likes this.
