Tundra truck camper
Discussion in 'Towing & Hauling' started by Robacurt, Jun 29, 2025.
  1. Jun 29, 2025 at 6:57 AM
    Robacurt
    Robacurt [OP] New Member
    2019 SR5 TRD sport DC
    IMG_6001.jpg Made it 5,000 miles out west and back. Averaged 12 mpg on the trip, which is really good considering the load & front air push.
    QuicksandPNW and KNABORES like this.
  2. Jun 29, 2025 at 6:59 AM
    DrRansom
    DrRansom New Member
    Utah
    Silver Sky 2021 SR5 Tundra 4WD
    Cool camper and even cooler truck. How heavy is the camper?
    KNABORES likes this.
  3. Jun 29, 2025 at 9:29 AM
    Robacurt
    Camper = 1,500 Lbs.
    Truck with camper & loaded up + 2 people =8,600 lbs.
    summo springs add on rear & front, & e rated tires.
    Tunrod likes this.
  4. Jun 29, 2025 at 9:45 AM
    JRS
    JRS New Member
    2012 DCLB
    Upload a pic of your leaf pack when you remove the camper. Would like to see the shape they're in being that overloaded for that duration.
  5. Jun 29, 2025 at 8:01 PM
    Robacurt
    It was at the normal ride height the majority of the time loaded with the camper, gear & 2 peeps because of the SUMO springs. The majority of the weight was carried by the sumo’s. Also, the picture of this sumo was before I added a 1/2” spacer at the bottom & a flat plate on top for a better consistent contact to the frame. The brackets I used were not from sumo, I didn’t like theirs, so I made my own. That way the sumo’s were making full contact with some pre - loading from the truck only/lifted truck 2”. I looked at the springs before & after and see no difference. In the past I used airbags, but switched to these sumos for a firmer ride at the proper ride height, the airbags at proper ride height were to soft, to get the proper firmness I had to air them up to 80 psi, which then lifted the truck to high.
    JRS likes this.
  6. Jun 30, 2025 at 7:53 AM
    JRS
    JRS New Member
    2012 DCLB
    It must be the angle of the pic because, even with the Sumo, the pack looks like it's forcing the overload negative.
