Fuel smell in my engine oil
Discussion in '1st Gen Tundras (2000-2006)' started by mbb, Jun 28, 2025 at 7:18 PM.
  1. Jun 28, 2025 at 7:18 PM
    mbb
    mbb [OP] New Member
    Northern VA
    2000 TOYOTA TUNDRA ACCESS CAB/SR5 6 cylinder 4x4 manual
    My engine oil smells like fuel. It's not terrible but noticable. I replaced my O2 sensors because it was time anyway, but that did not seem to help. I thought I'd check for some common issues before going down the rabbit hole.
    What should I check next? Can I diagnose using an ECU data logger?
    2000 tundra v6 manual 4x4
  2. Jun 28, 2025 at 7:29 PM
    Could be leaking injectors.
  3. Jun 28, 2025 at 7:29 PM
    Both are petroleum products, so naturally, they're both going to smell like petrol. I've noted (on several cars I've owned) the same, where there almost seems to be a tinge of gas smell to the oil. Are you 100% positive this is an issue, or did you just now realize for the first time, "oh wow, used oil almost smells like gas!" ?
  4. Jun 29, 2025 at 2:36 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  5. Jun 29, 2025 at 5:49 AM
    bfunke
    bfunke Tundra Curmudgeon
    Change your PCV valve and oil first.
  6. Jun 29, 2025 at 6:05 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Back in the day my 70 Dodge Challenger mechanical fuel pump was leaking fuel into crankcase, the atomized vapors started choking out the car at idle. You can always send a oil sample to blackstone if you are worried, but slight fuel smell is normal.
  7. Jun 30, 2025 at 5:35 PM
    mbb
    mbb [OP] New Member
    Northern VA
    @KNABORES that is my next step as the injectors probably need replacing regardless. Might be original. The question is when.
    @bfunke I replaced the PCV valve around 30k miles ago. Might as well replace it, thanks for the reminder.
    @shifty` @w666 @Tunrod Sample to the lab it is - thanks so much. I think I was paying extra attention to the smell of my oil 2 changes ago. The current oil with under 100 miles has a very slight gas smell. My other cars have no gas small, which I used for comparison. The new oil in the bottle also has no gas smell. I'm really hoping that this is normal mainly because I'm afraid of prematurely wearing this excellent engine.
