Access Cab - Amp under passenger seat clearance?
Discussion in '1st Gen Tundras (2000-2006)' started by 1stGenOwner, Jun 28, 2025 at 8:03 PM.
  1. Jun 28, 2025 at 8:03 PM
    1stGenOwner
    1stGenOwner [OP] New Member
    I've been doing some research and it appears that the main places people mount their amps are either under the front seats or on the back wall behind the rear passenger seats.
    With that being said, I've settled on the front passenger seat. My concern are scratches. For those of you who has mounted your amps under your seats, is it getting beat up? Any scratches/scuff marks?
    I like to keep my gear as clean as possible, plus it is a pretty expensive amp. It's an Alpine Status HDA-V90 if anyone cares.
    Thanks in advance!
  2. Jun 29, 2025 at 9:01 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Unless you have kids or dogs that ride around in the cab, then I wouldn't worry about it. The only way it's going to get dinged up is if you have someone in the back seat putting their feet on it. Then a simple, nice but firm warning to "not get your grubby feet on my amp" should suffice.
  3. Jun 29, 2025 at 2:02 PM
    Definitely not like the driver's side. I wouldn't dare install my JBL HD900/5 under the driver's seat. I have a powered captains chair, and that joker gets loooooow to the floor.
    1stGenOwner[OP] likes this.
  4. Jun 30, 2025 at 11:58 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    I have two amps and a distribution block under the passengers seat. DSP (which is much smaller) is under the driver's seat. No probs.
