Boneheaded move today. Is it screwed
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mend0k, Jun 27, 2025.
  1. Jun 27, 2025 at 6:13 PM
    Mend0k
    Mend0k [OP] New Member
    2015 TRD Pro
    So I read that it’s recommended to drive 10mi a month in 4wd.
    I tried it today and drove like 2 miles then slowed down and made a right turn.
    It started to get stiff but got through with a lil jerk/noise.
    I then tried to reverse while the wheel is turned and it got stuck before jerking and making another noise.
    This is when I just stopped and googled and realized I wasn’t suppose to do that.
    So after reading I stopped, put the truck on neutral then disengaged 4hi.
    The blinker for 4hi kept blinking forever and I assume that it was just stuck so I turned off the truck. After turning it on the 4hi indicator was gone and I tried to drive but it binded again and made a loud sound before jerking again.
    So I repeat the process, put in neutral rengage 4hi then disengaged and finally the 4hi stops blinking.
    I have turned on 4hi and drove it straight just to test and turn it off while in neutral. It seems to be fine.. at least I think? I can’t tell if 4wd is actually on as I don’t want to drive on pavement with it on anymore.
    should I get it checked out at the shop? Did I break my differentials?
  2. Jun 27, 2025 at 6:24 PM
    18" TRD Off Road Wheels
    You don't have to go into neutral to use 4hi. It's meant to shift into and out of 4hi while in motion.
    It's fine to drive on pavement in 4hi, but you need to not make sharp turns. Read your owner's manual and it will explain it.
    chugs and bulldog93 like this.
  3. Jun 27, 2025 at 6:29 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    That’s one way to make sure everything is lubricated in the system haha.
    Everything is likely okay but don’t do that again!
    Just find a straight spot of highway and switch on/off 4hi every month.
    Wallygator, ZappBrannigan and WILLINH like this.
  4. Jun 27, 2025 at 6:52 PM
    Mend0k
    2015 TRD Pro
    Thank you il remember that. And I was looking for it but I guess the previous owner lost it as I couldn’t find it anywhere.
  5. Jun 27, 2025 at 6:53 PM
    Mend0k
    2015 TRD Pro
    Thank you, that eased my mind a bit lol.
  6. Jun 27, 2025 at 6:53 PM
    Should be available online, from the dealership, or in the Toyota app if your vehicle is new enough.
  7. Jun 27, 2025 at 6:54 PM
    Mend0k
    2015 TRD Pro
    Oh didn’t think of that, il look it up online. I just got this 2015 TRD pro like a couple days ago lol
  8. Jun 27, 2025 at 7:26 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Hell yeah, brother!
    Yota303, NWPirate, Wallygator and 7 others like this.
  9. Jun 29, 2025 at 5:04 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    2 things I require when buying a used vehicle are an owners manual and a spare set of keys/fobs.
    bulldog93 and Black Wolf like this.
  10. Jun 29, 2025 at 6:03 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can find your manuals here.
    https://www.toyota.com/owners/warranty-owners-manuals/
    Just uncheck the box; you don't need to create an account.
  11. Jun 29, 2025 at 6:28 AM
    Wallygator
    Also it's good to wait and do this on rainy days if you are going to do it on paved roads. :thumbsup:
    Mend0k[OP] likes this.
  12. Jun 29, 2025 at 11:01 AM
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    I use rainy days as an excuse to run it in 4WD occasionally . Typically on long straight sections where binding won't be an issue. Wish we had a center diff on our trucks. My old 4Runner had one and it was nice not having to worry about varying road conditions.
    chugs and Wallygator[QUOTED] like this.
  13. Jun 30, 2025 at 11:15 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    4x4 operating instructions are also located on your driver side sun visor for future reference in case you forget :thumbsup:
    Mend0k[QUOTED][OP] likes this.
