Roof crack
Discussion in '1st Gen Tundras (2000-2006)' started by Dustdog, Jun 4, 2025.
  1. Jun 27, 2025 at 8:38 AM
    Dustdog
    Dustdog [OP] New Member
    01, 05 AC 4wd
    stockers
    Thats an amazing finish.
    If it were anywhere visible Id get it sprayed by a pro. Being the roof, I will try it myself.
    Thank you to everyone for the responses
    G_unit3000 likes this.
  2. Jun 27, 2025 at 8:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I seriously considered doing my roof but my ARE cover needed attention also, so I chose to give our little towns Paint shop the job. They stripped both and after finished it looked new as ever....$1K
  3. Jun 27, 2025 at 3:34 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    Holy crud there is a lot to take out to pull the headliner. Rear seat backs and back panel look like they have to come out...With my weekend disappearing before my eyes I decided to peel away the damage- really just a way to procrastinate- and this is what I found.
    I think Im going to trim back to clean metal, wire wheel everything and paint.
    It seemed like a pretty consistent layer of filler under the paint. One long scratch dent and one penny sized probably from hail. You might be able to see them through the rust
    shifty` likes this.
  4. Jun 27, 2025 at 3:42 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Yes, there is a lot to remove, but it's just time and the vehicle is still usable with a lot of that stuff removed (you may need to reattach the seatbelt if that gets removed). Don't take the shortcut the last guy did. You'll kick yourself later.
  5. Jun 27, 2025 at 4:21 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Yeah, grind out all that filler and get back to shiny metal and see what you are actually dealing with. How big is the dent, I can't tell with no scale next to it.
  6. Jun 27, 2025 at 4:30 PM
    Dustdog
    01, 05 AC 4wd
    stockers
    That section is about 4 in diameter
