Moving to AZ - research thread
Discussion in 'Arizona' started by Breathing Borla, Aug 10, 2024.
  1. Jun 24, 2025 at 5:56 PM
    #511
    Azblue
    The Dirty T ( ^_^)_且
    This is mine, filter is at the bottom.
  2. Jun 24, 2025 at 6:02 PM
    #512
    Most people out here seem to have “split systems” with an air handler/furnace in a closet and a common return right at the air handler closet. A lot of people used to have swamp coolers(but also a heating furnace) the most common swap is a split system. Almost always ducts aren’t/weren’t insulated in a swap. Yours is a newer build so the sky is the limit, multiple returns is definitely a way better system to have because it will have better air circulation in all the rooms vs only sucking return air from one common area. R value with insulation and windows and doors also helps your cooling case.
  3. Jun 24, 2025 at 6:04 PM
    #513
    Is your drain line at the bottom on the lower or higher port? “Should” be at the lowest port with a drain overflow switch on the higher port(the ones right next to each other not the ones on the vertical plane)
    hahahah I didn’t even notice your foil pan “sump” let’s get you a proper condensate pump!
    NWPirate and TRDFerguson like this.
  4. Jun 24, 2025 at 6:07 PM
    #514
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I didn’t realize you have TWO casting couches. You dog.
  5. Jun 24, 2025 at 6:08 PM
    #515
    The fire place right in front of them really adds good mood lighting
  6. Jun 24, 2025 at 6:09 PM
    #516
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Great for those doggy style shots too
  7. Jun 24, 2025 at 6:10 PM
    #517
    You saw that video too?
  8. Jun 24, 2025 at 6:14 PM
    #518
    Azblue
    Yeah, the PVC is the drain. I put the pan under the P-trap when we were installing it 2 years ago when I was out of PVC glue and it was weeping. I got the glue and fixed it that night and just never took the pan out. This house had dual cooling with a swamp and A/C, I capped the cooler on the roof years ago. The house is on a slab, but was built with concrete tunnels below the slab to each room for A/C air intake.
  9. Jun 24, 2025 at 6:15 PM
    #519
    Azblue
    We have auditions every other Saturday night if you would like to apply.
  10. Jun 24, 2025 at 6:17 PM
    #520
    Breathing Borla
    Breathing Borla [OP] I'd rather be fishing
    Northern Illinois
    ok, thanks , I don’t remember anything but the big ass units on the roof , there is a shit ton of vents etc in there , with two thermostats and each unit does a portion of the house . When the inspector was cycling heat and ac it was pretty impressive how fast it raised and lowered the temp so we’ll see once I get out there .
    I’m getting a full duct cleaning as they had a cat and I need that all sanitized and they have shit ton of vents counted on the quote . The builder said they made it a point to have a robust system since that’s what people were most dissatisfied with in the area. We’ll see maybe it’s shit, maybe not , lol. It worked awesome when they were testing it though .
    they must have craned those up on the roof , those unit are pretty big horizontal ones or whatever , the seer rating is better than what I have now if that matters .
    its so fuckin humid here today mine is running non stop to keep up, a 2 story here is way harder to deal with and my current home is not built anywhere near as well as the new one.
    FrenchToasty[QUOTED] and Azblue like this.
  11. Jun 24, 2025 at 6:39 PM
    #521
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    We went with a baja shelf. its deeper than typical, at about 18". We got 2 polywood style adirondak chairs and we sit in them, and your bum/waist is in the water. I think its nice. Additionally, our Pentair lighting is nice (but the app /programming is annoying, it always locks up on purple/blue - but looks nice).
  12. Jun 24, 2025 at 6:45 PM
    #522
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nice setup!
    We did an 8x12 18” deep baja shelf as well. It’s money. The dogs love it and I’ll hang out there when I’m watching a ball game or movie.
  13. Jun 26, 2025 at 12:56 PM
    #523
    rdiddy5
    rdiddy5 New Member
    Arizona
    so when's the Tundra crew housewarming party?
  14. Jun 26, 2025 at 1:05 PM
    #524
    Breathing Borla
    Northern Illinois
    Im sure the wife would love that, lol.
    rdiddy5 likes this.
  15. Jun 26, 2025 at 1:13 PM
    #525
    Breathing Borla
    Northern Illinois
    so you guys find the 18" depth is perfect for that?
    Im kicking around doing that plus a little 0 entry at the end of it like taper it down or something
  16. Jun 26, 2025 at 1:13 PM
    #526
    rdiddy5
    rdiddy5 New Member
    Arizona
    You - "Hey babe. all my new AZ toyota friends wanna come over"
    Her - "you want to invite internet strangers to our new house?"
    You - "yea, whats wrong w/ that?"
    some of my most legit friends came about meetups from old mazda forums
    TRDFerguson and Azblue like this.
  17. Jun 26, 2025 at 1:15 PM
    #527
    Breathing Borla
    Northern Illinois
    lol, awesome.
    Id be sleeping outside with the snakes :eek2:
    Azblue likes this.
  18. Jun 26, 2025 at 1:27 PM
    #528
    rdiddy5
    rdiddy5 New Member
    Arizona
    There's a step in to the baja shelf. and 2 steps down to the shallow end.
  19. Jun 26, 2025 at 1:29 PM
    #529
    Breathing Borla
    Northern Illinois
    I see, that could work,
    I could put a railing down that side for the older folks with the steps then
    whats going on over on the right, is that just a in pool seating area type deal?
  20. Jun 26, 2025 at 1:42 PM
    #530
    AZBoatHauler
    So.Arizona
    I've lost count how many people from the forum I've met up with in real life. Dozens. 99% have been awesome.
    BillyB, Azblue, TRDFerguson and 3 others like this.
  21. Jun 26, 2025 at 1:50 PM
    #531
    Breathing Borla
    Northern Illinois
    thats good to know, I hope to keep that streak alive when I get out there.
  22. Jun 26, 2025 at 2:20 PM
    #532
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Not as many snakes as people like to think. You'd be sleeping with the meeces long before the esnakes arrive.
    Tons more bugs and critters in VA than AZ.
    BillyB likes this.
  23. Jun 26, 2025 at 2:40 PM
    #533
    Breathing Borla
    Northern Illinois
    thats good to know,
    same here, you cant even be outside right now with all the mosquitos , nats, flies, bees , hornets, yellow jackets, no seeums, etc.
    plus its absolutely fuckin awful out today,
    96 degrees, and the worst part, dew point 75+. ugh , you fuckin gills to breathe this shit
  24. Jun 26, 2025 at 2:48 PM
    #534
    Azblue
    So I guess that I'm that 1%. :pout:
  25. Jun 26, 2025 at 2:54 PM
    #535
    But out here we have special bugs that will make you have nightmares…….
    One that comes to mind is the palo verde beetle…….
    IMG_6295.jpgThis is a larva we found digging up a sewer line at the kids school, so you can imagine the actual beetles size!
  26. Jun 26, 2025 at 3:04 PM
    #536
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  27. Jun 26, 2025 at 3:30 PM
    #537
    AZBoatHauler
    So.Arizona
    Those cookies have you in the top 1%. Kids still talk about them.
  28. Jun 26, 2025 at 3:57 PM
    #538
    Azblue
    I'll make it an annual thing. :fistbump:
  29. Jun 26, 2025 at 6:25 PM
    #539
    Breathing Borla
    Northern Illinois
    shit no matter where you are
