  1. Jun 25, 2025 at 8:42 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Another mow man eh? Pretty nice. Did you do your own thing or work for someone?
    It's been that heatwave all this week and we just drink more fluids and keep going. I don't like working in such heat and humidity but today I had plenty of energy and even with my sore arm, I did all the weedeating. 8 yards done today.
    Today I tried out the "Shift L" button and she went into first gear just fine. I drove her a few feet in that then took it out.
    Today I pulled the small trailer and we did 6 yards. My wife had to go so I did 2 more alone. She finished her work and helped me weedeat that last yard. The Tundra is humming along just fine and I am so thankful to have her. :)
    Tomorrow we'll pull the long trailer. :)
  2. Jun 26, 2025 at 5:35 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I attached 2 100W flexible solar panels to my Softopper and connected them to a Victron MPPT controller. Keeps my battery topped up and has an auxiliary load output that I can connect additional devices to like our fridge/freezer for camping. The solar panels have 15' long cables so I can take them off the truck and set them on the ground pointed more precisely at the sun.
    The Bluetooth interface on this charge controller is really impressive too. Keeps perpetual logs on solar performance, battery health/condition, allows you to set charge profiles for different battery types and chemistries, adjust custom behaviors for the auxiliary load output, and a lot more.
    FrenchToasty, Voss, Suwand28 and 11 others like this.
  3. Jun 26, 2025 at 5:58 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I think i have that exact Victron charge controller as well. It works really well and I love the BT capability that lets you monitor your battery and panels.
    Did you velcro your panels to your soft topper? Or how are they removable? I have one 200watt panel mounted on my camper. Works great for fridge, lights, fans and charging phones and stuff.
  4. Jun 26, 2025 at 6:08 AM
    Mustanley
    Hendersonville, NC
    I used 1.5" wide Velcro brand hook and loop and then added 1/8" vinyl coated steel cable as a failsafe/anti-theft measure. If I ever need more capacity, there's room for 2 more panels (1 on the Softopper and 1 on the roof) and the charge controller should easily handle them all in series (100V/20A).
    Voss, des2mtn and oscardog86 like this.
  5. Jun 26, 2025 at 7:53 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I like it. I have portables like you, and need to figure out some sort of velcro on my camper shell to attach them to. I made small frames for mine to put them on the ground and angle them towards the sun, but otherwise I just throw them on top of the camper shell during the middle of the day. With my driving habits, I think the portable is a better call than a hard-mounted rigid one, even if they're slightly less efficient.
  6. Jun 26, 2025 at 8:54 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I need to pick a way to hang mine off the side of my cap, shade the side window as a bonus.when i had mine standing sideways on my roof (on concrete) i could pit the truck in neutral & push it a few feet every couple hours (with the steering turned about halfway to lock) to ‘track’ the sun. Both panels can increase battery voltage over time, but just a 100w panel could only maintain voltage.
    i do wish my charge controller had some bluetooth, but it shows about 14a in full sun.
    455h0le_dachshund and des2mtn like this.
  7. Jun 26, 2025 at 8:58 AM
    des2mtn
    SW
    Tonto cover
    I've also done magnets with eye hooks/ caribiners on the cab, put a piece of cloth in between the magnet and the cab as to not scratch the paint. Works with shade cloth if you have a strong enough magnet. Obviously doesn't work on the cap or for what you're trying to do, but yeah.
  8. Jun 26, 2025 at 9:43 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, still havent epoxied in my magnets yet. Its in the plans.
    des2mtn likes this.
  9. Jun 26, 2025 at 11:14 AM
    Softopper
    Softopper New Member
    That’s an awesome setup! We love seeing how people adapt their Softopper to fit their needs—this is a great example of making the most of your gear. Always cool to see creative solutions like this in action.
  10. Jun 26, 2025 at 3:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Let's see the whole truck. I've never seen a DC with a Softopper
  11. Jun 26, 2025 at 4:08 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Swing out version two
  12. Jun 26, 2025 at 10:13 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Just another day pulling. 18 foot trailer with two zero tuns then 12 foot trailer with one zero turn.
    Hope to take tomorrow off!
    bmf4069, Hutcheson, KNABORES and 3 others like this.
  13. Jun 26, 2025 at 10:16 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You pull em with separate trucks or alternate using your tundra?
    If the former, what's the second truck? Also a tundra?
  14. Jun 27, 2025 at 6:52 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Anyone got tips on getting the LCA bolt alignment holes to line up with the mounting points? It's looking like the bushings are ever so slightly too thick to get in there for me to get the bolt through. I force one end in partially so ONE bushing is captured but not both bushings are captured, but then the other side is off by 2-3mm on the edge of the bushing.
    The brown stuff is copper anti seize per Solo Motorsport's instructions.
    where Im at now:
    safe to trim the LCA bushings or is there a trick to forcing them in?
  15. Jun 27, 2025 at 7:21 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Got a crescent wrench and rubber mallet?
    Twist the crescent til it's tight enough to slide snug onto the part of the frame with the alignment holes and pull it gently out as necessary, checking clearance often, so you don't over do it.
    Should slide right in then.
    If the bushings are still snug but going on evenly on all four sides, give it some love taps with the mallet.
    That's what Casey and I did when we installed my Solos.
    Stock63, oscardog86, shifty` and 3 others like this.
  16. Jun 27, 2025 at 7:22 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Good old fashioned force. Assdogs truck had some crossmember damage so we had to bend the ears out a bit with a wrench.
    almost jinx.
  17. Jun 27, 2025 at 7:37 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    A couple hammer taps to spread them and then tighten the bolts to bring them home. I seem to remember doing that with my oem LCA replacements.
  18. Jun 27, 2025 at 9:03 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    Ball joints on the blue one today.
    Passenger was gritty, lumpy, and non OEM. Casting, zerk, and the (4) bolts gave it away.
    Driver was OEM and hard to remove. Not sure why they got mismatched or if the driver was original..
    My buddy's Blue has 141k and my gray has 145k. Both 06 DCs.
  19. Jun 27, 2025 at 9:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The blue is beautiful. I'm so :jellydance:
  20. Jun 27, 2025 at 9:32 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    The blue is really nice, it's grown on me, the paint is in great shape. It definitely has less pinstripes than the passenger side of mine.
  21. Jun 27, 2025 at 9:43 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Oem had loctite, did you loctite?
  22. Jun 27, 2025 at 11:42 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    You know, it would be nice! I have two trailers, a single axle 12 footer and a double axle 18 footer. The single axle is better built, being all 1/8 inch tubular steel while the 18 footer is 1/8 inch angle steel. Dad had the shorter trailer built to order about 20 years ago.
    I would like a second Tundra for that job as it's annoying having to switch out the ball (I have that 3 way ball hitch) but that'll have to wait! LOL
    I have considered a dually flat bed as a mowing truck (I've seen those) but I'd lose 4wd and I don't think for us that such is the best use of a dually.
    At the moment, there are two roads we have to back up to get to the client's house and both are single lane, gravel roads. So far though, it's working out fine. Whenever I talk to a new potential client, one of the things I look at is how to approach and leave. If it's too much of a hassle, I pass.
  23. Jun 28, 2025 at 11:46 AM
    Creeped under the truck today and inspected everything. I haven't done this in a while. I've been so focused on fixing all the stuff wrong with my house that the truck hasn't seen much love this year.
    Looking at my brakes. I believe I've missing the anti rattle springs aren't I?
  24. Jun 28, 2025 at 12:08 PM
    bfunke
    bfunke Tundra Curmudgeon
  25. Jun 28, 2025 at 12:12 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I double up on those
  26. Jun 28, 2025 at 12:20 PM
    Those rattle springs come in use when you have the vehicle inspected and they test your tie rods and possibly fail your vehicle after hearing it.
    I would 2nd @G_unit3000 and double up. Grease those caliper pins while you’re at it.
    bmf4069 and G_unit3000 like this.
  27. Jun 28, 2025 at 12:34 PM
    Are they universal or specific to our trucks? No clue why I didn't install them when I put the brakes on. I can hear them rattle when I go over bumps and it stops if I apply the brakes.
  28. Jun 28, 2025 at 12:42 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    This is the way ....
  29. Jun 28, 2025 at 12:48 PM
    I've got some extras in my toolbox if you want them
  30. Jun 28, 2025 at 1:09 PM
    Good question. I would think universal, but that’s a guess. Been a long time since I worked on someone else’s brakes.
    Maybe MacGyver that sh!t and make it out of clothespin wire?
