General Turbocharger Thread (formerly "Turbo Charging A Tundra!")
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Jun 25, 2025 at 8:47 AM
    #2311
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    Removing those lines is a no brainer, regardless of what people choose to do with the other transmission bits. And they were definitely the silliest heatsink I have ever seen. lol
    Mdl and TurboKits like this.
  2. Jun 25, 2025 at 11:17 AM
    #2312
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Good catch! I will replace both the thermostat and warming puck therefore no more need for coolant down as you mentioned.
    I will need both hoses for coolant and oil.
    The end state will be:
    1. A direct rubber coolant hoses from the front of the engine to the firewall. Remove hard lines.
    2. Remove both thermostat and warming puck. Remove hard lines. Use new oil hoses.
    Maybe is time to do a full coolant and trans. oil flush too.
    Today I'm going to take a close look at all of these things to make sure I understand everything correctly and plan the action plan.:)
    bflooks[QUOTED][OP] and Mdl like this.
  3. Jun 25, 2025 at 11:19 AM
    #2313
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No issues with mine removed for over a year. You should be good down in your warm climate.
  4. Jun 25, 2025 at 12:02 PM
    #2314
    TurboKits
    TurboKits New Member
    Drain and fill only on the TRANSMISSION. Do not FLUSH or replace all fluid at once.
    Jego[QUOTED] and bflooks[OP] like this.
  5. Jun 25, 2025 at 1:52 PM
    #2315
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    10-4 will do!
    I didn't imagine why but now I understand why.
  6. Jun 25, 2025 at 1:55 PM
    #2316
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    You'll need to at least top off both Trans fluid and Coolant as both levels will drop when removing the warming puck/adjusting the lines...there's no harm in doing both as long as you keep everything straight. When I removed the Trans thermostat and warming puck I did a full drain and fill on both.
  7. Jun 25, 2025 at 2:08 PM
    #2317
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    This is the first time I am doing something like this and have no experience with it at all:) lol. Just for precaution, I will do the mods, top off the coolant, and full flush to trans. I will do the coolant flush after few more days having it running and tested.
    armyoffoo[QUOTED] likes this.
  8. Jun 25, 2025 at 3:56 PM
    #2318
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Never heard that and if you do each independently shouldn't be an issue. I've never done just a drain and fill. I've always exchanged as much fluid through the cooler return line. But it's not a flush.
  9. Jun 25, 2025 at 5:39 PM
    #2319
    bflooks
    Metrowest MA
    I think that is a difference that has been thoroughly discussed though. Purging (via cooler line) is different than pressurized forcing (via flush). You know, like using a squatty potty vs getting a hernia from grunting. Same, but different. :)
