Lifted Tundra Outer Tie Rods (Pro Comp Lift)
Discussion in 'Suspension' started by Snowboard Tundra, Aug 19, 2023.
  1. Aug 19, 2023 at 8:03 AM
    Snowboard Tundra
    Snowboard Tundra [OP] New Member
    Guys-
    I'm posting this here in hopes that it will live on through the internet and help someone else as I just went through this. Internet searches gave me some data but never exactly what I needed, I was able to hunt down the parts I needed and get my truck fixed so thought to share. Here is the quick rundown, with additional details to follow.
    Truck: 2016 SR5 Tundra. 6" Pro Comp Lift.
    Mileage: 180xxx
    Issue: Outer Tie rods loose, needed replacement
    Narrative:
    Seems like an easy fix, source some new outer tie rods and that's that. Turns out finding them for my truck wouldn't be so easy, various internet searches did yield some part #'s but nothing definitive. Pictures weren't lining up either, my tie rods were short and straight and nothing I found matched what they looked like. I couldn't find anything definitive that said for your make and model you need exactly this.
    I emailed Pro Comp and found out that the straight tie rods I had on my truck were no longer used. Apparently there was an issue with them rubbing against the spring, so they switched out to a curved set which...he said I could order from 4 Wheel Parts (but I couldn't find that part # on their website to begin with).
    I sent him (Benny at Pro Comp) this link to the installation manual:
    https://www.4wheelparts.com/sku/Trail Master/standard/TM505N_INST.pdf
    And told him what I needed (based on page 13) was:
    - Driver: 90-40232
    - Passenger: 90-40231
    He replied with: Part number 90-40231B is a boxed pair of those, and you can order them through 4 Wheel Parts. They can be reached at 877-474-4821.
    I called 4WP, ordered that part #, had them installed and am now good to to. Pics follow.
    Old Tie Rods on the truck:
    New stuff in a box and compared to old stuff:
    New tie rods installed:
    Tundra2Yak, Keoki_m and D4x4TRD like this.
  2. Jan 26, 2025 at 5:03 AM
    Kfxnow
    Kfxnow New Member
    Joel
    2008 DC 4x4 lifted
    Did this happen to also fix the issue that PC has with the steering geometry? My symptoms (and many others) are that at full turn, the truck 'walks' or 'snowplows' because the lift causes asymetric turning radius on the truck.
  3. May 2, 2025 at 4:25 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    I have the same lift but 7 inch. Pro Comp told me the only difference was the 1 inch in coil spacer.
    I just installed JBA uppers and Rough Country Vertex coilovers. Alignment shop is having trouble getting camber dialed in. They said the tie rods ran out of adjustment and they should be shorter to make everything play well.
    I'm curious if the coachbuilder tie rods would work with these Pro Comp spindles or if they would hit. Long shot, but anyone have experience with this setup?
  4. Jun 25, 2025 at 1:52 PM
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Just ordered a set of these for 4WP, and they are getting very scarce. The local 4WP had to check nationwide to find a set; I guess ProComp has basically gone out of business.
