So ... you wanna buy / just bought a 1st Gen Tundra, eh?
Discussion in '1st Gen Tundras (2000-2006)' started by shifty`, Nov 14, 2022.
  1. Apr 20, 2025 at 4:01 PM
    #211
    DocHolliday3841
    DocHolliday3841 New Member
    2005 Blue Tundra Double Cab Limited 4x4
    I bought upper and lower control arms from trq however I'm using Moog ball joints on the ucas and reusing the lower OEM ball joints as they are made to unbolt from the lca.
    This is just temporary as I feel in a year+ I might pull the trigger on the SAS conversion I've been considering.
  2. Apr 20, 2025 at 4:07 PM
    #212
    shifty` [OP] Earth acid cleanses me, cleanses me clean
    If you really think you're likely going through with SAS conversion in 1-2 years, then that would settle it for me. Get extended links. Install the 6112s, noting the lift results others have gotten at misc notches versus what Bilstein tells you is fact (FYI: It's not fact), install the extended links, and call it a day.
    At least one user, @KNABORES, found he was able to stick with the OEM Toyota links with his lift by using a stack of washers to lift the top "bushing sandwich" (as I'll call it) roughly an inch. He was still able to screw down the top nut, which IIRC is a nylock, enough to have 1-2 threads pop out the other end, even with that stack. That may be an option for you too.
    I deleted my swaybar totally, and the only time I notice is when I'm hitting a 270° interstate offramp at 40mph+. That may also be an option for you.
    Good luck with the TRQ parts. We'd love to have your feedback on their quality/longevity over here after 1-3 years: https://www.tundras.com/threads/1st-gen-parts-corner-of-shame-oem-minus-or-plus.122591/
    KNABORES likes this.
  3. May 27, 2025 at 12:27 PM
    #213
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Was skimming this again and didn't realize our trucks want Dexon 3 atf, not regular power steering.
    Why is that?
  4. May 28, 2025 at 5:07 AM
    #214
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Dexron III ATF is used in power steering systems due to its lubricating properties and ability to reduce friction
    shifty`[OP] likes this.
  5. May 30, 2025 at 10:54 AM
    #215
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  6. May 30, 2025 at 11:28 AM
    #216
    Nicklovin
    Nicklovin Yap Yap
    Makes sense. Just blows my mind a bit that a power steering pump doesn't want power steering fluid.... and now my system may have both fluids in it :anonymous:
  7. May 30, 2025 at 11:31 AM
    #217
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    If you can't properly do a flush right now, use the turkey baster method to drain and fill with Dex III in the meantime.
    Nicklovin[QUOTED] likes this.
  8. May 30, 2025 at 12:10 PM
    #218
    I'm glad you fixed the typo in that pic.
  9. May 30, 2025 at 12:11 PM
    #219
    They're extremely similar in nature, minus the additive package. I think ATF adds detergents? I'd need to go look it up.
  10. May 31, 2025 at 4:31 PM
    #220
    retiredguy111
    retiredguy111 New Member
    Littlestown, Pa.
    2000 Tundra Base Regular Cab 8 ft. bed 2wd 3.4
    Thanks Shifty....
    I really need the 2000 Tundra wiring diagram...
  11. May 31, 2025 at 5:49 PM
    #221
  12. Jun 1, 2025 at 5:47 AM
    #222
    retiredguy111
    Littlestown, Pa.
    Yep, got it..
    Looking for a common ground or power that causes instruments and accessories to cut out when I shift into drive or use turn signal or hit bumps. If I slap the top of the dash or bottom of the column it sometimes all comes back on, or it all comes back on next morning..
    w666 likes this.
  13. Jun 19, 2025 at 11:23 AM
    #223
    Leojin
    Leojin New Member
    Illinois
    2004 Tundra Limited DC 4x4 4.7L V8
    Just wanted to say hello and thanks to @shifty`for this post. I just bought a 2004 DC on Monday and have never owned a toyota before. I read through several build threads before buying, but having all this information organized in one place is *chefs kiss*
    I have some big plans for this truck and have the pdf file saved on my phone and pc. It is a great road map
  14. Jun 19, 2025 at 11:26 AM
    #224
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Welcome!
    G_unit3000, BroHon, Tundra2n3 and 5 others like this.
  15. Jun 20, 2025 at 9:28 AM
    #225
    Leojin
    Leojin New Member
    Illinois
    :rofl:Sometimes its best not to see whats on the other side of the fence
  16. Jun 20, 2025 at 11:26 AM
    #226
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Leojin[QUOTED] and shifty`[OP] like this.
  17. Jun 24, 2025 at 1:10 PM
    #227
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
  18. Jun 25, 2025 at 6:43 AM
    #228
    RLB
    RLB New Member
    Randy
    Original Buyer and Owner of 2006 DC Tundra
    I'm new to the forum, just never thought I'd be seeking out a Tundra forum and read through a lot of what Shifty had to say "not all of it" most of what he said doesn't pertain to me because I am the original owner, so what brought me here was seeking advise on my closed Transmission to change or not to change, but first a bit of background, from what Shifty described, I must have a unicorn because I am the original owner and the Truck is sill like Brand new, that's because I went over and beyond on the upkeep, I've used nothing but Valvoline Oil Full Synthetic and swapped it out with shelf life not mileage because in my case shelf always came before mileage, it's always been garage kept, though most of not all of the 81k are in town/city type driving, I purchased my SR5 DC the last year of the Gen1 back in 2006 and it only now has 81k on it. I'm in central TX no rust here and have been retired for the past 16 years, I rode a Harley for several year which helped keep the miles off the truck, so my Gen1 is sill like a new truck at least in my eyes. To this day no matter where I go I get compliments and or is it for sale? Questions on the truck because of it's brand new like condition, things I recently done to it were changing out the front headlight housings to get rid of the yellow completely, replace the rear bumper it had a couple small backing dents in it that I put there and I replaced the in-dash with an high end Kenwood flat panel and added a backup camera to it, original harness, solder joints. At my age I now know that, I did good when I purchased this truck as it's going to be my forever truck and now that I have modernized it, even more so.
    I remember when I took it in to the Toyota dealer from where I bought it from for it's 50k mileage warranty check many years ago, I was told then it had a closed system and so now today I'm wondering if I should go ahead and get the fluid swapped out, I've heard issue with flushing so I'm thinking if I get it done a drain and fill only.
  19. Jun 25, 2025 at 7:05 AM
    #229
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Welcome (also) from Texas!
    I'll throw my hat in and recommend a DRAIN AND FILL ONLY.
    G_unit3000, RLB[QUOTED] and KNABORES like this.
  20. Jun 25, 2025 at 7:35 AM
    #230
    Good call on the Tundra and sounds like great job on the upkeep. Drain and fill is the way here. While the newer transmissions in everything are “sealed”, they are not truly maintenance free. The fluid gets old (think shelf life you described for your engine oil), the fluid also gets “dirty”. Not from environmental contaminants like your engine oil does, but mostly just byproducts of torque converter wear. Worth an occasional, 30-60k miles, drain and fill of the 3.5-4qts that will come out. Not necessary to drop the pan as there is not a paper filter, but merely a mesh screen that won’t ever clog up.
  21. Jun 25, 2025 at 9:02 AM
    #231
    bmf4069 Captain wtf
    You wanna sell it?
    BroHon, G_unit3000, PNW15 and 4 others like this.
  22. Jun 25, 2025 at 9:25 AM
    #232
    RLB
    RLB New Member
    Randy
    I should of seen that coming :)
  23. Jun 25, 2025 at 6:41 PM
    #233
    The four big killers of these trucks:
    • Using non-OEM lower balljoints, or failing to refresh the lower balljoints after 100k miles.
    • Failing to replace the timing belt/water pump/tensioner (for V8 trucks) with the OEM-supplier, Aisin, kit ending in part# -021 every 100k miles or 10 years of service life - Toyota says 90k/9yr as long as you use OEM-grade equipment, and OEM is one of their OEM suppliers, settle for nothing less. We've seen (even recently) stories of other brands, including big names like Gates, failing with as little as 50k-60k miles, which isn't good for a low-interference engine.
    • Radiator, specifically "pink milkshake", the transmission fluid passes thru the bottom of the radiator and the seals on that connection are known to give out, sending coolant into your transmission. Best bet: Replace with a new Denso brand unit when you do the timing belt, it's an extra $125-150. Always use pink-colored SLL coolant! If you have anything else, you should really purge at the radiator/both drain blocks, flush once or twice with distilled water, install pink SLLC.
    • Rust, which depending on your location/usage, may not be a problem. If you're not launching your boat into salt/brackish water and don't live in an area that salts the roads, chances are this doesn't impact you.
    Congrats on being an original owner. You're smarter than 90% of the other truck owners out there, no doubt :rofl:
  24. Jul 8, 2025 at 11:05 PM
    #234
    DocHolliday3841
    Has anybody tried removing the front coil spring on a 2005 - 2006 double cab Tundra to fully cycle the suspension and playing with the alignment Bolt to see what is the largest size tire you can truly fit? I feel like this plus proper wheel offset would give a true answer as to how big of a tire we can fit. I sure wish I had a lift
  25. Jul 8, 2025 at 11:28 PM
    #235
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    You're not properly fitting 35s on this truck unless you cut metal. Don't care what anyone else on here tries to tell you.
    shifty`[OP], bmf4069 and PNW15 like this.
  26. Jul 8, 2025 at 11:34 PM
    #236
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    There's a lot of different tire threads around here, but I haven't seen a secret recipe of offset, caster, and tire width that will for certain tell you the biggest diameter you can run at full stuff and at full lock. Most people don't take into account full stuff and full lock in their reported fitment.
    Something documented like tinkerers video but for 1st Gen would be dope.
    I don't have enough personal experience to say for sure but Id be skeptical if there was a recipe for 1GT to fit 35s, and definitely not 37s. I think skinny 35s with positive offset, and probably spc uppers and solo lowers might even be a fairytale without something being trimmed on the front bumper... Or moving wheel wells...
    Shocks are easy to remove on these trucks imo, so the cycling is not hard... It's the investment into the rarer wheel offset and the uppers and lowers to find the sweet spot.
  27. Jul 10, 2025 at 4:10 PM
    #237
    DocHolliday3841
    Not looking to fit 35s but possibly 34 x11.5r17
    I'm also thinking an aftermarket off-road bumper would help because then I wouldn't be so limited in terms of the tire hitting the front bumper
  28. Jul 14, 2025 at 4:32 PM
    #238
    DocHolliday3841
    Has anyone watched the 1st gen build on "The Dirt Head Shed" on YouTube? Dave Chappelle of the former MotorTrend show "Dirt Every Day" helps a buddy build one of these 1st gens.
    https://youtu.be/XGuxf62Alac?si=3MXBRWvwM1DJNXWB
  29. Jul 14, 2025 at 5:34 PM
    #239
    Nicklovin
    Nicklovin Yap Yap
    I watch his videos sometimes but haven't seen that one yet
  30. Jul 14, 2025 at 6:05 PM
    #240
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    I want to see more on this truck.
