35s or 37s
Discussion in 'Wheels & Tires' started by Chan, Jun 25, 2025 at 12:34 AM.
  1. Jun 25, 2025 at 12:34 AM
    Chan
    Chan [OP] New Member
    Yesterday
    Chandler
    Tundra
    Hey so I’m getting new wheels and am debating 35s or 37s the car is on a 1.75 level king kit with rear spacers and will be moved over to king 3.0 within the next 2 months. Any recommendation on which size to go with along with if a rehear is needed for 37s, as I’ve seen very mixed responses
  2. Jun 25, 2025 at 12:43 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Year make and model will go a long way…
    pretty sure it would be hard to stuff 37” on a 2nd Gen with just a 2” level; I know it can be done with perfect offset but it’s a challenge
    and in terms of regearing, that falls down to what gears you have from factory, each model is different with tow package and without etc; you could also potentially look at a tune instead to get some power back
    and welcome to the forum!
  3. Jun 25, 2025 at 1:04 AM
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    I went with 37’s. No regear needed.
  4. Jun 25, 2025 at 12:54 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Welcome! No regear options available yet for the third gen’s, but as other people have said, doesn’t seem necessary. My truck spins its 35s with ease. My truck is just leveled, no lift in the rear, and I’ll still rub the tires on the fenders when I bottom out, but that’s mostly because of my zero offset wheels. Go with whatever look you prefer - the only thing I’d do, if I were to do it again, is getting C-load 35s instead of heavy ass E-load.
  5. Jun 25, 2025 at 12:54 PM
    Chan
    Yesterday
    Chandler
    Tundra
    Sorry forgot to add model and make
    2024 tundra limited crewmax
    joseph_womack likes this.
  6. Jun 25, 2025 at 1:11 PM
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Is having a full size spare important to you? If so, a 37" won't fit in the factory spot, but if you're going with 3.0 Kings, I'm assuming the truck is being built for high speed desert use and will carry the spare(s) in the bed for weight distribution...
  7. Jun 25, 2025 at 1:30 PM
    Chan
    Yesterday
    Chandler
    Tundra
    Yes I’ll be putting a bed spare in the upcoming months so that’s not too big of a worry. More just worried if I’ll clear 37s for the two months without 3.0 kings and if it’ll need a regear as not sure what mpg or if it creates a drag feeling with the 3rd gen tundra
  8. Jun 25, 2025 at 2:09 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Suspension lift does not aid in your ability to clear larger tires when actually cycling the suspension. If you use the full stroke of the suspension, at some point, the suspension will be compressed and the wheel will the in the same place as it would be with the stock setup, effectively having zero lift.
    BillyB likes this.
  9. Jun 25, 2025 at 11:22 PM
    Chan
    Yesterday
    Chandler
    Tundra
    Are you on any aftermarket suspension or leveling kits? Also how is the clearance been when it comes to travel
  10. Jun 25, 2025 at 11:38 PM
    18" TRD Off Road Wheels
    If you are even remotely concerned about MPG stick to stock tire sizes. Adding all that rotational mass is going to be a hefty bit of extra work for the truck. Lifting it up is also going to hit you in the MPGs. If you start down this road you have to just accept your mileage is going to be trash and you chose to do it. No bitching about it later.
    Mallcrl and BreyTundy like this.
  11. Jun 26, 2025 at 8:05 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I did 35s then 37s. I wouldn't go back to 35, but there are trade offs. 37s are heavier mpg will suffer. Truck still has plenty of power, but braking distance will increase.
    You will have to trim. Front fender crash horn at minimum. Some front and rear fender depending on lift and wheel backspacing. Mudflaps are gone.
    I'm on about 2.5" on front and <1" on the rear lift wise.
  12. Jun 26, 2025 at 6:37 PM
    Chan
    Yesterday
    Chandler
    Tundra
    How is the travel with 37s when off-roading ,have you taken it through any whoops
  13. Jun 26, 2025 at 7:42 PM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I live in high desert, plenty of high speed whoops, some rocky areas and snow driving on paved and unpaved roads.
    I don't beat on the tundra like a dedicated off road machine (I've built a samurai and Cherokee in the past, plus I've got a couple ATVs for trail stuff) but the tundra does great. Remote reservoir shocks eat up the high speed desert and I've trimmed enough for full articulation.
    Works well for me.
  14. Jun 26, 2025 at 7:54 PM
    Chan
    Yesterday
    Chandler
    Tundra
    Could you send pics of what you trimmed or go into further detail. Intrested as to what you had to exactly do
  15. Jun 26, 2025 at 8:36 PM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I can get a few pic tomorrow
