Play at 3 and 9 o’clock on front wheels
Discussion in '1st Gen Tundras (2000-2006)' started by grzzlr, May 8, 2025.
  1. May 8, 2025 at 4:31 PM
    grzzlr
    grzzlr [OP] New Member
    2002 AC V8 TRD 2x
    Front end has new shocks, upper/lower arms, ball joints, and tie rods, and steering rack bushings in the past year… is it the steering rack or am I being paranoid and this is normal?
    thanks for your help!
  2. May 8, 2025 at 4:33 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Both sides or just one? Could be inner tie rods, could be the rack. Was the steering wheel locked down?
    grzzlr[OP] likes this.
  3. May 8, 2025 at 4:33 PM
    grzzlr
    2002 AC V8 TRD 2x
    Oh I remember I also did the outer tie rods but I’m realizing we didn’t do the inner could the inner ones cause this level of play?
  4. May 8, 2025 at 4:34 PM
    grzzlr
    2002 AC V8 TRD 2x
    both wheels, steering was not locked should I do that and check again?
  5. May 8, 2025 at 4:36 PM
    Lock the steering wheel and only lift one side at a time to test
  6. May 8, 2025 at 4:37 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, or make a mental note of how much the steering wheel jiggles. The rack can wiggle a bit, the bushings can wear. And the factory steering lock isnt tight enough. I lock it, then bungie the wheel to sorta hold it to one side of the lock. One side at a time will usually solve that problem.
    jack the whole front end up, lay across and use your feet to stabilize one side while you jiggle the other side. You can usually see if the rack or bushings are loose.
    grzzlr[OP] and FrenchToasty like this.
  7. May 8, 2025 at 4:39 PM
    Sounds like a new yoga pose
    grzzlr[OP] and Sirfive[QUOTED] like this.
  8. May 8, 2025 at 4:41 PM
    grzzlr
    2002 AC V8 TRD 2x
    Locked the wheel, raised one side at a time and the play persists
  9. May 8, 2025 at 4:43 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Did you replace the inner tie rods?
  10. May 8, 2025 at 4:45 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I call it spitroasted by engineers.
    but the beauty is you can hold a wheel with your hands and wiggle the other at your feet to help determine which inner tie rod it is.
  11. May 8, 2025 at 4:46 PM
    grzzlr
    2002 AC V8 TRD 2x
    No I realized we hadn’t done those, I’ll start there. Should I go OEM?
  12. May 8, 2025 at 4:48 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i didnt. But i’m no role model.
  13. May 8, 2025 at 6:47 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Always. If you can.
    grzzlr[QUOTED][OP] likes this.
  14. Jun 23, 2025 at 9:31 PM
    MeanGreenmachine
    MeanGreenmachine New Member
    2001 green tundra limited ac
    lol a little late to the topic sorry to open it back up but
    sorry to open this topic back up but I’m dealing with the same thing after replacing upper and lower ball joints and both cv axles and outer tie rod ends. did you find out what was causing it?
  15. Jun 24, 2025 at 11:01 AM
    Looks like a wheel bearing to me. But 3/9 o'clock is also indicative of tie rod, however, in this case, you can see the entire knuckle/hub is flopping around - bad TRE aren't going to cause that.
  16. Jun 24, 2025 at 8:56 PM
    grzzlr
    2002 AC V8 TRD 2x
    I replaced the whole steering rack today. The inner tie rods were toast but the rack was also leaking so I went ahead and did the whole. All better now!
    Jack McCarthy and shifty` like this.
  17. Jun 24, 2025 at 8:56 PM
    grzzlr
    2002 AC V8 TRD 2x
  18. Jun 26, 2025 at 8:52 PM
    MeanGreenmachine
    Oh hell yeah I’m on a budget so I ordered a Detroit axle and with 2 day shipping I had to as bad as I wanted to go OEM I couldn’t.
    what brand did you get? OEM?
  19. Jun 30, 2025 at 9:10 PM
    grzzlr
    2002 AC V8 TRD 2x
    I'm on a budget too... I went with Detroit Axle too I think it was $203 before tax. I haven't looked into shipping the core back for the warranty but the rack is self feels good for now.
  20. Jul 1, 2025 at 4:20 AM
    bmf4069 Captain wtf
    I've had the DA rack for 3 years now with is about 3/4 of a year in regular people miles, with 6 off road adventures. It's been fine.
    MeanGreenmachine likes this.
  21. Jul 2, 2025 at 10:22 AM
    grzzlr
    2002 AC V8 TRD 2x
    Good to hear!
