  1. Jun 23, 2025 at 6:43 PM
    !Marauder
    !Marauder New Member
    2019 white tundra
    I added 20" lightbar to the top hood scoop:
    Florida AF, Cthulhu, GAknight and 6 others like this.
  2. Jun 23, 2025 at 7:00 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    made it home! 10 days, 2292 miles. truck ran really good- only exception was that the AC didn't feel super cold at times. need to diagnose that.
    pulled our camper from phoenix, az > tucson, az > alamogordo, nm > roswell, nm > balmorhea, tx > fredricksburg, tx > austin, tx > san angelo, tx > las cruces, nm > home. mostly saw 7-8mpg. first 3 days were 105F+ temps (Intake temp read 130F+).
    ZPhilip, JMGmanAZ, woods and 5 others like this.
  3. Jun 23, 2025 at 7:16 PM
    martiartisan
    martiartisan New Member
    North Texas
    2020 Tundra DC, 2006 Tundra Crew Cab
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Did you ever figure this out? I am having a similar issue but getting a clunk at low speeds (15-20mph) on bumpy roads. I retorqued everything with no luck.
  4. Jun 23, 2025 at 7:20 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Talking sense into him is like talking sense into me…it ain’t worth the hassle
    reywcms and FrenchToasty like this.
  5. Jun 23, 2025 at 7:46 PM
    I just went from Toytec Alumas to Bilstein 8112's and 8100'S.....night and day difference!
  6. Jun 23, 2025 at 8:21 PM
    NWPirate
    Zach
    WA
    I need to check these out :D
    Details on your build thread?
  7. Jun 23, 2025 at 8:40 PM
    I went from Toytec to these. I currently have SPC arms but I'm wondering if I should replace them with the Bilstein or Dirt Kings.
  8. Jun 24, 2025 at 4:51 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
  9. Jun 24, 2025 at 8:48 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Nice! Which one?
  10. Jun 24, 2025 at 8:52 AM
    Fobroader
    Fobroader New Member
    Alberta
    2020 Platinum
    Threw on some OME front springs, a cheap jungle website 2" lift block for the rear, SPC upper control arms and Timbren bump stops front and rear. She rides OH so much better on the rough gravel road I take on the daily. The bump stops are worth their weight in gold but the new front springs mean that she doesn't bottom over the slightest bump.
    TacomaTRD4x402, ATV25 and bulldog93 like this.
  11. Jun 24, 2025 at 9:12 AM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Polished my wheels..
    Velocity72, ATV25 and bulldog93 like this.
  12. Jun 24, 2025 at 9:14 AM
    What did you torque the bolt and the ball joint castellated nut too? I ask because the instructions are wrong.
  13. Jun 24, 2025 at 9:16 AM
    Fobroader
    Alberta
    2020 Platinum
    Uhhhmmm, no idea, had a shop toss everything on for me.
  14. Jun 24, 2025 at 9:23 AM
    I would highly recommend checking them. The UCA bolt should be 173 ft lbs, the large ball joint mounting nut is 200 ft lbs for the maintenance free ball joint, and the stud castellated nut is 81 ft lbs, not 45 as stated.
    Henry1jg, Yota303, ATV25 and 4 others like this.
  15. Jun 24, 2025 at 1:25 PM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
  16. Jun 24, 2025 at 1:35 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles +2 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI High flying steering wheel TRD shifter knob LED lights inside/outside Morimoto 3rd brake light
    I like it....where did you purchase that bad boy?
    Corndog123[QUOTED] likes this.
  17. Jun 24, 2025 at 1:41 PM
    Corndog123
    Sam
    Tennessee
    It was Amazon. 400 bucks. Weighs about 80 lbs. Seems solid enough. There isn't much to the OEM bumper. Not much at all. This is more substantial. I looked it over before I put it on and everything seems to be made well. The welds were good, the D ring mounts are beefy as are the D rings. The only problem is my harness for the trailer plug isn't long enough. I don't pull a trailer but I like everything to be hooked up like its supposed to be.
    BR73[QUOTED] and Gainer like this.
  18. Jun 24, 2025 at 1:43 PM
    I would get rid of the red on those corner pieces. IMO it would look better.
  19. Jun 24, 2025 at 1:51 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    That's an understatement... the rear bumper wouldn't stop a Chevette at full throttle... nor would the front...
    Corndog123[QUOTED] and bulldog93 like this.
  20. Jun 24, 2025 at 1:51 PM
    Corndog123
    Sam
    Tennessee
    I'll probably paint them black.
    bulldog93 and BR73 like this.
  21. Jun 24, 2025 at 1:59 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Managed to get the torque converter fluid up to 258. Caught the picture below. Pan temps stayed in 230’s. This was on route 50 in WVA on a long steady hill climb. No cooler.
    Henry1jg, Corndog123, ATV25 and 3 others like this.
  22. Jun 24, 2025 at 2:06 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    Installed the tailgate lock kit from Pop & Lock. Part# PL8547TUN. This updated version includes the wire harness for under the passenger kick panel which used to be separate. No wire taps. Easy install, plenty of videos on YT. Longest part was routing/tucking the wire safely under the truck. Feels better knowing the tailgate is always locked now!
    Also swapped the oem all-weather mats for a weathertech set I found on marketplace for cheap. Part #444081-440938. Much better coverage overall. I like how the front mats go over the door sills where water used to collect. Only gripe is the left-foot rest area isn't fully covered, not sure why they designed it like that. Back mat is awesome, complete coverage.
  23. Jun 24, 2025 at 2:11 PM
    Boneskull420
    Boneskull420 God loving,Tundra driving,rednek custom joker!
    Mark
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Looks good! I've looked at the front bumper version of that 1.
  24. Jun 24, 2025 at 2:23 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
  25. Jun 24, 2025 at 2:25 PM
    BR73
    BR73 TUNDRA LIFE
    Rick
    Talladega,Al
    Oh yeah that's me right there....I have a 7pin extension for my 2 rear bumper pod lights so I'm probably good
  26. Jun 24, 2025 at 3:01 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    You’re not wrong. In my normal day to day driving, I usually never see anything over 220. I also don’t tow. But it’s a good insurance.
  27. Jun 24, 2025 at 3:05 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    My day to day temp is 195-200. when towing its 199-208 on flats, and when doing steep grades its 220ish.
  28. Jun 24, 2025 at 7:00 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Were you able to measure the front hub centers to fenders to figure out what lift height you ended up with?
  29. Jun 24, 2025 at 7:20 PM
    I measured from the ground to the bottom of the flares but I will have to do it from the hub. I know that I didn't lose any height between these and the Toytecs.
    HulkSmurf14 likes this.
  30. Jun 24, 2025 at 7:41 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    Looks good! :thumbsup:
    woods and Corndog123[QUOTED] like this.
