Vibration
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1794Rookie, Jun 22, 2025.
  1. Jun 22, 2025 at 3:03 PM
    1794Rookie
    1794Rookie [OP] New Member
    White 2017 1794 Edition
    Stock
    Hey guys, when I test drove my 2017 it had a bad vibration. The dealer doesn’t fix it until it’s bought. So I bought it and test drove it before I brought it home. No vibration because I stayed in the city. Needed an alignment, which now I think the salesman was lying about, because there alignment machine was broken. Anyway they sent it out for an alignment, came back and I took it home. On the way home, still needs a better alignment and I was getting a vibration. What would be the common causes of this vibration? Thanks
  2. Jun 22, 2025 at 6:19 PM
    Mr Badwrench
    Mr Badwrench New Member
    Do you feel it in the steering wheel, or driveline, brake pulsation? Where do you think it is coming from?
  3. Jun 22, 2025 at 6:40 PM
    Where does it feel like the vibration is coming from? Any lift kit or is it stock? How many miles....it could be a a few different things....tire balance, rotors, ball joints, tie rods, etc.
  4. Jun 22, 2025 at 9:18 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    I just dealt with vibration myself. Mine was tire issue. Took it three times to get it forced balanced. Finally got it to where it was good enough.
    Shakes the body like a shimmy and some vibration at the steering wheel.
    I'd try that first. It's the cheapest option.
    Good luck
  5. Jun 22, 2025 at 10:02 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    My experience so far with vibrations has been from unbalanced tires. Even when correctly balanced there seems to always be a certain speed that there will be one.
    phabej likes this.
  6. Jun 22, 2025 at 10:07 PM
    Tundrav82019
    Tundrav82019 New Member
    Leo
    2019 Tundra Limited TRD Off Road
    Road force balance the tires, ensure PSI is good.
    do you have E rated tires or P rated?
    Alignment for sure.
    Generally tire shops can check for ball joints and laxity in the control arms while checking tires.
  7. Jun 23, 2025 at 6:41 AM
    1794Rookie
    Stock
    I feel the vibration with my butt, and I look at my side mirror and it’s shaking. It’s got about 60 thousand miles on it. Thanks
  8. Jun 23, 2025 at 6:48 AM
    Mr Badwrench
    Does it happen all the time, when you're braking, accelerating...?
    If you don't feel it in the steering wheel, you can probably rule out the front tires being out of balance or anything in the front suspension.
    1794Rookie[OP] likes this.
  9. Jun 23, 2025 at 7:57 AM
    1794Rookie
    Stock
    I have stock wheels and 275/55/20 Michelin Defender ltx m/s tires.
  10. Jun 23, 2025 at 10:10 AM
    gunpup
    gunpup New Member
    Nate
    WA
    2018 SR5 DC
    If it is in a particular speed window such as 50-60mph before slowly subsiding or reducing as the speed increases over that window it is likely just a wheel balance issue.
    Tundrav82019 likes this.
  11. Jun 23, 2025 at 10:10 AM
    Tundrav82019
    Leo
    Could be suspension or tire balance in rear wheels
  12. Jun 23, 2025 at 10:25 AM
    Retired...finally
    4x4? If so, put it in 4wd and test.
  13. Jun 23, 2025 at 10:35 AM
    Tundrav82019
    Leo
    Road force balancing would likely be very helpful. It’ll also know if your wheel is bent.
    are your wheels OEM or aftermarket?
    are the lugs to spec, 97 foot lbs?
    any uneven wear on the tires?
  14. Jun 23, 2025 at 12:32 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Depending on tire and environmental conditions, temporary tire flat spotting isn’t uncommon. Also, road surface conditions play a factor especially when one considers highway expansion joints. Could just be some bed bounce.
  15. Jun 23, 2025 at 6:35 PM
    1794Rookie
    Stock
    Actually did have a little today I noticed. Going to the dealer Friday and getting an alignment but I’m going to tell them to check the balance on the tires first.
