5.7 motor mounts
Discussion in '2nd Gen Tundras (2007-2013)' started by Bonzen, Dec 16, 2019.
  1. May 25, 2025 at 7:49 PM
    #361
    MEGA VOL
    MEGA VOL New Member
    24 1794 limited edition
    I would be interested in a set of both but it doesn’t feel like timing is going to work out? I have an appointment at TCCN automotive on June 3rd for a full inspection and most likely a new motor and transmission.
    I’m not sure what the timeframe will be after June 3. This will be a 2nd vehicle and project truck.
    I have a pretty nice 2010 chassis with 377,000K road miles on a 5.7. I don’t do a lot of off roading but I’m always interested in good up-grades.
  2. May 26, 2025 at 3:24 PM
    #362
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
    Appreciate the interest, I am 4 weeks out on lead time right now, and thats before the GB orders. So if you placed an order today, you would be looking at July for delivery.
  3. May 27, 2025 at 12:00 PM
    #363
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    This might be an obvious or N00b question, but what are the tq specs for the motor mount lock nuts (red circle)? I'm a tq spec kind of guy. Same thing applies to the trans verticle lock nuts.
    If it's 2.1-million-foot pounds with globs of red Loctite, then I'll send it.
  4. May 27, 2025 at 1:00 PM
    #364
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's not a torque spec. You want to get it close/touching and maybe a turn or 2. If they are squeaking back off a little. Over tightening can cause premature failure. I rechecked them twice about 100miles to ensure they were good.
    On the trans mount that used nylocks I did torque those as there is no poly-bushing.
    @Bonzen or others can chime in on their method.
  5. May 27, 2025 at 4:31 PM
    #365
    Bonzen
    I don't have a torque spec, there isn't anything to reference for these parts because none of these parts with the Poly bushing is OE manufacturer engineered to ASTM/SAE standards. That 9/16" bolt with the nylock nut shouldnt ever come loose, crank it down tight - but not so tight that the bushings start squeezing out. At some point the inner bushing sleeve will bottom out on the tabs and it wont tighten anymore anyway(noted in the instructions). These things don't pivot or move, the bushing is just there for vibration dampening.
    So in summary, send it.
  6. May 27, 2025 at 4:47 PM
    #366
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Good to know. I had my traction bar bushing tear from over tightening. Didn't want that to happen here. Thanks!
    bulldog93 and AstroDude like this.
  7. Jun 23, 2025 at 2:14 PM
    #367
    Bonzen
    Getting close to start on the GB trans kits.
    @SAGE63 @Ryuu @Mdl How are the trans mounts working for you all?
    AstroDude, Mdl, Wynnded and 2 others like this.
  8. Jun 23, 2025 at 3:05 PM
    #368
    SAGE63
    San Diego County
    Received mine today. have not even opened the box yet...will be installed after the 4th of July.
    Bonzen[OP], Mdl and reywcms like this.
  9. Jun 23, 2025 at 3:35 PM
    #369
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The trans mount is doing great! Holding up with no issues. Hard to tell with the Solid engine mounts but it does seem more planted. I ordered up a Mitch Made billet carrier bearing, soft. I'll be replacing the u-joints so I'm sure it'll be pretty solid at getting as much power to the rear. I have no issues with noise or vibrations. Vibration is minimal at startup and idling around.
  10. Jun 23, 2025 at 6:17 PM
    #370
    Bonzen
    Upgrading the carrier bearing is a major under-rated mod. Any serious off road truck should have that done.
    2mchfun, bulldog93, Wynnded and 2 others like this.
  11. Jul 24, 2025 at 9:53 PM
    #371
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    How are these coming along?
    Mdl likes this.
  12. Jul 25, 2025 at 10:05 AM
    #372
    Bonzen
    I have one more website order I have to build that the customer is hot for, then I'm onto the GB trans mounts.
    AstroDude, Mdl, Wynnded and 1 other person like this.
  13. Aug 3, 2025 at 6:16 PM
    #373
    Bonzen
    The GB trans mounts will start shipping this coming week, finally caught up with everything else. I am painting one right now that will ship tomorrow.
    AstroDude, Wynnded, reywcms and 4 others like this.
  14. Aug 3, 2025 at 7:10 PM
    #374
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Awesome looking forward to it!
    Mdl likes this.
  15. Aug 5, 2025 at 1:10 PM
    #375
    Bonzen
    Guys, update - I have 3 trans kits ready to ship right now but I have zero bushings. My bulk order hasn't shown up yet, I contacted my supplier this morning and they apologized for the delay but said they are going to get them out the door today, which puts them in my hands on Thursday. As soon as they show up I will pop them in the kits and ship everything I have. Will be welding up the rest of the GB kits until then.
    AstroDude, Wynnded, bulldog93 and 2 others like this.
  16. Aug 5, 2025 at 1:12 PM
    #376
    SAGE63
    San Diego County
    Will be installed Friday August 8th...
    Is there a # to reach out to if we have any issues or questions
    bulldog93 likes this.
  17. Aug 5, 2025 at 2:36 PM
    #377
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    With the solid mounts there is enough room to lift the t-case. Double check hose and wiring when lifting it up. It may seem like not enough room to remove but there is as it'll be pretty close.
  18. Aug 5, 2025 at 2:37 PM
    SAGE63
    San Diego County
    Thanks. Will need to remove the RCI Skid plates too....
  19. Aug 5, 2025 at 2:46 PM
    #379
    Bonzen
    Replied to your PM
    SAGE63[QUOTED] likes this.
  20. Aug 5, 2025 at 2:49 PM
    #380
    Bonzen
    I know you didn't have to loosen the engine mounts to install the trans mount, but if it is close for anyone else, loosening the big 9/16" bushing cross-bolt will yield additional flex to raise the T-case up. Just don't forget to re-tighten those bolts after!
    Follow the instructions:thumbsup:
  21. Aug 5, 2025 at 3:04 PM
    #381
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks! Forgot about the 9/16 bolt. I didn't need to loosen, but check for any strain on the engine mount cross bolt. Might be good idea to just loosen as to keep from checking them out each pump on the jack.
  22. Aug 5, 2025 at 3:07 PM
    #382
    bflooks
    bflooks New Member
    Metrowest MA
    Reading this is telling me I need to get it shipped to CT instead of my house so someone can do it "while they're in there". DM inbound @Bonzen
    Mdl, Bonzen[OP] and bulldog93 like this.
  23. Aug 5, 2025 at 5:00 PM
    #383
    Bonzen
    Its definitely a good "while you're in there" mod haha.
    bulldog93, Mdl and bflooks[QUOTED] like this.
  24. Aug 5, 2025 at 5:04 PM
    #384
    bflooks
    bflooks New Member
    Metrowest MA
    Thanks for the quick pivot!
    Mdl likes this.
