Oil so clear you can’t see it?
Discussion in 'General Tundra Discussion' started by blee, Jun 23, 2025 at 2:39 PM.
  1. Jun 23, 2025 at 2:39 PM
    blee
    blee [OP] New Member
    2017 Tundra XSPX
    I got an oil change today at a new Toyota dealer. (New to me). I was able to watch them do the oil change and I think it made my ocd a little crazy lol. They just filled it up with a hose that I suppose had a button you press on the nozzle to say how many quarts etc. but they didn’t even check the oil with the dipstick afterwards so I felt like I needed to check it when I got home. I’ve never checked my oil level immediately after an oil change but is it normal for it to be so clear you can’t see it? I mean it’s like water… if I held it in the sun just right I could barely see there is something on the stick but when I first took it out I was freaking because I thought it wasn’t even touching the stick … when I wipe the stick some seems to be coming off but I don’t know. It was a huge dealership and they were probably working on 30 plus cars at one time so I would assume they put the right amount … I guess maybe this is why they don’t check it because you can’t see it anyway lol.. I really can’t tell exactly where it is on the stick
  2. Jun 23, 2025 at 2:56 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Sounds about right, get some mileage on it and it will darken and u can see it better
  3. Jun 23, 2025 at 2:58 PM
    EmergencyMaximum
    Interesting. Whenever I fill up with new oil, it's definitely not clear. Maybe they filled it up with machine oil?
  4. Jun 23, 2025 at 3:02 PM
    blee
    2017 Tundra XSPX
    Not sure why they would have machine oil as an option to fill though? I did read that synthetic oil can appear clear when it’s new but I’ve never looked before
  5. Jun 23, 2025 at 3:03 PM
    blee
    2017 Tundra XSPX
    That’s what I’m reading so hopefully that’s what’s going on
  6. Jun 23, 2025 at 3:04 PM
    EmergencyMaximum
    My mobil1 0w20 synthetic is yellow when filling up. I mean its somewhat transparent, but not to a point you describe. If I peek into the jug, I almost have to verify it's not old drained oil.
  7. Jun 23, 2025 at 3:13 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  8. Jun 23, 2025 at 3:14 PM
    blee
    2017 Tundra XSPX
    Hmm yea this is pretty clear like I can see there is something wet on the stick but it’s literally so clear I didn’t see it at first …
  9. Jun 23, 2025 at 3:15 PM
    blee
    2017 Tundra XSPX
  10. Jun 23, 2025 at 3:18 PM
    I thought I read on this forum somewhere, it’s easier to read depending which way the dimples are facing when you insert the stick, either towards or away from the engine
    blee[OP] likes this.
  11. Jun 23, 2025 at 3:21 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I seen that as well ... towards engine, but I don't think it makes a difference.
  12. Jun 23, 2025 at 3:25 PM
    blee
    2017 Tundra XSPX
    So you mean the side that has them raised should be toward the engine? I don’t think it will make a difference in this case either
  13. Jun 23, 2025 at 3:27 PM
    rcsbguy
    rcsbguy New Member
    On your dipstick, use 500+ grit sand paper and sand some horizontal lines up to the full mark.
    When you re-insert it, go all the way down till the o-ring seats and remove quickly.
  14. Jun 23, 2025 at 3:27 PM
    EmergencyMaximum
    I think as long as oil is not overflowing from the dipstick while engine is running, it's good.
    bflooks and FrenchToasty like this.
  15. Jun 23, 2025 at 3:31 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    There was a post in here somewhere and the guy stated it was in the owners manual for oil level check. I looked and couldn't find it, perhaps an earlier model?
  16. Jun 23, 2025 at 4:08 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    It might take me 10 different wipes and checks, but i can tell where my oil level is after an oil change. It is kinda clear and I need good light to see it good.
    Petro, blee[OP] and Tunrod like this.
  17. Jun 23, 2025 at 4:16 PM
    blee
    2017 Tundra XSPX
    I just went out there and checked again after the sun had gone down some (different lighting ) and I can tell better now where it’s at in the stick I can see the glare from the oil when I twist it certain ways .. once the oil was a little darker at the tip of the stick but I can see the oil is in safe range now … just super clear ..
    Tunrod likes this.
  18. Jun 23, 2025 at 4:17 PM
    Adamace1
    Adamace1 New Member
    None....
    That's good. It's sad the dealer won't check the engines oil after they change it. I do all my own maintenance because nobody seems to care and I know if they mess it up, then they will fight as hard as they can to not pay to repair their F up...
    Tunrod likes this.
  19. Jun 23, 2025 at 4:21 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    The true mystery is I use Royal Purple and it goes into the engine very dark purple and shows up on dipstick clear AF. Brake cleaner trick works for me during oil changes and checking first thing in the morning thereafter.
  20. Jun 23, 2025 at 4:23 PM
    blee
    2017 Tundra XSPX
    Yes I thought it was wild they didn’t check it after .. putting a lot of trust in their handy dandy oil filling device. I’m sure it’s accurate but why take a chance doesn’t take that long to check
  21. Jun 23, 2025 at 4:24 PM
    blee
    2017 Tundra XSPX
    That’s wild
  22. Jun 23, 2025 at 4:29 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I can confirm it needs to be less than 1.15 gallons overfilled to not have issues. :oops:
