3rd Gen TRD Performance Exhaust review
Discussion in 'Performance and Tuning' started by G8Santini, Jun 23, 2025.
  1. Jun 23, 2025 at 6:36 AM
    G8Santini
    G8Santini [OP] New Member
    25 Tundra SR5, 4x4, PremCnv, Perf. Pkg., Blackout, TRD 3”Lift, 20”TRD rims
    Heritage grille, fog lights, 35x12.5x20” Nitto, low profile toolbox, F/R tow hooks
    My 2025 SR5 Tundra came with the rear TRD dual tip exhaust PTR03-34222 dual-tip in black. Family Toyota of Burleson (TX) had installed before delivery. Overall sounded slightly deeper compared to my stock 2025 Tundra Limited. With rear exhaust idle was better tone, and there was a better tone at full throttle. Wasn’t a lot of change.
    I added a Houston TIG stainless exhaust and it was much louder. Better, deeper idle tone, raspy on throttle, great sound on full throttle. We tow, and the drone could get excessive @ 2100rpm cruise around 80, or normal driving hitting a hill/grade.
    Swapped that system out recently for TRD center section PTR03-34221. It is a true dual input into a single muffler about 3/4 the size of the stock Toyota center muffler, and exits as a single pipe into my -34222 dual tip. Around 30 pounds, super well built, and looks like small version of OE muffler. Sound is better than stock at idle, and improved the dual tip rear system in tone. Not raspy or loud. Nice low tone on wide open launches & shifts. Let’s you hear turbos better. Good overall, solved the drone issue, but I’d like it a bit wilder.
    I’d rate stock a 1, stock with TRD dual exhaust a 2.5, the TRD full system of center & rear a 5.5, and Houston TIG a 7.5 for overall performance sound. The Houston TIG will probably go back on this truck. I may try the TRD center section on my wife’s 2023 Sequoia.
    If you want some tone and happy family & neighbors then the full TRD exhaust is your clear choice. The full TRD is pricey, and for same value you can get Borla, AFE, etc., but you live in the hills or tow will probably have drone issues. You can’t beat the TRD warranty if a dealer installs (3Y/36K). I just like to do these mods myself.
    Pic 1&2 = OE stock muffler to Houston TIG
    Pic 3 = full center sections comparing Houston TIG to PTR03-34221
    Pic 4&5 = -34221 installed
    Pic 6 = PTR03-34222 dual tip exit location
    Tundra Dude 45 likes this.
  2. Jun 23, 2025 at 7:44 AM
    sudobash
    sudobash New Member
    That won't work. Center section for the Sequoia is completely different.
    PTR03-0C250
  3. Jun 23, 2025 at 8:10 AM
    G8Santini
    Thx Sudobash for the input. I need to get under the Sequoia & do some measuring.
    sudobash likes this.
  4. Jun 23, 2025 at 5:05 PM
    lapoolboy
    lapoolboy New Member
    So if I'm reading this correctly, I can bolt the TRD Performance muffler (center section) under my truck AND keep the TRD Pro dual tip tailpipe section???
    I've always thought it was all or nothing with the TRD Performance exhaust setup.
  5. Jun 23, 2025 at 7:32 PM
    G8Santini
    Yessir. You can use the PTR03-34221 center section with either the stock tailpipe w/ its built in resonator, or with the -34220 dual tail pipe. The rear muffler collector bolts up the same to either the rear stock or TRD dual exhaust. The system uses all of the same stock rubber mounting isolators in original mounting locations.
  6. Jun 23, 2025 at 9:41 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Oh wow. I can so make a system super deep without all the drone.
    dirtydeedsindustries.com
  7. Jun 24, 2025 at 5:13 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Saving this for reference. I also had the same Tig weld exhaust. I also have his dump tip. Definitely a noise maker. Around town loved it. Turbo noise galore. Highway my ears couldn’t handle it. Even with the factory exit, resonated tip. It got better but the highway drone. Factory muffler was reinstalled with tig welds dump tip. A slight tone change but my ears are happy. So yes my tig weld is up for sale.
  8. Jun 24, 2025 at 7:22 AM
    dirtydeeds
    Keith
    USA
    I’m sorry you’re unhappy with your exhaust. That person is unfortunately converting a lot of tundra owners from guys who want an exhaust back to guys who just wan stock.
    please don’t be discouraged by that one company’s poor performing product. We have a solution which allows you to have a good clean sound with minimal drone.
    https://youtube.com/@dirtydeedsindustries?si=PDdEnccTeRZaEGHa
  9. Jun 24, 2025 at 12:05 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I’m not discouraged. I know all about the rift between you and Casey, lol. I really do hope he gets things figured out. I know a lot of people are pissed and they have the right to be. Your system does look and sound awesome. Haven’t heard it in person though. Keeping it fairly OG for now.
  10. Jun 24, 2025 at 12:13 PM
    lapoolboy
    Yea, but it don't have this shit!
    ARB1977[QUOTED] likes this.
  11. Jun 24, 2025 at 2:32 PM
    dirtydeeds
    Keith
    USA
    Yup. I do, plus, NO DRONE;)
    1lowlife likes this.
  12. Jun 24, 2025 at 3:03 PM
    lapoolboy
    which is it??
    Minimally pregnant is still pregnant.
  13. Jun 24, 2025 at 3:11 PM
    dirtydeeds
    Keith
    USA
    Pregnant and exhaust systems are the same thing?
  14. Jun 24, 2025 at 3:17 PM
    lapoolboy
    Nope, never said they were. It's obvious I'm asking for you to clarify if it has "minimal drone" or "NO DRONE". Either it drones or it doesn't. Understand now?
  15. Jun 24, 2025 at 3:19 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  16. Jun 24, 2025 at 3:37 PM
    dirtydeeds
    Keith
    USA
    Drone in our trucks is 80-90hz in one area of the rpm range. And about 130hz in another rpm range.
    My system takes those frequencies and knocks them down to a tolerable level.
    It would be misleading of any company to say it gets rid of those frequencies. I believe that saying there is no drone is like saying those frequencies are not there anymore.
    when I say ‘minimal drone’ I’m saying that the drone frequencies are lower than they would be if I didn’t do what I do.
    I can also say that the only other exhaust system where those frequencies are lower…. Is stock.
  17. Jun 24, 2025 at 3:41 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I'll take a painted functional system over a system members are removing from their Gen 3s because of the loudness and drone.
    Did TIG stainless exhaust start offering a swap if a customer wasn't happy with their product?
    Or are customers just stuck with something they don't want?
    My 10" BAM on a 5.7 has less drone than the stock exhaust did and yes, it is painted.:thumbsup:
    No one has ever asked to see my muffler..:rolleyes:
    Good luck Bro..
  18. Jun 24, 2025 at 3:44 PM
    lapoolboy
    Appreciate the detailed response with actual data. Now you can see why the "NO DRONE" statement you made could be misleading to some readers.
    dirtydeeds[QUOTED] likes this.
  19. Jun 24, 2025 at 3:48 PM
    G8Santini
    My drone issue starts with me. Im the one that put on 35” tires that increased the stock tire diameter 2” & completely changed the final gear ratio. So now the tranny shifts are off, the ECU is picking up incorrect data on the speed sensor readings effecting all kinds of things - ie. variable valve timing, etc. So when I tow, my truck configuration is always a bit behind and loading on hills. And even when normal driving around 80mph, when aerodynamic drag starts doubling (welcome to Texas), and you get to 10th speed and converter lockup, 2000-2100rpm is right where the truck drones under a bog. Around town I almost always run in Sport mode just to keep a gear higher to make the truck more responsive, and stay away from the drone. Casey’s muffler is a pretty cool work of art (if you know welding), and it performs exactly as I expected. I really, really like it. The full Tundra TRD performance system is 1/2 as loud at idle, and quiet under cruise with no drone, and yet in comparison it’s twice as loud as a stock muffler. It’s all in what you’re looking for.
    dirtydeeds likes this.
  20. Jun 24, 2025 at 4:01 PM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Mine's also painted and I'm not taking it off to resell. I wouldn't have to resell it anyway if Keith's warranty says I can exchange it for something else if I'm not happy with it.
  21. Jun 24, 2025 at 4:25 PM
    dirtydeeds
    Keith
    USA
    All good. Glad to help. Wasn’t trying to deflect anything, just wanted to make sure I answered your question as accurately as possible.
    as others have pointed out, my system has a lifetime warranty, and that includes sound.
    but with over 100 options, it’s rare I get one back. I just build what they want the first time!! I’ve been building tundra exhaust for over 20 years.
    760-877-4234
  22. Jun 24, 2025 at 4:25 PM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I tried sport mode and it made no difference. Yes I agree his muffler is a work of art. If I don’t have any takers I may mount it to my wall just because it looks cool. I just wish that low rpm on the highway drone wasn’t there.
  23. Jun 24, 2025 at 4:27 PM
    dirtydeeds
    Keith
    USA
    Thanks dude.
    no matter which exhaust a guy ends up getting, it’s highly recommended to paint the system with the exact paint in the can that was posted. The thermal insulation in theory gives better exhaust velocity and therefore better low end torque. Plus; it’s just cool painted black!!
    1lowlife[QUOTED] likes this.
  24. Jun 29, 2025 at 11:26 AM
    G8Santini
    The TRD Performance Exhaust for Gen3 is overall pretty much what I see in these blogs Tundra owners are looking for. Just another exhaust system option, but with Toyota engineering behind it. Watching who drives Gen 3 Tundras my personal perspective is that the majority see a fair bit of family use. Most of any trucks in Texas are suburban warriors going to from work, getting groceries & school. V6 engines are inherently difficult to make sound good. So these louder exhaust systems aren’t much fun when you road trip or tow and listen to drone. No question that the full TRD Perf Exhaust is not Civic VTEC or 350Z Buzzsaw loud. It is louder than stock or TRD Pro systems, has good deep idle, nice growl on acceleration. I can’t get it to drone at all. Just saying it’s another option out there. I like that the SS finish matches the stock look.
