Ready fo new shoes! 285/75/18
Discussion in 'Wheels & Tires' started by ackthresher, Jul 2, 2024.
  1. Jul 13, 2024 at 8:47 AM
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    gotcha.
  2. Jul 13, 2024 at 5:55 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Not 100% correct. Part of an alignment on our trucks involves setting you caster angle. Since our UCAs typically have a fixed location for the top of the spindle, the wheel will move forward or backward in the wheel well as the caster angle is adjusted. This will change the space you have between the tire and body mount behind the tire, as well as the bumper in front.
    Caster plays a big part in fitting bigger tires on our trucks.
  3. Jul 13, 2024 at 9:04 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Hmmm, ok. I’d never screw with castor just to fit bigger tires. Wow.
  4. Jul 13, 2024 at 9:33 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Nor would I, but plenty of people do.
  5. Jul 13, 2024 at 9:43 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I know how to fit 37” tires on a Gen 2 with only slight shaving and bit of work. But no messing with
    castor. Reckon that’s big enough.
  6. Jul 13, 2024 at 10:40 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I don’t know that I’d consider it “screwing with caster”. It’s an adjustment that is checked and manipulated every time a decent alignment is done. You can push the tires forward, resulting in more clearance to the body mount, while remaining within the acceptable range. Or, slide the tires back, maybe need to modify the body mount, and still be within the acceptable range. Just a couple degrees makes a difference here! No change in tire wear or drivability that I can see or feel.
    Terndrerrr likes this.
  7. Jul 13, 2024 at 11:19 PM
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    IMG_5817.jpg 285/75/18 Toyo AT3…..Do it!!!!!!
  8. Jul 14, 2024 at 2:12 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Manipulating caster is super common when trying to fit big tires. All you’re doing is trying to center a much bigger tire in the wheel well with the goal of avoiding rubbing. Usually, this means more positive caster so your sweet beefy tire doesn’t rub on the cab mount. More positive caster is not a big deal.
    I should say, 285/75R18 tires fit on my truck with OEM wheels without any need to tweak caster. Here’s a video explaining how to set positive caster yourself:
    The Dude and Jackstraw like this.
  9. Jul 14, 2024 at 3:43 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Sorry, I come from the solid axle age. Castor is set, and left alone. Now ya got me worried about who to trust if and when I do an alignment.
  10. Jul 14, 2024 at 5:00 PM
    Terndrerrr
    Music City
    6UR-FE
    Yes caster is generally set with SFA and left alone, because to change it you have to either cut/rotate your knuckles or add shims between the springs and the axle.
    But with IFS, it’s as simple as adjusting the cams on your lower control arms. It’s not a big deal at all. If you’re worried, just tell the alignment guy you want as close to stock specs as possible. Again, I didn’t have to increase positive caster to fit 285/75R18s.
    Cruiserpilot[QUOTED] likes this.
  11. Jul 24, 2024 at 10:34 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Got any more photos of the truck with these, especially from the front or rear? I had them prior in 33x12.50r17 and I liked them. I just ordered some more of these Kendas in 285/75r18s for my incoming FN wheels. They seemed like the best combo of height and width I was after while not exceeding 65lbs, a decent price point, and the aggressive tread pattern I was after.
    I was tempted by dueler Revo 3s in 295/70r18s as they somehow manage to be an E load in that size that only weighs 55 lbs, but I didn’t find them attractive enough from a looks perspective.
  12. Jul 24, 2024 at 8:24 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Did you have any fitment issues changing from a 295/70 to the 285/75?
    I have 295/70/18's Nitto's on my 2020
  13. Jul 26, 2024 at 6:05 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
  14. Jul 26, 2024 at 6:08 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    I had to do a little more molding of the front finder liner with the heat gun and had to cut off a little bit of the tabs on the factory skid plate when I went from the 295/70/18 to the 285/75/18. Nothing too crazy for sure.
    Silver17 likes this.
  15. Jul 26, 2024 at 10:34 AM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Not true. Caster can do a lot for clearance.
  16. Jul 26, 2024 at 10:42 AM
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I have the Toyo at3's in 295/70/18 and have been happy with them. A little bit of noise but not bad at all. Removed the front flap thing and trimmed factory front mudflap and no rubbing +18 offset.
    The Dude and BR73 like this.
  17. Jul 26, 2024 at 10:57 AM
    GATORthaBEAST
    GATORthaBEAST New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    What did you do for suspension? I’m looking at going up to 285-75-18 from 275-70-18. I have KO2s right now which have been great but Discount Tire sent me an offer on eBay for $200 off the Toyo OC RT Trails in 285-75-18 which is basically like not paying taxes. I want the bigger tire size but I don’t want to do too much alterations to make em fit. I’m a little over 2” on my 5100s. Your truck looks sick by the way. I also have Method 312s which have a 18+ offset I believe. Could be wrong.
    drobb[QUOTED] and BR73 like this.
  18. Jul 26, 2024 at 4:38 PM
    GATORthaBEAST
    What lift do you have? Or what did you do to your suspension to make the 285-75-18 fit?
    truck looks amazing by the way
    BR73 likes this.
  19. Jul 27, 2024 at 9:31 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    I have the 3/1.5 Toytec Boss lift. Other than that just removing the front mud flap, a little trimming, heat gun, and cut off part of the tabs in the factory skid plate.
    Thank you by the way!!!!
  20. Jul 27, 2024 at 5:46 PM
    #50
    Silver17
    Eastern PA
    My 285/75 Kendas arrived today. Tastefully chunky. I was pleasantly surprised to find they weigh less than Kenda quotes. They say 65 lbs, my 4 tires ranged from 63 lbs. 1 oz. to 64 lbs 2 oz. Luckily the wheels only weigh 23 lbs which helps, and they should be here next week.
    TwistedTad, Terndrerrr and BR73 like this.
  21. Jul 28, 2024 at 6:10 AM
    #51
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Well I finally figured out what's on my 2020 to get lift for these 295/70R 18's
    Thanks to this forum I'm slowly learning
    PXL_20240727_200416876.jpg PXL_20240727_210707693.jpg PXL_20240727_200558983.jpg
  22. Jul 28, 2024 at 8:46 PM
    #52
    drobb
    All I did was 6112s in the front at the top setting. 5100s in the rear with no lift.
    Thanks for the compliment!
    #52
  23. Jul 29, 2024 at 3:54 AM
    #53
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    My truck has the same setup with Coachbuilder shackles and I have 295/70R 18's under it
    drobb[QUOTED] likes this.
  24. Aug 9, 2024 at 3:08 AM
    #54
    ackthresher
    ackthresher [OP] New Member
    Jamie
    2017 cement crew max tundra pro
    Just pulled the trigger on Toyo at3 285/75/18 !Any TPMs advice?thank you!
  25. Jun 22, 2025 at 5:31 PM
    #55
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    So where did you get TPMS from? Yes, I know I'm reviving year old thread, but I'm in the same boat now, trying to fit 285/75/18 on mine.
  26. Jun 22, 2025 at 5:47 PM
    #56
    Silver17
    Eastern PA
    I like using these. Also, never shared pics of my 285/75s mounted up. Here was how it turned out.
  27. Jun 22, 2025 at 6:04 PM
    #57
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I agree the Autel mx sensors are super easy to program. I use them regularly at work and have no problems. You can also get them for @$25 a piece.
    The Dude and Tripleconpanna like this.
  28. Jun 22, 2025 at 7:41 PM
    #58
    skip1980
    skip1980 New Member
    Columbia, Missouri
    I have a extra tpms tool for sale right now. It's an Autel TS408. It will program Autel sensors. Still has plastic on screen, lightly used. $100 plus shipping.
    Lucid Tundra likes this.
