Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Jun 22, 2025 at 7:05 PM
    #751
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Oh really? I had showed a video of it to my mechanic and he didn’t seem worried. His initial thought was that the preload would keep it tight. If I purposely try to hold the gear and spin the inner race I can get some movement, but it’s not that easy or sloppy.
  2. Jun 22, 2025 at 7:12 PM
    #752
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When I was checking the preload it was on pretty tight when I was checking runout and gear pattern. It did pop out with the press but nothing like the rear.
  3. Jun 22, 2025 at 7:17 PM
    #753
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Yes, that will get you the double row ball bearing. The manual indicates it’s not press fit there, just requires a little tappy tap tap.
    bflooks, j_supra, Mdl and 3 others like this.
  4. Jun 22, 2025 at 7:26 PM
    #754
    Silver17
    Eastern PA
    Oh wow well in that case I’m not too worried. Sliding it on it reaches a little resistance in that last inch and then feels like it pushes over a hump and into place with a small amount of force. Might get an OEM roller bearing for the heck of it to try it but I think I could use this one without worrying about it. Thanks for the input guys.
  5. Jun 22, 2025 at 8:02 PM
    #755
    blenton
    blenton New Member
    :rofl::rofl::rofl:
  6. Jun 22, 2025 at 8:06 PM
    #756
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    At first I pressed it out and after that a few hard smacks with a dead blow got it out. The tappy-tap for me usually sends things flying and I have to search...
  7. Jun 25, 2025 at 4:19 PM
    #757
    DbQC
    DbQC New Member
    2009 tundra sr5
  8. Jun 25, 2025 at 4:59 PM
    #758
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @DbQC
    looks a tad deep. How is your carrier backlash? Ring side carrier bearing too tight? Shoot for .007. does have a nice hamburger bun top on drive side...err on a little shallow than too deep to prevent whine.
    Post a pic of the pinion pattern too.
    reywcms likes this.
