new member here
Discussion in 'New Member Introductions' started by HKNAPPS, Jun 22, 2025 at 6:54 PM.
  1. Jun 22, 2025 at 6:54 PM
    HKNAPPS
    HKNAPPS [OP] New Member
    i have a 2010 tundra. the ac light started blinking last week. i replaced the mag clutch relay and still blinking. i replaced the compressor and condenser. went to charge up the system and light still blinking. checked the fuses and the a/c ig fuse was blown. replaced it and it kept blowing. i disconnected the switch by the condensor and when i turned on the ac it did not blow the fuse. i replaced the sensor. i tested the new sensor before i screwed it in and the fuse did not blow. once i screwed it in the fuse blew. i cannot figure this out. i have replaced almost the whole ac system and relays and fuses and it will always blow the fuse. it did this out of the blue. one day the system worked the next day it did not. please help or advise
    thanks
  2. Jun 22, 2025 at 8:00 PM
  3. Jun 23, 2025 at 4:25 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome (again) from LA (Lower Alabama)!
    HKNAPPS[OP] likes this.
