05' FGT DC
Discussion in '1st Gen Tundras (2000-2006)' started by EyeSpyA1stGenTundra, Jun 16, 2025.
  1. Jun 20, 2025 at 10:28 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    I know what you mean
  2. Jun 21, 2025 at 9:03 AM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Know the feeling. I was in the market because I got rid of my 2nd gen and brought a car and then owning a house it was not practical because I was alway borrowing a truck. Wife and I agreed it was time for a new truck, so I started a journey on a newer truck. After searching couldn't find a decent truck. One day after searching I stop by a dealer and asked them if they had any older tundra in stock and they said they had one. I went to look at it and it was my current 1st gen. When I sat in it and saw that Miles was 55k I told my self I would be stupid if I didn't take it. I remember I showed up home with the older truck and my wife was worried I brought an too old of a truck but now she has relized how good Tundra are built. Only repairs I have done is steering rack LBJ UCA and did a lift since I was in there already. Timing belt done she ready for another 100k.
    G_unit3000 and NWPirate like this.
  3. Jun 21, 2025 at 9:45 AM
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 BktSeats
    @KNABORES [post#18] is the gospel on these trucks...
    I went in knowing this and am content w/it.
    Im in now for about $13k , including acquisition [but excluding 'discretionaries' like Re-paint, Audio improvement].
    I knew LBJs & Tbelt-Rad would be absolutes. Then of course, Toyota parts are pricey, but very well made.
    In the end, Im only driving it less that 800mi/mo and primary use was 5500# boat puller; its done that extremely well. If its a DD replacement, youre looking at 13-16mpg- hopefully ur job is close to home.
    If I can do this for 5 years [vs a 60mo. finance of a '20 Tndra], it will average out to less $4k/yr total; 5 yr old well equipped Tundra likely at least $6-7k/yr, not including the initial DP...pick ur poison.
    Oh, one last item about these trucks [very argueable tho], when they do encounter a system failure, theyre a bit simpler to diagnose than newer products. Together w/this living database, Tundras.com, your not likely to be a 'maintenace-prisoner' to a dealership, especially if you have some skills or know of a good-honest indie Toyota mechanic.
  4. Jun 21, 2025 at 9:57 AM
    Excluding insurance and fuel, I’m pretty sure my cost of ownership has averaged out to around $1500 a year for my truck. I spent $16k to purchase and over the last 20 years I’ve spent about $15k on maintenance and mods. Not bad. That’s a monthly truck note on a new one.
    Dustdog, abcinv and G_unit3000 like this.
  5. Jun 21, 2025 at 10:02 AM
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra [OP] New Member
    Eric
    Looking for my future 1st Gen Tundra
    Sounds like a steal to me! Getting a LOT of good feedback here. Thank you all!!!!
  6. Jun 21, 2025 at 7:33 PM
    badass03taco
    i bought my double cab about 4 years ago
    i have not.... well lemme take that back... I did have a hole blow out in a catalytic converter while towing one day. I suspect the cat was nearly stopped up and the heat from towing got the shell so hot the exhaust blew a new way out. I did proactively replace the whole exhaust system with nice new stuff just cause. New cats, cross over pipe, mid pipe and resonator, new muffler and tail pipe.
    Aside from that, i have not had to turn a wrench on my truck other than mods like mild lift, springs, and tires and wheels. I havent had a single electrical gremlin, a suspension part, no oil leaks, no mechanical issues. When i bought it i had to replace about $120 worth of light bulbs that were burnt out but other than that i havent touched it. Aside from the catalytic converter thing its been as reliable as a brand new vehicle with a warranty even though its 20.5 years old.
    I am about 25,000 miles away from doing a timing belt water pump ball joints and all that stuff on it which is going to be a maintenance thing, aside from that i havent had to spend much of anything on it other than gas and oil changes.
    Timing belt has about 75,000 miles on it, 9 years old, looks practically brand new.
    Has the recall ball joints, they are solid, zero slack, dont need to replace but going to anyway when i do the timing belt
    Interior is mint, freakin 10/10 for a 20 year old truck
    Gotta polish it with Wizards Shine Master every other year to keep it shiny, the white will oxidize on you and fade bad.
  7. Jun 21, 2025 at 7:45 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    I have a feeling that fewer of the 2025 Tundras will make it to 2045 than 2005 Tundras made it to 2025.
  8. Jun 22, 2025 at 5:15 PM
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    A lot of those 2025s arent making it out of 2025
