Bed Organization ideas (pic heavy)
Discussion in '3rd Gen Tundras (2022+)' started by ThePolak, Apr 4, 2022.
  1. Apr 30, 2025 at 10:49 AM
    #91
    !Marauder
    !Marauder New Member
    2019 white tundra
  2. Jun 17, 2025 at 11:07 AM
    #92
    AF555
    AF555 New Member
    Michael
    2025 Tundra 1794 - Smoked Mesquite
    @astrength22
    Probably going to be stealing your idea :) Did you use any special kind of screws for joining the 2 pieces of trex together with the straps on the back (bedliner) side? First time I'd be working with trex, so not sure if I can use regular wood screws etc. THANKS!
    astrength22[QUOTED] likes this.
  3. Jun 17, 2025 at 11:28 AM
    #93
    astrength22
    astrength22 New Member
    2023 Silver Tundra Platinum
    Steal away! Isn't that what this thread is for? lol
    I just used deck screws. If I remember right, the Trex is ~1" thick- but you can see it has grooves/channels on the back side, so I made sure the holes I chose for screws in the straps lined up away from the channels, so I'd hit the full 1" thickness. I used 1" screws, but after the thickness of the strap and a washer or two, they did not poke through the front side.
    If you can find solid Trex without channels/notches- may be easier, but would add weight.
    I also cut the straps to length with my angle grinder- couldn't find any 11" exactly.
    A few months later- it's holding up well- no warping and keeps my golf clubs from flying to the front of the bed
    AF555[QUOTED] likes this.
  4. Jun 17, 2025 at 11:31 AM
    #94
    AF555
    AF555 New Member
    Michael
    Awesome - thanks for the quick reply and help! Should be attempting this later this week/weekend! Many thanks again for the guidance!
    astrength22 likes this.
  5. Jun 17, 2025 at 11:48 AM
    #95
    astrength22
  6. Jun 17, 2025 at 11:50 AM
    #96
    AF555
    AF555 New Member
    Michael
  7. Jun 17, 2025 at 12:04 PM
    #97
    astrength22
  8. Jun 19, 2025 at 2:42 PM
    #98
    AF555
    AF555 New Member
    Michael
    Had some time today and based this off the divider created by @astrength22. Since I have the bedrug installed, I just measured (60.5") and cut the Trex boards straight. Went with the "Saddle" colored Trex as it matches the 1794 interior really well! There is a little bit of play in movement but I think it'll be ok. Already went and got some groceries to test it out and it did just fine. The octopus hooks are a bit too low and probably won't be used too much, but they look good. I'll be adding some Toyota badging courtesy of my 3D printer and a couple of kayak handles (being delivered today) and that should be all I need. Thanks again for the inspiration and idea @astrength22.
  9. Jun 21, 2025 at 7:00 AM
    #99
    CHESSIEMAN
    CHESSIEMAN New Member
    STEVE
    PA
    2025 ICE CAP RALLY CREWMAX
    Recycled my old bedrug. Wrapped up a 2x12 board.PXL_20250621_130754972.RAW-01.COVER.jpg
