How high can you stack a pile of chit?
Discussion in 'Outdoors' started by Half Assed, Jun 1, 2025.
  1. Jun 15, 2025 at 5:02 PM
    #121
    Half Assed
    Half Assed [OP] me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Well i almost finished before it started pouring rain.
    Some 1" sch40 sprinkler pipe out of a dumpster and some angle iron. I built some steps with the tie down at the end of it. I want to add some gussets but it might have to wait until after next weekend's camping trip.
  2. Jun 16, 2025 at 6:08 PM
    #122
    Half Assed
    Heartland Florida
  3. Jun 16, 2025 at 6:09 PM
    #123
    Half Assed
    Heartland Florida
    Got the Firestone airbags installed tonight
  4. Jun 19, 2025 at 8:31 PM
    #124
    Half Assed
    Heartland Florida
    Installed an Amazon special sway bar and sheeted the sleeping area.
  5. Jun 19, 2025 at 8:34 PM
    #125
    Half Assed
    Heartland Florida
    Camper is currently loaded in the truck for a weekend trip about 3.5hrs away. :fingerscrossed:
    BlackNBlu, j-utah, mrmahi and 4 others like this.
  6. Jun 19, 2025 at 8:39 PM
    #126
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  7. Jun 20, 2025 at 4:13 PM
    #127
    Half Assed
    Heartland Florida
    On the road. Lost my outside cover for the fridge already lol. I forgot to check that.
  8. Jun 20, 2025 at 5:20 PM
    #128
    rmiller139
    rmiller139 New Member
    2011 Tundra DC
    Eibach 2R kit w/ Icon UCA BAK revolver
  9. Jun 20, 2025 at 6:19 PM
    #129
    Blue Thunder
    Washington
    What color are your knuckles?
  10. Jun 20, 2025 at 6:23 PM
    #130
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Holy McFuck.
    Yota303, BlackNBlu, Outbound and 8 others like this.
  11. Jun 20, 2025 at 6:24 PM
    #131
    Azblue
    The Dirty T ( ^_^)_且
    BlackNBlu, hagrid, OldGuy03 and 2 others like this.
  12. Jun 20, 2025 at 7:54 PM
    #132
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Looks like truck is buckling under the weight
    Willard and Blue Thunder like this.
  13. Jun 21, 2025 at 5:19 PM
    #133
    Half Assed
    Heartland Florida
    Drove a lot better than when i brought it home.
    I think the driver's side bag might be leaking. It's sagging on that side. I tried to pump it up but my milwaukee pump with a thread on air chuck lets out all the air i try to put in so i need to find a solution for that. Possibly a 1 gallon air tank?
    Went tubing down Rainbow River today. Had a good time. Heading back tomorrow. :D
  14. Jun 21, 2025 at 6:41 PM
    #134
    Petro
    Petro New Member
    2019 Tundra SR5 TRD OR Crewmax
    This thread is awesome.
    j-utah and Sirfive like this.
  15. Jun 21, 2025 at 6:49 PM
    #135
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Awesome job :bowdown: ... one reason I plumbed my airbags together to prevent asymmetrical loading if one fails. But that's towing a travel trailer.
    BlackNBlu and j-utah like this.
  16. Jun 21, 2025 at 7:05 PM
    #136
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Clean Setup
  17. Jun 21, 2025 at 8:32 PM
    #137
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    i dont want you to take this the wrong way, i say this with full respect.
    but i’ve never been so jealous of hammered dogshit.
  18. Jun 22, 2025 at 6:19 PM
    #138
    Half Assed
    Heartland Florida
    This is my first experience with airbags. I need to figure out if it is actually leaking or maybe it's just heavier on that side.
    I'd prefer to have a heavy duty leaf pack instead of bags, but it's too late to make changes now. Leaving town in a week and a half.
    Function over form my man. People worry too much about the way things look.
  19. Jun 22, 2025 at 6:25 PM
    #139
    Half Assed
    Heartland Florida
    Made it home. Stopped at the Don Garlits drag racing museum on the way home which was pretty neat. It's right off I75 in Ocala if anybody is interested in that kinda stuff. Went looking for the refridgerator vent cover that i lost leaving town on friday but was unsuccessful...
    It made it 400 miles so i guess it's ready for a 7500 mile trip lmao.
    BlackNBlu, j-utah, MS22 and 4 others like this.
  20. Jun 22, 2025 at 6:53 PM
    #140
    blenton
    blenton New Member
    I use these quick clip on air chucks on my m18 inflators. Mine are the older style but they work perfectly. I had the exact same issue airing up my bags and would always have to overinflated them and hope they kept enough air when removing the screw chuck.
    I also plumbed my bags independently. With the fuel tank, driver, brakes, and battery on one side, I always run a few more pounds in the left bag to level out the lean. Also, if plumbed together, air transfers from one bag to the other on corners, essentially deleting spring rate from the bag with more weight. This can cause excessive lean, whereas bags plumbed independently combat lean and increase spring rate on the loaded corner as the suspension compresses - EXACTLY what you want to happen when hauling heavy.
    https://a.co/d/8WzFOc4
    If you have a leak, more often than not, it’s a rough/not straight cut hose at one of the press to connect fittings. I’m sure you know hot to find a leak with soapy water. You can get a cheap airline hose cutter for a few bucks, or use a slow, purposely sawing motion with a new razor blade. I used the latter method on my Ride Rites 8+ years ago and have never had a leak. I’ve even unhooked them from the fittings a few times and still no leaks.
    IMO, the Firestone kit is the best airbag kit for our vehicles.
    BlackNBlu, OldGuy03 and KNABORES like this.
  21. Jun 22, 2025 at 7:42 PM
    #141
    Half Assed
    Heartland Florida
    Thanks for the info. A quick release air chuck is what I need. I will check for leaks tomorrow.
    blenton[QUOTED] likes this.
  22. Jun 27, 2025 at 1:08 PM
    #142
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I saw this about a year ago and I so tried to make it work on the FGT, but it would not
  23. Jun 29, 2025 at 11:46 AM
    #143
    Half Assed
    Heartland Florida
    Modified my milwaukee inflator to be quick disconnect so i can properly inflate my airbags.
    Also built a new refridgerator vent cover.
  24. Jun 29, 2025 at 12:04 PM
    #144
    Half Assed
    Heartland Florida
    One of the reasons I wanted to replace the wheel bearings was that the carrier pin broke and had been rattling around in the diff for a while. I replaced the diff a few months ago. That, the mileage, and the payload for this trip I figured they could be a problem.
    Metal shavings from the diff grinding.
    New SKF bearings going on. What a pain in the ass. Unnecessarily complicated IMO.
    Hope i can reuse the retainers because i didnt do enough research to buy new ones. I did buy new axle seals though.
    New brakes, replaced the calipers since the passenger side was sticking a couple years ago and I just greased it at the time. New hoses.
    I also put a newer spare under the truck. It had what I assume is the original dated 0307. Did tundras have Michelins? I thought they were all getting Bridgestones from the factory during that time at least.
  25. Jul 6, 2025 at 6:09 PM
    #145
    Half Assed
    Heartland Florida
    Left thursday night for two weeks. Currently in PA.
    Pic from the blue ridge parkway near Sylva, NC.
  26. Jul 6, 2025 at 6:17 PM
    #146
    Half Assed
    Heartland Florida
    Scaled out at 9140. :homer: If that's correct, the camper and cargo weighs about 3300 loaded which is friggin' crazy. Next time i'm at a truck stop with an open scale i want to double check that number.
  27. Jul 6, 2025 at 8:01 PM
    #147
    Willard
    Willard New Member
    2024 F250
    Isn’t gvwr on your truck only ~7000 lb? :eek2:
  28. Jul 6, 2025 at 8:09 PM
    #148
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    If your brakes feel good, then as far as gross weight I would be more concerned about how your steering feels, and along those lines you could add some weight by strapping something to the bumper to weigh the front end down. If needed.
  29. Jul 6, 2025 at 8:37 PM
    #149
    I wouldn’t be adding weight anywhere to that truck. 9100# is danger zone already
  30. Jul 6, 2025 at 8:39 PM
    #150
    Retroboy1989
    Northern Utah
    o_O
