General Supercharger Thread
  1. Jun 19, 2025 at 4:10 PM
    centex
    centex New Member
    Just like every other engine.
  2. Jun 19, 2025 at 4:47 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'll use the Lucas Dyno I ordered & change it in 500, I'll stay out of boost & under a zillion RPMs & hopefully live happily ever after....
    HulkSmurf14, Wynnded and mustang67408 like this.
  3. Jun 19, 2025 at 5:29 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Engine break-in procedure, the new gear break-in debate. Lol
  4. Jun 19, 2025 at 5:49 PM
    e30cabrio
    I'm not debating, I want to do it properly so I don't fuck up another motor. I'm well over my limit.
  5. Jun 19, 2025 at 6:06 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Over all of our limits!
    *we feel for you! Keep positive!
  6. Jun 19, 2025 at 6:27 PM
    e30cabrio
    Sure, sure.
    bflooks and HulkSmurf14[QUOTED] like this.
  7. Jun 19, 2025 at 7:32 PM
    bflooks
    bflooks New Member
    Metrowest MA
    My fingers are crossed this one gets you fixed up correctly. I feel like that latest junkyard motor you had for the tree was hurt from the very beginning and the fact it last as long as it did was more of an accomplishment than a failure.
    e30cabrio and HulkSmurf14 like this.
  8. Jun 20, 2025 at 5:54 AM
    e30cabrio
    Thanks!
  9. Jun 20, 2025 at 6:35 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Any new additions to the Day 1/install time additions? i got my whipple tracking but it hasn't moved from "label created"
    I think the last thing that we came up with was a catch can and a wideband. I did end up getting HP Tuners and credits, but will probably just try out the whipple tune until i reach out to our local Mad Scientist.
    A while back i there was talk of heat blankets and spacers.....
    HulkSmurf14 likes this.
  10. Jun 20, 2025 at 6:42 AM
    bflooks
    bflooks New Member
    Metrowest MA
    smart man leveraging all of the talk in here and asking before install. "while you're/they're in there" is a very real motivator.
    i think the answers will be YES to the heat mat and TBD on the spacers. it's probably also a good time to consider doing the Hewitt bypass kit if that has ever crossed your mind.
    just an outsider's .02
    HulkSmurf14 and mustang67408 like this.
  11. Jun 20, 2025 at 6:43 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes, wideband is paramount and you can do it without the blower, so if you already have it I would just install it now while you wait for the Whipple.
  12. Jun 20, 2025 at 7:20 AM
    Danimal86
    Daniel
    Sacramento, CA
    Anyone have the heat mat link handy so i dont have to dig through all the pages?
    I'll have to look at the Hewitt kit, its never come across my radar. Seems like might not be necessary unless i have those CEL codes? I'm in the worst state for emissions (TBD, heard rumors of that might change, but doubtfull), so i don't want to mess with too much emissions related stuff.
    I really should go and install that wideband....i've got everything i need to do it, just seems like a pain...even though its only a few bolts and then taking it to a shop to weld the sensor.
  13. Jun 20, 2025 at 7:25 AM
    snivilous
    SW UT
    Oh it is an absolute pain, pulling wires, tapping into power, installing the sensors, it's a half day task itself. Good luck! :D
  14. Jun 20, 2025 at 8:18 AM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Make sure you grab some extra exhaust gaskets too, mine were toast when pulling everything apart.
  15. Jun 20, 2025 at 8:19 AM
    Danimal86
    Daniel
    Sacramento, CA
    Good call, i didn't think about that.
  16. Jun 20, 2025 at 8:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    My back and shoulders hurt just thinking about it......it just went from a "maybe i'll tackle it this weekend", to a "we'll see".
    I'm still undecided on my gauge mount. I have the vent pod gauge mount currently but it being summer, it feels wrong to loose a bunch of airflow.
    Only other option i really know of is the steering column mount. I'd like to keep it as stealthy as possible.
    I wish there was just a small display i could tuck besides the cluster gauges or be able to have it displayed on my head unit like the other gauges. I wonder if anyone has torn apart one of the Innovate gauges.
  17. Jun 20, 2025 at 8:33 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  18. Jun 20, 2025 at 8:34 AM
    snivilous
    SW UT
    If you want to be a test case I could cut out another knee mount gauge pod, even though I said I'd do this months ago, maybe I would finally do it again :rofl:
  19. Jun 20, 2025 at 8:40 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  20. Jun 20, 2025 at 9:06 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    That looks so clean :thumbsup:...I think I'm going to move my gauges now...:spending:
  21. Jun 20, 2025 at 9:19 AM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
  22. Jun 20, 2025 at 9:37 AM
    mustang67408
    Victor
    Never been fond of this. The way I have it
    I really like the way @reywcms has his....will be updating soon
  23. Jun 20, 2025 at 10:01 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Those gauge pods on the old man’s tundra mines this on the wheel which I like but both work well.
  24. Jun 20, 2025 at 10:02 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    I would like one please!
  25. Jun 20, 2025 at 10:16 AM
    centex
    centex New Member
    e30cabrio and mustang67408 like this.
  26. Jun 20, 2025 at 10:21 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Yeah...when we used to go to the beach in our younger years in Texas you'd see people running across the asphalt parking lot to buy beer and ice.
    Only to find blisters on the bottom of their feet afterwards.
    It only took one time to teach them to invest in some Flip Flops....
    mustang67408[QUOTED] likes this.
  27. Jun 20, 2025 at 10:48 AM
    ssmokedz
    Shelton CT
    She's a beaut Clark!
  28. Jun 20, 2025 at 10:48 AM
    e30cabrio
    I like mine on the steering mount, like Rey's Dad.
    https://vimeo.com/1079198159
    Also,
    Amazon finds new & inventive ways to annoy daily!!!
    I ordered 2 gallons of coolant in the order for oil, Trans fluid & coolant for delivery today.
    They seem to have split the two gallons up.
    mustang67408 and HulkSmurf14 like this.
  29. Jun 20, 2025 at 11:42 AM
    centex
    centex New Member
    Rockauto and Walmart do that to me all the time. Most irritating thing ever.
  30. Jun 20, 2025 at 12:51 PM
    e30cabrio
    Yup, 1 gallon.
    The other has not even shipped. WTF??
    Mdl likes this.
