2003 v6 manual bell housing
Discussion in '1st Gen Tundras (2000-2006)' started by KD808, Jun 18, 2025.
  1. Jun 18, 2025 at 5:52 PM
    KD808
    KD808 [OP] New Member
    2003 Tundra V6 2wd 5speed
    Hi, sorry if this isn’t allowed on here please lmk and I’ll delete it…..
    im looking for a bell housing for 2003 Tundra v6 manual. Mines cracked where the line coming from the slave cylinder entering the bell housing is. The line moves around and I think it’s where the pivot ball mounts to maybe. Idk. I’m looking to buy a bell housing shipped to me in Hawaii. Thanks in advance.
  2. Jun 18, 2025 at 5:57 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Welcome, try car-part.com maybe
    KD808[OP] likes this.
  3. Jun 18, 2025 at 5:58 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Have you checked the local junkyards?
    might be the same as a v6 manual taco or 4runner.
  4. Jun 18, 2025 at 6:31 PM
    KD808
    yea local junkyards have all automatics.
  5. Jun 18, 2025 at 6:36 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Find someone to make an adapter & clutch for a 6 speed swap. & ask if they’d make a 2uz clutch & bellhousing set.
    The Black Mamba and KD808[OP] like this.
  6. Jun 18, 2025 at 6:43 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Any chance it can be repaired by a good welder. I have a guy here in SoCal, and he has amazing skills. Given the scarcity of manuals it might be your best bet.
    tvpierce and KD808[OP] like this.
  7. Jun 18, 2025 at 6:49 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, taco’d a zx6r wheel & had a dude bend it back with heat & a hammer & a bottle jack, then weld the cracks. I left most of the wheel black, but polished that weld out & put it in a 485* oven for a couple hours. Still perfect after 15 years.
    shifty` and KD808[OP] like this.
  8. Jun 19, 2025 at 9:14 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Have you checked OEM?
    Clutch Housing #31111-35090 | Autoparts.toyota.com
    Also. you can search that part number on fleabay and such
    KD808[QUOTED][OP] likes this.
