Console lock safe
Discussion in '3rd Gen Tundras (2022+)' started by JaxTex, Jun 18, 2025.
  1. Jun 18, 2025 at 9:53 AM
    JaxTex
    JaxTex [OP] New Member
    2023 White Tunda SR5 Off Road
    Please if I’m wrong just tell me. I bought my 2023 Tundra from a local pretty large dealership and it went fine but my biggest gripe is that safe in the console has no access. The dealer has no key, no code and only asked to remove the safe instead of replacing the lock. This is kinda fresh so sorry for the ranting. I’ve reached out to the manufacturer of the safe but didn’t think I should be responsible for the cost. Any input is greatly appreciated. Thanks
  2. Jun 18, 2025 at 10:02 AM
    lapoolboy
    lapoolboy New Member
    They can't remove it if they can't open it. At least not without destroying your truck in the process.
    Can the dealer call the previous owner? Sometimes the easiest solution is the best.
  3. Jun 18, 2025 at 10:04 AM
    JaxTex
    Can the lock not be drilled out and replaced? Never had one before but it seems lightweight enough to do so.
  4. Jun 18, 2025 at 10:54 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    Have you tried the factory code of all zero's? If that doesn't work a locksmith can take care of it.
  5. Jun 18, 2025 at 11:25 AM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    Is the console safe the factory Toyota safe? I had the same problem with mine. Came with the safe and it was open, but they did not have the key to override. If the safe is open you can hold in the pin on the end and set a new 3 digit code and release and it will change the combination.
    This is the factory console safe:
    https://www.amazon.com/Genuine-Toyo...34220/dp/B09P4B1D1M?smid=A1010H8RP0QWSN&gQT=2
    If you can get it open (drill it out) you can buy a new lock on Amazon. That's what I did.
    Here is the lock for the Toyota factory Safe.
    https://www.amazon.com/dp/B0DTKWV61M?th=1
  6. Jun 18, 2025 at 12:06 PM
    watacivic
    watacivic New Member
    i found my safe keys in the glove compartment.
    75tranzam likes this.
  7. Jun 18, 2025 at 12:13 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    The dealer can find a phone number to call in the instructions for the console safe.. I will see if I can dig it up for you
    That was easy....try 1-800-878-1369
  8. Jun 18, 2025 at 12:21 PM
    JaxTex
    Thanks for the help guys. I ended up having the locksmith open it for 40$. Up just order a new lock and install it. The dealership had no desire to help me. The safe wasn’t a Toyota safe and there wasn’t any markings on it.
  9. Jun 20, 2025 at 8:30 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    I'd find another dealer if they sold you a truck with this in it and didn't want to help you out. Thanks for your money, let me show you to the door.
    pursuit2550 likes this.
