Is this the remains of an LSD sticker?
Discussion in '1st Gen Tundras (2000-2006)' started by poormxdad, Jun 18, 2025.
  1. Jun 18, 2025 at 9:08 AM
    poormxdad
    poormxdad [OP] New Member
    2012 Tundra Grade Four Door 4.6 4WD/ 2007 Sequoia SR5 Leather
    Gents,
    I'm trying to determine if I have an LSD on my '07 2WD Sequoia. Factory tow package and 17 inch wheel option.
    Is that the remains of the LSD sticker I've seen in other threads? Sorry about the crappy pic.
    Thanks,
  2. Jun 18, 2025 at 9:13 AM
    LSD stickers are typically oriented vertically, above the fill plug IIRC on the Tundra. Not sure on Sequoia.
    Hi06silver likes this.
  3. Jun 18, 2025 at 9:30 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I think if you create a Toyota login it'll give you some insight to the specs of your rig from factory.
    Click here to create a login and see anything that was done to your rig at a dealer before you owned it. The other way to tell is take a peak in the bunghole
    shifty` likes this.
  4. Jun 18, 2025 at 9:39 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  5. Jun 18, 2025 at 12:24 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  6. Jun 18, 2025 at 1:09 PM
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    I had a few LSD stamps back in the day, dont remember how they looked
  7. Jun 18, 2025 at 1:16 PM
    Colors. Lots of colors. Especially when you drop 10-strips at a time.
    Nimitz_, bfunke and Hi06silver like this.
  8. Jun 18, 2025 at 1:44 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    After a couple, I wouldn’t care but made Stairway to Heaven sound better :facepalm:
  9. Jun 18, 2025 at 2:01 PM
    poormxdad
    Gents,
    I went to the Toyota site, created a login, and downloaded my info a couple of weeks ago. It didn't tell me the square root of eff all. It never mentioned the factory tow package, aluminum 17" wheels, and it even said I had fabric interior. It's leather.
    I can clearly see the outline of whatever that sticker on the diff is. Could someone please pass me the length and width of an intact sticker. I'll assume that's what it is if the measurements match.
    Thanks,
    I'm trying to figure out what gear oil to use...
  10. Jun 18, 2025 at 2:12 PM
    Just put Lucas 80w90 in the rear diff and move right along. Problem solved.
    If you REALLY need to have synthetic, either the Valvoline FlexFill bags or Amsoil Sever Gear will work for LSD, supposedly, with no chatter. If not, just use the Lucas. It works, universally, and is a no brainer.
    The Black Mamba and Hi06silver like this.
  11. Jun 18, 2025 at 2:15 PM
    PS: here is the normal location, shape/size of the LAD sticker I’ve seen for the Tundras: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-2360#post-3930678
    Compare the width of the sticker to the width of the drain bolt for reference on size. But if you really want to know, since sometimes rear-ends do blow up and get internals replaced, you’ve been given above two practical ways to figure out, visually, with very little effort, how to know if you have LSD. The video method above is the “classic” way to tell.
  12. Jun 18, 2025 at 2:23 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  13. Jun 18, 2025 at 2:24 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Also, if you’ll read the link that I posted earlier, you’ll see whether you have LSD or not when you pull the drain plug
    Edit: I think the term is bunghole
  14. Jun 19, 2025 at 5:29 AM
    bfunke
    bfunke Tundra Curmudgeon
    Every one I’ve ever seen is like this
  15. Jun 19, 2025 at 5:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    What is/was the horizontal sticker behind the parking brake cable?
  16. Jun 19, 2025 at 3:00 PM
    poormxdad
    Sooooooooooooooooooooooooooooooooooooooooooooooooooo, it is likely the remnants of the sticker I have are not those of an LSD equipped Sequoia. No problemo. It would be nice to know what that sticker was.
    Thanks much,
  17. Jun 19, 2025 at 3:10 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  18. Jun 28, 2025 at 2:52 PM
    poormxdad
    I finally got a chance to look inside the bunghole. I saw gear teeth, dammit.
    Given what I've read, including the ECGS article, it appears I should buy a gallon of Lucas 85W-140 dino oil. Is that correct? My owner's manual says 75W-140 synthetic, but makes no mention of an LSD. I'm in southeast Virginia.
    BTW, I dropped the spare to make it easier to get at everything and the build date on the tire is 0406...
  19. Jun 28, 2025 at 6:51 PM
    Lucas 80w90 is plenty fine for any rear-end in our trucks.
  20. Jun 28, 2025 at 7:13 PM
    Dustdog
    Dustdog New Member
    01, 05 AC 4wd
    stockers
    I had the same experience with that site. Something must have changed recently..
