First time Toyota owner.. gem or rust bucket?
Discussion in 'New Member Introductions' started by Leojin, Jun 17, 2025.
  1. Jun 17, 2025 at 7:46 PM
    Leojin
    Leojin [OP] New Member
    Illinois
    2004 Tundra Limited DC 4x4 4.7L V8
    Here she is.. 2004 Tundra Limited 4.7L V8. 159k with frame rust, doesn’t seem to have gone too much further than surface scale. No lights on the dash.IMG_5924.jpg IMG_5929.jpg IMG_5917.jpg IMG_5915.jpg IMG_5921.jpg IMG_5914.jpg
    Tacoma-Tundra and Sean492 like this.
  2. Jun 17, 2025 at 8:02 PM
    Not enough pics of the right places to really get a bead on the rust situation, but it’s heavy scale on the suspension bits up front and outer frame rails. That usually equals trouble for the inner rear frame braces at the overlaps and X brace over spare. Front frame boxed sections are areas of concern as well. Rear axles are hit or miss as they sometimes get hosed down periodically by owners since it’s visible. But rear axle diff “cover” is the thinnest metal portion and is a problem area as well.
    Leojin[OP] likes this.
  3. Jun 17, 2025 at 8:12 PM
    Welcome from NY.
  4. Jun 18, 2025 at 4:29 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Jun 18, 2025 at 6:30 AM
    Leojin
    Illinois
    I will update in the next day or two with some better angles, I was trying to snap a few quick before it started raining. I have been reading a lot of threads dealing with frames and recall.
  6. Jun 22, 2025 at 12:26 AM
    Tacoma-Tundra
    Tacoma-Tundra New Member
    Tony
    06 Tundra SR5 LTD DC 4.7 V8 AT 2WD
    Welcome from NC :hattip:sounds like your to-do list is manageable; keep us posted
  7. Jun 22, 2025 at 1:58 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Congratulations and welcome from the Rust Belt, Pa..
  8. Jun 23, 2025 at 8:15 PM
    Leojin
    Illinois
    Went to start knocking the scale off the frame before wire brushing and got a nasty surprise. What looks like good metal is actually just a spray coating. It rusted from the inside out. I pulled back the spray layer and just kept picking until I went all the way through. Not sure if I’ll need a frame swap or if it can be repaired..
