What is the part number for the skid plate bolts? 2006 DC V8
Discussion in '1st Gen Tundras (2000-2006)' started by Bought2Pull, Jun 17, 2025.
  1. Jun 17, 2025 at 12:09 PM
    Bought2Pull
    Bought2Pull [OP] New Member
    Greg
    WV
    2006 Tundra 4 door
    I hate to ask but I tried the "search" function first and just no luck.
    Someone has replaced the 6 skid plate bolts with some zinc plated bolts. They fit well-enough but I'm trying to keep my truck as OEM as I can.
    This is for the plate that protects the oil pan and filter.
    I thought I saved the link someone posted to this same question but I guess not. Thanks!
  2. Jun 17, 2025 at 12:35 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  3. Jun 17, 2025 at 12:40 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    thanks man!
    BubbaW likes this.
  4. Jun 17, 2025 at 2:49 PM
    bfunke
    bfunke Tundra Curmudgeon
    If your threads in the frame are somewhat buggered from that grease monkey and his impact, get an M8x1.25 thread chaser to clean them up before you put new bolts in.
  5. Jun 17, 2025 at 3:33 PM
  6. Jun 17, 2025 at 4:12 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Exactly what I did with mine. Part number for bolt on mine was also 90080-11373. The tip of the OEM part is tapered and chamfered somewhat which makes them easier to line up the hole in the skidplate with the frame you are attaching it to.
  7. Jun 17, 2025 at 6:41 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I wouldn't be surprised if that was the case. I don't know who that couple had working on their truck but if he was anything like who they had mowing their yard (before
    That's a good idea, thank you. :)
  8. Jun 17, 2025 at 7:08 PM
    Fragman
    Fragman New Member
    Just to clarify, use a chaser, NOT a tap. Different tools for different purposes.
  9. Jun 17, 2025 at 7:55 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Like in this video? :) Thanks. I appreciate the concern that I may not be familiar....which I wasn't but I'd have asked for what was suggested, "a thread chaser" but you didn't know that and you cared enough to be more clear. :) :)
    Why Your Shop Needs a Thread Chaser Kit
  10. Jun 17, 2025 at 9:00 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    This post made me giggle because I'm currently missing one of my skid plate bolts and two others are held on with zipties
    Bought2Pull[OP] likes this.
  11. Jun 17, 2025 at 9:01 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    If you need to chase the holes just use a tap, cheaper and more readily available, and useful for other things.
  12. Jun 18, 2025 at 7:49 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    That's what my dad would say. :p
    I ordered a Lang chasing kit from Zoro last night after reading replies here. I had a 20% off coupon anyway. Want to try and replace those bolts next oil change which should be due next month. Putting a lot of miles on the truck.
  13. Jun 18, 2025 at 8:01 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    I wouldn't necessarily worry about springing for OEM bolts on this once you get it cleaned up. As long as you get at least a Grade 5 M8 x 1.25 bolt from a local hardware store, you'll be good to go. Tractor supply sells Grade 5 metric bolts by the 2/4 pack. Autozone and Oreilly's also sell Grade 8 metric bolts by the 4 pack, but you don't need to get stronger bolts unless you absolutely want to.
    Pretty much all fasteners you'll encounter on the truck will be metric fasteners. They're sold in the M6-1.00x30 format
    M is metric thread designation
    6 is the thread diameter in MM
    1.00 is the thread pitch in MM
    30 is the length of the bolt in MM
    Thread pitch measures distance between threads. Pitch can vary depending on thread size. Thread pitch will also tell you how many threads per inch there are. A bolt with a 1.00mm pitch will have 25.4 threads per inch, and a 1.25mm pitch will have 20.32 threads per inch.
    Fasteners can also be graded depending on their strength. Most stuff on the truck will be Metric Class 8.8 or less, but there's no harm in using Metric Class 10.9 (commonly referred to as Grade 8)
    Further reading: https://www.fastenermart.com/understanding-metric-fasteners.html
    Thread strength: https://www.fastenermart.com/understanding-fastener-grades-and-classes.html
    G_unit3000, shifty` and Kimosabe like this.
  14. Jun 18, 2025 at 8:08 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    @Bought2Pull obviously you do you, but just get one of the metric bolt assortments from O'reilly or wherever and be done with it. That way you have some spare nuts and bolts on hand. No one will judge you for non-oem skid plate bolts. LBJ and crank bolts are a different story.
    Bought2Pull[OP] and des2mtn like this.
  15. Jun 18, 2025 at 8:10 AM
    I just like the little self-guiding nipple on the OEM bolts. Makes it easier to install.
    des2mtn and Fragman like this.
  16. Jun 18, 2025 at 8:15 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    To each; their own. I like that the bolts are shiny.
    shifty`[QUOTED] likes this.
  17. Jun 18, 2025 at 11:43 AM
    bfunke
    Toyota fasteners don’t stay shiny long. Their corrosion control sucks on both frames and fasteners.
    des2mtn and shifty` like this.
  18. Jun 18, 2025 at 12:36 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I get the shiny ones from o’reillys.
    Like this
  19. Jun 22, 2025 at 6:45 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Thanks man, I appreciate the advice. And no need for a "you do you" preface.....I like advice and WISH that people that knew stuff had given me more advice because they cared about my welfare, not because I asked for it. :)
    Been pretty crazy with mowing last few days but came to catch up on some posts.
    Kimosabe[QUOTED] likes this.
