headlight bulb location problem
Discussion in 'New Member Introductions' started by zer0, Jun 14, 2025.
  1. Jun 14, 2025 at 6:34 PM
    zer0
    zer0 [OP] New Member
    2014? tundra
    bed slide, topper
    Anyone experience a problem replacing headlight bulbs on 2014-2021 Tundras?
    I drive and maintain a 2014 Tundra. The only way I see to replace the headlight bulbs is to remove the grill, bumper cover and lens so to allow access to the bulbs. Is there a way to replace these bulbs without removing these body parts? And does anyone know of an aftermarket lens assembly with an accessible bulb location different than the oe if there is no other way? Why did Toyota change the headlight/hood/grill assembly in 2014? Had it not changed It would be simpler!
    I would graciously appreciate any advice.
    rear view image of aftermarket headlight assembly for 2014 -2021 Tundra by Formlights FORM Lighting 2014-2021 Tundra LED Projector Headlights
  2. Jun 14, 2025 at 7:00 PM
    vmkeith
    vmkeith New Member
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining bedliner Rydonair 7" antenna 275/70/18 Pirelli Scorpion A/T tires Lund 5" Cab Length Oval Curved Tube Steps RealTruck Elevate FS Bed Rack Rhino-Rack Carriers RealTruck TruXedo Pro X15 Tonneau Cover Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs
    No other option but to remove the grill, bumper cover, and lens because there is a protective rubber boot that has to be removed to access the retaining clip that holds the bulb in place. Haven't looked at aftermarket headlight assemblies, don't really see the point of that.
    zer0[QUOTED][OP] likes this.
  3. Jun 14, 2025 at 7:35 PM
    zer0
    2014? tundra
    bed slide, topper
    Thank you for your quick response.
  4. Jun 15, 2025 at 5:32 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Stick around and join the conversations!
  5. Jun 15, 2025 at 6:07 AM
    Welcome from NY.
  6. Jun 15, 2025 at 9:06 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Actually, the manual says to change headlight bulbs from the fender well, but we know that it is nearly impossible.
    upload_2025-6-15_10-54-38.pngupload_2025-6-15_10-54-50.pngupload_2025-6-15_10-55-6.png
    I do agree that the best way is simply to remove the grille.
    It only takes 10 minutes after doing it a few times.
    https://youtu.be/ROHlnvOnH0A?si=8RWjiPYZVirLFg7Q&t=15
    Welcome to the forum @zer0
    You can find your manual here if you don't have one;
    Toyota Manuals and Warranties | Toyota Owners
    If you need to replace one headlight, parking light, or turn signal bulb, you might as well replace both sides while you have it apart.
    Turn signal/DRL bulbs can be replaced without removing the grille, although you might need to remove the wiper reservoir screws for more room.
    You might look into the 2018+ OEM LED headlight upgrade with an @iHacker harness if that would interest you.
    I did it and replaced the parking and turn signal with LED bulbs, which usually last much longer than halogen bulbs.
    2018+ LED HEADLIGHTS PLUG N PLAY HARNESS FOR 2014-2021 MODELS [V 2.0] | Toyota Tundra Forum
    Not only do the OEM LED headlights provide better light, they also look much nicer than the halogen housings.
    a57f7a7a-30f5-4035-bba7-a8a67c8891cf_47ff888cbc6b455bd181ed8f24e6d4f27fdca0cc.jpge6f2a292-d666-4eb3-b557-a0607b2ea952_8aac55445e0ecc572f691f7edcd5a7b3ddb629dc.jpg
    4416b47f-7ec3-44ba-9d41-5a5391be8be7_14d08690e09b26c615df31bf111c0c8ceee8cb47.jpg6cfc0422-1088-49ee-af47-a2e197ad23d7_ff4066154f91038158b8ee3784cadcd363ad79e8.jpg
    Good luck..
    iHacker, zer0[OP] and Tunrod like this.
  7. Jun 15, 2025 at 9:13 AM
    vmkeith
    vmkeith New Member
    Vince
    Clark County, Wa
    Absolutely correct. When I replaced my headlight bulbs I tried using the directions in the manual. After several F bombs and some colorful commentary about the authors of the manual, I went to YouTube and ended up removing the grill and panels instead. Yes, it's a bit more time consuming, but also a hell of a lot easier. Bonus, I was able to do some cosmetic cleaning that needed to be done.
    zer0[OP], 1lowlife[QUOTED] and Tunrod like this.
  8. Jun 15, 2025 at 10:16 PM
    zer0
    2014? tundra
    bed slide, topper
    thanks!
