Coolant leak
Discussion in 'General Tundra Discussion' started by Edog, Jun 15, 2025.
  1. Jun 15, 2025 at 8:18 AM
    Edog
    Edog [OP] New Member
    eric
    2003 Tundra SR5
    Thank you for allowing me to join. I have a 2003 Tundra SR5, 4.7L, which has coolant leak spots on various locations, (hoses, manifold, top of radiator, battery....). I have replaced the coolant in the reservoir two weeks ago and the level of the coolant in the reservoir is down again with more spotting on top of engine.
    I have considered replacing the radiator cap but it appears to be good with normal spring/ tension and the reservoir cap also appears to be good.
    Any suggestions? Should I pressure test the system? And prior threads talked about thermostat housing. And for the record, I am not a good mechanic but want to try to fix or understand prior to bringing to the repair shop.
    Thank you in advance
  2. Jun 15, 2025 at 11:34 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Sounds like a cracked radiator. My SC had a corner cracked and would spray the top of the engine including the battery. Cheapest task is checking that cap and make sure it's still good.
  3. Jun 15, 2025 at 6:05 PM
    Edog
    eric
    2003 Tundra SR5
    Thank you for that information and advice. I did get a cap and will pressure test it to see if it is a small hairline crack. I believe it may just be that because of the accumulation of coolant residue on the front side of the radiator, between the frame and start of coil.
