Brake Grinding Noise in Rear, it’s not the Brakes!
Discussion in '2nd Gen Tundras (2007-2013)' started by Tunienew43, Jun 14, 2025.
  1. Jun 14, 2025 at 9:03 PM
    Tunienew43
    Tunienew43 [OP] New Member
    2007 4.7 Liter
    Posting here as I am stumped, and hoping to crowd source a solution. I’ve been needing new rotors for a while, got all the parts ordered and waited for convenient time. earlier this week, I noticed a squeaking or grinding noise after braking coming from the rear Driver side tire. Figured it was time. Did a total pad and rotor replacement today. Everything went smooth, except the noise is still there. Did a real good inspection while the rotor was off to see if anything looked off and it didn’t. I’ve done a real thorough inspection to make sure nothing’s bent or scraping while the wheel turns. It seems to be coming from the brake. I’m wondering if the emergency brake shoe is rubbing? Any thoughts?
  2. Jun 14, 2025 at 9:08 PM
    That brake shield has seen better days.
  3. Jun 14, 2025 at 9:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    This. Aside from the obvious mangling around the OD, these are known to rust jack near the caliper mounting lugs until they rub the rotor. I can where it’s been rubbing in your photo.
    Tundra234[QUOTED] likes this.
  4. Jun 14, 2025 at 9:46 PM
    Tunienew43
    2007 4.7 Liter
    Yes, I can see what you’re saying now. Do you think the easiest solution would be to carefully grind down the spot on the brake shield near the mounting lugs?
    It still is a little strange to me that it seems to start making noise after braking, and after a while, go away until braking again.
  5. Jun 14, 2025 at 9:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    No, here. At least that’s sure how it looks to me. And where mine rubbed.
    I was able to “massage” the dust shield back away from the rotor with a punch and hammer IIRC.
  6. Jun 14, 2025 at 10:22 PM
    Tunienew43
    2007 4.7 Liter
    Thank you. I will give it another look over. I hope this solves it.
    landphil[QUOTED] likes this.
