Do you agree that having to press the ac button every time is stupid
Discussion in '3rd Gen Tundras (2022+)' started by 389 24/7, Jun 5, 2025.
  1. Jun 8, 2025 at 6:40 AM
    #61
    389 24/7
    389 24/7 [OP] 125k on the gen3
    Oregona
    2022 TRD OR
    Nada
    Thanks for this....someone who knows wuz up!!!
  2. Jun 8, 2025 at 10:08 AM
    #62
    pursuit2550
    pursuit2550 New Member
    Nothing like changing a water pump, alt, or starter in around 30-45 mins. I have the best of both worlds right now, if you want to call it that. A 98 Z71 and a 25 MDX.
  3. Jun 8, 2025 at 10:59 AM
    #63
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I keep mine in auto. Works great never had to hit the ac button.
  4. Jun 8, 2025 at 12:32 PM
    #64
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    I did not change any factory settings but my a/c stays ON after I turn the engine of and then ON.
    That is right the indicator is not lit, but the cold air comes out and it cools as it should. Same with fresh air. The indicator is not lit but when I drive I feel the fresh air blow in my face without turning the fan ON
    ansel123, BdBoyitz and Raven67 like this.
  5. Jun 9, 2025 at 4:33 PM
    #65
    BossDawg24
    BossDawg24 New Member
    Mark
    Cumming, GA
    2023 Tundra Capstone Blueprint, 2017 1794 Barcelona Red
    None
    The way to disable the autostop is to buy a hybrid.
  6. Jun 10, 2025 at 9:39 PM
    #66
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    Technically it does auto stop. It just doesn't rely on the little starter and bendix to start back up. When the engine kicks on at a stop light it has the electric motor that spins up to idle speed that is not noticeable at all.
  7. Jun 10, 2025 at 9:50 PM
    #67
    Retroboy1989
    Northern Utah
  8. Jun 10, 2025 at 9:56 PM
    #68
    Retroboy1989
    Northern Utah
    Seriously though, I've like the auto HVAC. It dials back the fan speed as the cab cools down.
    The manual controls in the third gen aren't great, so auto it is.
    Op, just do auto and override the vent controls?
    In other news, the Amazon auto stop module is amazing. So nice not to have the annoying park-stop-start-stop. I never clamped the brakes hard enough to activate stop in normal driving. Toyota did a nice job skirting the EPA with that feature.
  9. Jun 11, 2025 at 4:54 AM
    #69
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
  10. Jun 11, 2025 at 5:38 AM
    #70
    MPclk2006
    MPclk2006 New Member
    2025 Black Tundra
    Thanks to this thread. I changed the setting and now AC stays on, thanks!!
  11. Jun 11, 2025 at 12:05 PM
    #71
    G10dra
    G10dra Not a New Member
    The whole point of using the "Auto" setting on your car's HVAC system is to let the system take care of keeping the cabin comfortable without you having to constantly adjust anything. When you first get into a hot car—like one that’s been sitting in the sun—the system automatically cranks the A/C and fan speed to cool things down as quickly as possible. Then, as the interior temperature drops closer to what you’ve set, it gradually slows the fan and balances everything out.
    It’s designed to adjust in real time based on how warm or cool it is inside the car. So whether you're sitting in traffic, driving at highway speeds, or the weather outside changes, the system adapts to keep your preferred temperature steady.
    Here’s why "Auto" is such a great feature:
    • You don’t have to fiddle with the controls while driving—it does all the work for you.
    • It keeps the temperature consistent, so you're not too hot one minute and too cold the next.
    • It’s more efficient, because it doesn’t overwork the system once the cabin is at the right temp.
    • It’s quieter most of the time, since the fan slows down when full power isn’t needed.
    • And in some cars, it even helps with things like humidity or air quality.
    So really, there’s not much of a downside to using Auto mode. It’s convenient, smart, and designed to make the driving experience more comfortable without the hassle of manual adjustments.
  12. Jun 12, 2025 at 2:08 PM
    #72
    4x Taco Owner
    4x Taco Owner New Member
    North Idaho
    2025 limited offroad
    Thats what I do. Set it and forget it.
    Raven67 and Matt2015Tundra like this.
  13. Jun 13, 2025 at 3:09 PM
    #73
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I know it’s a diff thread but it was the same “Idiot” that wired the rear window button upside down. :-0
    ElJefe77 likes this.
  14. Jun 13, 2025 at 6:47 PM
    #74
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    This^^^^^ it still gets me every time.
  15. Jun 14, 2025 at 6:39 PM
    #75
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Not at all. I was taught early on to turn the ac off before turning off the vehicle. Turn ac on after the vehicle is running. This takes a load off the engine when starting. Been doing this since I was 18.
    aredub, Paul499 and PNW Tundra Mike like this.
