  1. Jun 14, 2025 at 2:17 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    So you fabricated that yourself? If so, very impressive! My compliments! :)
    Voss[QUOTED] likes this.
  2. Jun 14, 2025 at 3:16 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    OK, break was over so I went back out and put two new OEM tailgate cables (stays) on her.
    I reused one of the original tailgate bolts as the new one didn't seem to want to take to the threads.
    So today: new tailgate handle and new tailgate cables. :)
    KNABORES, BroHon, Hutcheson and 2 others like this.
  3. Jun 15, 2025 at 11:38 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Nothing exciting, just my semi-annual wash and wax job. I looked at the engine too, but although it's never been cleaned it looked acceptable for 24 years without a bath.
  4. Jun 15, 2025 at 12:37 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Changed the oil and finally drilled one of the front broken skid plate bolts out, though I took some threads with it. I can get a bolt threaded in there now, but it starts stripping when I go too tight. I got impatient with the drill...but it's progress.
    Anyone with Total Chaos leaf spring hangers have advice on reaching the zerk? I got a 90-degree angle attachment for my grease gun, but it won't get in there. It looks to me like I'll need to jack up the back of the truck and let the axle droop to get the shackle to swing a bit and make it easier to reach the zerk? Can anyone confirm?
    If I had a garage I'd have just jacked it up to see for myself, but using my floor jack requires picking it up, going up a flight a stairs and dragging it across a gravel driveway so I'm trying to save myself the work until I know it will work...
    Voss likes this.
  5. Jun 15, 2025 at 12:45 PM
    My front/center one does this also. I haven't decided how I'll go about resolving the issue yet. I know it's the hole itself, not the bolt.
    MT-Tundra[QUOTED] likes this.
  6. Jun 15, 2025 at 1:28 PM
    You need to get an actual 90 zerk otherwise it’s damn near impossible to grease it even at full droop
    Voss and MT-Tundra[QUOTED] like this.
  7. Jun 15, 2025 at 1:39 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Might be a nice Father’s Day task while the kid has a nap.
    I’ve got quite the nice RA cart adding up, wouldn’t mind getting an HD leaf set made up as mine sit pretty flat with nothing in the bed. Hoping these Timbren bump stops help for now.
  8. Jun 15, 2025 at 2:00 PM
    chunk
    chunk New Member
    I'd be interested in a follow up review on the bump stops. I've been thinking of installing a set of those too.
    Voss and Hutcheson[QUOTED] like this.
  9. Jun 15, 2025 at 2:22 PM
    Hutcheson
    Caleb
    2004 DC Limited
    Absolutely, I want to get a build thread going pretty soon so keep an eye out
    chunk[QUOTED] likes this.
  10. Jun 15, 2025 at 2:35 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Helicol?
  11. Jun 15, 2025 at 3:07 PM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    2" spacer level 285/70/17 Falken Wildpeaks
    Does anyone know if the driver and passenger seatbelt on an AC cab are the same/interchangable?
  12. Jun 15, 2025 at 3:40 PM
    The belt or the latch? If you mean the latch, the metal portion bolting it down is physically bent at a slightly different angle between the two.
  13. Jun 15, 2025 at 3:41 PM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    I mean the belt portion only
  14. Jun 15, 2025 at 3:42 PM
    That I’m unsure.
  15. Jun 15, 2025 at 5:17 PM
    MT-Tundra
    Montana
    Yeah mine too. At least with the one I just drilled out, I was shocked there were any threads at all left in the nut. I was pretty aggressive/sloppy and used a large bit. But I must have also over-tightened the other side at some point. Still, two half-stripped front skid plate bolts are better than one, which is what I had been working with till now.
    Ahhh, a 90 zerk instead of a 90 degree grease gun fitting. Yeah I can easily picture how that will actually work. Thanks.
    Might be the path. Maybe a tap & die set. I need one anyway, just haven't prioritized the expense yet.
    shifty`[QUOTED] likes this.
  16. Jun 15, 2025 at 5:32 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Fitment wasn’t great but for a universal cover they were nicer than most of the stuff I’ve seen.
    start one. Good way to convince yourself to spend more money. Haha
    Hutcheson[QUOTED] and KNABORES like this.
  17. Jun 15, 2025 at 6:01 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Don’t think they’re interchangeable but if your seatbelt isn’t working properly, there are places that’ll repair them. Mailed to them and back took like a week when I sent my passenger side in. Think it was like $50
  18. Jun 15, 2025 at 6:28 PM
    What was the company that folks on here used to have theirs re-wound? Safety Restore?
    Voss likes this.
  19. Jun 15, 2025 at 6:41 PM
    Voss
    Valod
    2003 AC TRD 4x4
    That’s who I used. Great service!
