Rear axle issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by SoTexTundra, Jun 13, 2025.
  1. Jun 13, 2025 at 12:56 PM
    SoTexTundra
    SoTexTundra [OP] New Member
    19 DC TRD OFF-ROAD
    So I’ve been hearing what sounds like something is loose in the rear end of the truck when i go over any kind of bumps or unevenness while driving. I have looked everywhere but also when I grab the top of the rear tires on either side and push and pull I feel like something in the axle has play. Haven’t gone to the shop yet just wondering if anyone has ever dealt with something similar.
  2. Jun 13, 2025 at 1:55 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    The best lubricant is....
    ... oh wrong thread.
    hagrid, Kung, TRDFerguson and 2 others like this.
  3. Jun 13, 2025 at 1:57 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is ......?
    hagrid and Saltyhero13[QUOTED] like this.
  4. Jun 13, 2025 at 1:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Clickbait thread title. Reported.
  5. Jun 15, 2025 at 6:23 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I fixed the title lol
    TRDFerguson[QUOTED] likes this.
  6. Jun 15, 2025 at 6:39 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Have you drained fluid to see if there's anything weird looking?
  7. Jun 15, 2025 at 7:44 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I changed to fluid back in April and it was clean still and the magnet didn’t have any chunks. It sounds like something loose when I slowly go over any kind of uneven surfaces and more frequent after driving for awhile.
    MadMaxCanon[QUOTED] likes this.
  8. Jun 15, 2025 at 7:44 AM
    MadMaxCanon
    Definitely have a shop take a look.
  9. Jun 15, 2025 at 7:46 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Yea that’s the plan cause I have looked all over and messed with everything I thought it could be and no luck still. Just wondering if anyone had something similar happen that I may have missed while looking.
  10. Jun 15, 2025 at 9:01 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Pretty new truck to have loose issues it the rear? Try retorquing the rear wheel lug nuts?
  11. Jun 15, 2025 at 9:18 AM
    TheBeast
    TheBeast The Beach
    coming from differential or wheel or suspension ?
  12. Jun 16, 2025 at 2:39 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Yea I’ve taken both wheels off even cleaned the surfaces and re-torqued the wheels
  13. Jun 16, 2025 at 2:40 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    So if you grab the top of the tire on either the driver or passenger side and push and pull it to move the whole truck, it sounds like something in the axle is loose behind the rotor I think. I’m almost certain it’s not the wheels at this point
  14. Jun 16, 2025 at 2:51 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    The wheel bearings or the 4 big nuts behind the backing plate that hold the axle in, are they somehow loose?
  15. Jun 16, 2025 at 3:13 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Not sure about the bearings but ill check the nuts and see if they are. The shop i deal with will have to look at the bearings and go from there.
  16. Jun 16, 2025 at 3:39 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Does anyone have any idea what the propeller shaft bolt re-torque even is? Nothing on here is really showing what the torque numbers are or what it even is lol
  17. Jun 16, 2025 at 3:40 AM
    Kung
    KG, VA
    227196388_119018787127081_38125215445133_ed5ef7667bb7bb28f330d9cdd2210b6f8b5c6a0d.png
  18. Jun 16, 2025 at 4:46 AM
    Retired...finally
    I take a 17mm box end and smack it with a 18" piece of 2x4. Never had ine move yet. As far as retorque? I'm not going to loosen them to find out they were tight to begin with.
  19. Jun 16, 2025 at 5:04 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Is it the four bolts that connect the driveshaft to the differential and transmission on either side?
  20. Jun 16, 2025 at 5:14 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Just to clarify I meant the four nuts that hold the axles in on each side. Behind the brake backing plate. Making sure the drive shaft bolts at the trans and diff are tight is a good idea too though.
  21. Jun 16, 2025 at 5:23 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Yea i get that. Would you happen to know the torque value for the axle bolts?
  22. Jun 16, 2025 at 5:29 AM
    Retired...finally
    I hope so cause those are the ones I'm beating on.
  23. Jun 16, 2025 at 5:33 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Yea that's what I'm thinking they are cause in the maintenance manual it just says bolt not bolts.
  24. Jun 16, 2025 at 9:57 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    I don't know the value off hand. but for the drive shaft and the axle bolts, if you can't tighten them any more by hand with a wrench, they're probably tight enough
  25. Jun 17, 2025 at 3:40 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Truck goes to the shop on Thursday so hopefully I can update on here what they find.
    j_supra likes this.
  26. Jun 17, 2025 at 3:55 AM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    Found some torque specs I had saved on my phone.
  27. Jun 24, 2025 at 5:26 AM
    Saltyhero13
    Original thread title was "Rear end play"....
  28. Jun 24, 2025 at 6:54 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    :rofl::eek:
  29. Jun 24, 2025 at 2:00 PM
    stiffler
    stiffler New Member
    2020 Platinum SSM Tundra
    What did the shop say?
  30. Jul 2, 2025 at 8:53 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    They couldn't find anything wrong with the truck unfortunately and i don't hear anything anymore so if something breaks then ill know whats wrong.
