Looking to add a winch on the hitch receiver
Discussion in 'Towing & Hauling' started by mrburt3, Mar 15, 2025.
  1. Mar 15, 2025 at 10:46 AM
    mrburt3
    mrburt3 [OP] New Member
    LD
    2015 1794 4WD, max cab
    I have a 2015 Model 1794 Tundra 4WD MX CAB
    I want to add a winch on the hitch receiver. I have found the adapter but I want to know if I can pick up power from the round trailer brake controller connector and the max amps for which pin.. I can opt for a winch that uses the right amount of power for the capacity but don't know which pin nor the current limitation. This will be used for dragging things up on my small trailer as I'm too old to move by hand, for example, my 400lb chipper and logs for firewood
    Thanks in advance for any advice.
    LD
    Bought2Pull likes this.
  2. Mar 28, 2025 at 11:39 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I can't answer your question directly but seeing as no one else has tried....
    My dad and I did exactly what you are talking about....well....his idea and metal and my welding! LOL
    As to the wiring issue, maybe this bump will get more exposure and the right someone will chime in.
    Could you not run by a small shop near you and just ask the shop manager/owner if he can suggest a mechanic to do it in their spare time?
    I've hired painters that way and the results were great.
    As to dad's hitch-mounted winch, he just hooks it up directly to a spare car battery he puts over in the bed or the truck or bed of the trailer. Works fine.
    Corndog123 likes this.
  3. Jun 13, 2025 at 5:04 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    That's a good idea.
  4. Jun 13, 2025 at 5:09 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    @mrburt3 seems to have only made one post. so he may be long gone. But to answer the question, No - you cannot get power
    for any winch thru the trailer light connector nor brake controller wiring.
    Best thing I think is as above suggested and just clip to spare battery secured to trailer. A small ATV/UTV winch is ideal for
    lawn and garden equipment and I'd suggest a portable clamp to the trailer or permanent mounting plate to trailer. IMO
    ColoradoTJ and Corndog123 like this.
  5. Jun 13, 2025 at 5:12 AM
    Corndog123
    Sam
    Tennessee
    Yep, I really like the spare battery idea. I don't have a spare winch lying around but the Harbor Frieght Badlands winch is a very good one from what I understand and would come in handy in some of the places I get into with my Tundra.
  6. Jun 13, 2025 at 5:35 AM
    centex
    centex New Member
    Winches draw a lot of amps and current when they get under load. I daisy chain jumper cables together to the truck battery when using mine on the hitch.
  7. Jun 13, 2025 at 5:52 AM
    Corndog123
    Sam
    Tennessee
    Oh no kidding? Interesting!!
  8. Jun 13, 2025 at 6:37 AM
    centex
    centex New Member
    Here’s how mine is setup. I’ve done this a couple of times. Those cables are 4ga wire.
  9. Jun 13, 2025 at 8:31 AM
    A little sketch. But sometimes sketch gets the job done. Would be an easy project to take 2 sets of cables and make your own dedicated cable setup for the winch. Plug on one end for the winch, clamps on the far end for the battery. Hack off the clamps in the middle and butt splice and HD heat shrink the connections
    centex[QUOTED] and Corndog123 like this.
  10. Jun 13, 2025 at 8:42 AM
    Hard wire to battery. Never seen it done any other way.
    The kits vary from 49-112.00
    https://a.co/d/6Van0yt
  11. Jun 13, 2025 at 11:35 AM
    Corndog123
    Sam
    Tennessee
    Very cool! Thank you for showing us how you do it!!
  12. Jul 1, 2025 at 8:20 AM
    PNWOffroader
    PNWOffroader New Member
    2016 Inferno Orange SR5
    TRD Offroad, Tow Package, Crewmax
    I only use my hitch during emergencies and occasional tree moving so I opted to get a long cable and clip it to my battery. This is the video I got my inspiration from.
  13. Jul 12, 2025 at 2:55 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I'd like to put a winch onto the front of both of my trailers.....if my mower breaks down I'd be able to pull it up onto the trailer.
    I've had one mower go down on a job but it's easy to get into neutral and since the client was with me that day, we were able to push it onto the trailer pretty easily.*
    *Turned out to be wiring had got into contact with the block and melted, shorting across the block and blowing a fuse. I traced the wires, taped the damage up with electrical tape, and pulled the wires away from the engine block with a zip tie to the mower frame. Mower is doing great! :) At some point though I need to replace those burnt wires.
    KNABORES likes this.
  14. Jul 12, 2025 at 3:39 PM
    centex
    centex New Member
    That’s my plan when I redeck my trailer this year. Weld in some 1/4” plate and then bolt a receiver hitch to the deck that I can slide my 12k into. That way I can transfer it from the trailer to the truck easily.
