Transmission temperatures
Discussion in '2nd Gen Tundras (2007-2013)' started by k0diak8o8, Jun 11, 2025.
  1. Jun 11, 2025 at 1:58 PM
    k0diak8o8
    k0diak8o8 [OP] New Member
    Big Island Hawai'i
    2010 Limited DC 4x4 Salsa Red Pearl
    RC 6" w/Lifted Struts 20" Fuel Lethals 35" Maxxis Razr MTs ARE Z-line topper
    Did some searching on here before posting this and found some info but looking for more feedback. 2010 tundra 5.7L 6inch lift 35"MT. I've been using the Torque app. What are typical tranny temps both pan and torque converter not towing just cruising around? What peak temps do you guys see typically? Appreciate any help.
  2. Jun 11, 2025 at 2:36 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    2018 Tundra Platinum on 35s
    Typical Trans Pan Temps: 185-195°F
    Typical Converter Temps: 185-215°F
    Your truck should have a slightly different auxiliary cooler setup than mine. It sits way out front of your condenser, so it could be caked in bugs, leaves, etc. If so clean it off and recheck. You can also very easily pin your trans cooler thermostat and it should being temps down quite a bit.
  3. Jun 11, 2025 at 5:49 PM
    EmergencyMaximum
    Mine shows middle on the gauge, so I think it's medium temps. I have towing package that come with transmission cooler, the real one.
    Gauge never went above medium ever.
    KNABORES and k0diak8o8[OP] like this.
  4. Jun 11, 2025 at 6:41 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    180-200 in general. If you're regeared the higher rpm tends to heat it up more too. If the converter unlocks the converter temp spikes very fast, but in lockup it drops to pan temp instantly. If you pin the thermostat on the trans cooler it'll drop temps considerably too. But if it's not holding above 200 I wouldn't be very worried. If the trans temp gets over 220 I start to worry, if it's nearing 240 I would pull over or slow down to let it cool.
    Mdl and k0diak8o8[OP] like this.
  5. Jun 12, 2025 at 8:57 AM
    Iilac
    Iilac New Member
    I am seeing 257ish F on my 2007 with the towing package. I use the Alpine FLX-F511 paired the Maestro connected to OBD port. Not sure what sensor that the reading is from but it indicates on the radio as the automatic transmission temperature. Not sure if I should be concern with it as the OEM guage doesn't go over medium as well.
  6. Jun 12, 2025 at 9:44 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    The OEM dash gauge is almost useless. The OBD II readings are way more accurate and therefore useful. 257°F is really hot, but the overheating warning doesn't come on (on the dash) until somewhere around 300°F. I'd be concerned and would check that your thermostat is working properly, your cooler itself isn't overly dirty, and I'd do a few drain fills with fresh ATF WS for good measure
    k0diak8o8[OP] and snivilous like this.
  7. Jun 12, 2025 at 10:51 AM
    snivilous
    SW UT
    I would change your transmission fluid, probably never been changed unless you've already done it. I would also pin open the transmission thermostat, takes all of a minute to do with a piece of wire. If the torque converter is unlocked the trans temp spikes, and you're most likely seeing converter temps. The torque converter doesn't lock up in stock form all that often, and even with a trans cooler it can get extremely hot. Pinning the thermostat will help it a bit, and then do fluid changes every 30k miles to help keep the trans healthy.
    k0diak8o8[OP] likes this.
  8. Jun 12, 2025 at 10:59 AM
    Iilac
    Iilac New Member
    I have changed it once and I planned to do another one. Is the thermostat underneath the truck or in the engine bay?
  9. Jun 12, 2025 at 11:06 AM
    snivilous
    SW UT
    It's under the truck, on the passenger side behind the front tire. There will be a big hockey puck sized thing coming off the transmission, above that is the thermostat. On the back side there is a little plunger that you push in with a screw driver, and then slide a wire/pin through both holes and it will keep the plunger depressed.
    The thermostat opens when the transmission gets hot, but it doesn't seem to FULLY open so you actually end up with quite a bit more cooling in my experience with it pinned open. In the winter time, myself and many others keep it pinned open, the transmission still gets up to temp within a couple miles.
  10. Jun 12, 2025 at 12:39 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    I'm getting ready to do my first drain n fill on my '18. I'm only at 40k miles but Im sure the fluid is 7yrs old.
    Am I understanding correctly that it's safe to keep the pin in the thermostat 100% of the time? By doing so, that will keep my trans temps cooler? What are pros or cons? I'm in So Cal. I never tow but occasionally I haul heavy loads.
  11. Jun 12, 2025 at 12:41 PM
    snivilous
    SW UT
    Yes sir, correct, leave it pinned all the time. Lots of people even in colder climates leave it pinned in the winter, that is the only time maybe you'd want to unpin it---but I leave mine pinned and it gets into the teens where I live and it's fine.
    Not really any cons for the best I can tell, quite a few of us on the forum have had it pinned for years and thousands of miles now. If you're in Socal I would pin it and never think twice. It made a 20+deg temperature difference on my truck.
    TacomaTRD4x402[QUOTED] and Mdl like this.
  12. Jun 12, 2025 at 12:49 PM
    TacomaTRD4x402
    Southern California
    Awesome! Thank you. :cheers:
  13. Jun 12, 2025 at 12:58 PM
    JRS
    JRS New Member
    2012 DCLB
    I'll give this a shot in a few weeks. Both daily driving and towing the RV (loaded ~8K), with 37s on stock gearing, 90degF outside, S4, results in the pan at 195degF with the TC hitting 220 when I've got to give it the beans. Curious how much that steady state will drop.
  14. Jun 12, 2025 at 1:42 PM
    EmergencyMaximum
    Question is, why are you seeing such high temperatures in the first place, even woth trans cooler included?! Many gang here even without trans coolers of later year tundras don't post these numbers:notsure:
    ☆question for lilac with 250f temps☆
  15. Jun 12, 2025 at 1:48 PM
    k0diak8o8
    Big Island Hawai'i
    Appreciate the all the replies and info. I've never towed with this truck and highest pan temp i've seen is 199F. Highest torque converter temp i've seen is 225F. This was gunning it hard up a long hill. After cresting the pan dropped to back to 194-196F then even lower down 188-190 going back downhill. Sometimes around town i'll see the torque converter spike to 215-218F always goes down when locking up. I used Grok to make a chart for my recent trips. How do these numbers look? Thanks gang!
  16. Jun 12, 2025 at 1:50 PM
    snivilous
    SW UT
    I wouldn't sweat it hitting 220 range, it's inevitable if the converter unlocks for any period of time in my experience.
    Tunrod and k0diak8o8[QUOTED][OP] like this.
  17. Jun 12, 2025 at 2:57 PM
    Iilac
    Iilac New Member
    I have no clue... Truck drives and shifts fine. I only became aware of the temperature after installing the radio with the capability to read the sensor and show the temperature. The case of having too much information and not knowing what to do with it.
    Tunrod likes this.
  18. Jun 12, 2025 at 4:25 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I see mid 180s to mid-190s on my 2008 (stock size tires, 5.7 with towing package) with regular driving. The picture shows the OBD Fusion app running.
    TheBeast, Tunrod and k0diak8o8[OP] like this.
  19. Jun 13, 2025 at 8:14 AM
    Iilac
    Iilac New Member
    Can anyone post their transmission temperature when the truck is turned on in the morning? My starting temperature is @ 150 F which I don't believe is accurate.
  20. Jun 13, 2025 at 8:25 AM
    JohnWhicker
    JohnWhicker New Member
    That can't be. Mine starts around 89. Is a 2021 and no transmission cooler.
  21. Jun 13, 2025 at 8:28 AM
    Iilac
    Iilac New Member
    That's what I am thinking. It's not calibrated correctly. We have had some cool mornings lately in California and there's no way that the sensor should be reading 150F after just starting the car.
  22. Jun 13, 2025 at 8:34 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    What are using to monitor?
    Here's mine after start up and running for about 3 minutes, OAT 90 degrees.
  23. Jun 13, 2025 at 8:38 AM
    Iilac
    Iilac New Member
