Radio, A/C, windows and more don't work
Discussion in '2nd Gen Tundras (2007-2013)' started by phtoyoguy, Aug 11, 2021.
  1. Aug 11, 2021 at 12:25 PM
    phtoyoguy
    phtoyoguy [OP] New Member
    R
    2011 Tundra crewmax
    3" lift 35s
    things that stopped working after a recent trip. no speedometer, A/C stopped working,radio doesn't work, power windows don't work, voltmeter not accurate, ABS light on, tire pressure light on. check ingine light on. it does start and can drive it at slow speed after overriding shifter
  2. Aug 11, 2021 at 12:26 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Can you read any codes through the OBD port?
  3. Aug 11, 2021 at 12:28 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Check battery condition, verify alternator operation, visually check fuses and major grounds.
  4. Aug 11, 2021 at 12:31 PM
    phtoyoguy
    R
    2011 Tundra crewmax
    3" lift 35s
    cod indicated a transmission solenoid failure
  5. Aug 11, 2021 at 2:02 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    What do you mean by voltmeter not accurate? It is a mechanical gauge that reads the voltage directly off a wire coming into the back of the cluster.
    First thing I would do is put a volt meter on your battery. Check for 12V+ when off and 14V+ when running. If you have both of those start looking at major fuses and ground wires.
    Loose or dirty ground connections will make electronics systems do crazy things.
  6. Oct 8, 2022 at 3:16 PM
    4theluvuvtoyota
    4theluvuvtoyota New Member
    Jack
    Ever find the fix? Same stuff happening to mine. Started with an alarm system that went berserk and then multiple electrical issues. Going in to an alarm doctor next week to see if they can get it back to factory wiring but I sure would like to use my truck today!
    02 tundra no windows no AC (unacceptable in florida), no instrument cluster no radio. At first it wouldn’t even accelerate forward, but I found 2 A blown for EFI and ETCS that fixed that. Now it drives but all that other stuff wrong. Can’t find anymore bad fuses in or out. Maybe a bad ground somewhere? Is there specific ways/places to look for that?
  7. Oct 9, 2022 at 9:50 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Visual inspection of grounds is the primary method followed by using a DMM (digital multimeter) to verify near 0 ohm resistance.
  8. Apr 21, 2023 at 10:05 AM
    Sgomez1
    Sgomez1 New Member
    2013 toyota tundra
  9. Apr 21, 2023 at 10:05 AM
    Sgomez1
    Sgomez1 New Member
    2013 toyota tundra
    We just had the same problem that you had. What did you find out was wrong with your vehicle?
  10. Jul 7, 2024 at 4:41 PM
    Djchuri
    Djchuri New Member
    I had all the exact same symptoms and it turned out to be the 15amp cigarette lighter fuse underneath the dash was blown. Wow I had three mechanics put their scanners on my truck and couldn’t figure nothing out. I guess I got lucky.
    Retired...finally likes this.
  11. Jul 8, 2024 at 7:33 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    It’s really interesting how folks sign up to join when they have an issue, expect help, and then never follow-up with what was wrong.
    grave and OldGuy03 like this.
  12. Jul 20, 2024 at 1:17 PM
    4theluvuvtoyota
    Jack
    Same issues. Tundra 02 4.7. Battery kept dying so Just replaced the alternator. Still no cluster, windows and bunch of other stuff. Checked all small fuses under dash and under hood. Don’t know how the check big fuses. About to start hunting grounds but I’d like to find this and offer it for everyone.
    I’m not experienced w electrical systems but I have a multimeter. Is there a layman approach to testing like certain contact points or readings I should look out for? Advice appreciated
  13. Jun 13, 2025 at 7:33 AM
    Kingajmal520
    Kingajmal520 New Member
    Ajmal
    2006 Toyota sequoia sr5
    The fusible link in the engine compartment was blown where it’s circled and caused a bunch of components to malfunction including the ones you stated. Speedometer and temp gauge were also out. I would check that fusible link to make sure it’s not blown then move forward.
