2014 Tundra 1794 Heated Steering Wheel
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rosco68, Feb 7, 2025.
  1. Feb 7, 2025 at 8:19 PM
    Rosco68
    Rosco68 [OP] New Member
    Will
    2014 Tundra 1794
    Greetings from BC Canada. I bought a 2014 Tundra 1794 this past summer, I looked for this truck for years and I’m going to be buried with this one. We have cold winters here and I was surprised to find my Tundra does not have a heated steering wheel. I understood a heated steering wheel was standard in the 1794 package. However, my truck doesn’t have one. Is this unusual?
    HulkSmurf14 likes this.
  2. Feb 8, 2025 at 5:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mdnitedrftr, TreeCat and Rdrcr like this.
  3. Feb 8, 2025 at 6:27 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I have the same wheel, living in Maine I use it all the time during the winter. Works great! IMG_0423.jpg
    reywcms, TreeCat, Rdrcr and 1 other person like this.
  4. Feb 8, 2025 at 8:48 AM
    Rdrcr
    Rdrcr New Member
    2019 Toyota Tundra TRD Sport
    I’m certainly enjoying my Heated Steering wheel in our winter climate! The steering wheel itself is a nice upgrade and the heated functionality is fantastic. I definitely recommend it.
  5. Feb 11, 2025 at 7:05 AM
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I need to get one of these steering wheels. Is the install difficult?
  6. Feb 11, 2025 at 8:53 AM
    Satch01
    Satch01 New Member
    2021 Platinum Wind Chill Pearl
    There is a video, actually I thought it was from a previous thread on here. I watched and am not sure I want to tackle it...I think it was the wiring that scared me off for now.
  7. Feb 11, 2025 at 11:16 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    The biggest challenge will be not unspooling the clock spring. I didn't use a wheel puller when I swapped steering wheels, and the clock spring came out with the wheel, and unspooled itself at my feet.
    Essentially you just use a T25 or T30 to remove a screw from each side of the steering column (after disconnecting the negative terminal of the battery and waiting like 10-15 minutes), then disconnecting all the plugs, set the airbag down on something, remove the steering wheel nut, then either tug on the wheel or use a wheel puller, remove the clock spring (zip tie it so it doesn't change position), install new stuff.
    It shouldn't take you more than an hour, that includes waiting to touch the airbag after disconnecting the negative terminal and taking your time.
    bulldog93, TreeCat and HulkSmurf14 like this.
  8. Feb 11, 2025 at 5:38 PM
    Rdrcr
    Rdrcr New Member
    Damaging the OEM clockspring during the installation of the new “heated” steering wheel shouldn’t be too much of a concern since it comes with a new replacement.
  9. Feb 12, 2025 at 9:56 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Where is the steering wheel made? My issue would be an air bag that didn’t deploy in case of an accident from a cheap ass, China made clock spring. I’ve actually found new clock springs for these trucks for less than 10 bucks. Considering the air bag signal runs thru it, don’t think I’d trust it if it’s a cheapy.
    300BLK likes this.
  10. Feb 12, 2025 at 2:08 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Does the wheel feel overly thick at all? How long does it take for the wheel to heat up?
    Rdrcr[QUOTED] likes this.
  11. Feb 12, 2025 at 2:45 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    The wheel feels proper in size. And as for the heat it gets warm pretty fast, within 3 minutes it’s fully warm.
    Rdrcr likes this.
  12. Feb 12, 2025 at 7:25 PM
    Rdrcr
    Rdrcr New Member
    You reuse the OEM airbag. But, yeah, I’m pretty sure the clockspring and steering wheel are made in China. If that’s a serious concern, I wouldn’t buy it. Personally, I’m not worried about it.
  13. Feb 12, 2025 at 7:26 PM
    Rdrcr
    Rdrcr New Member
    It’s definitely thicker than the OEM wheel but, not overly thick. It’s a pretty nice upgrade itself without the heated functionality.
  14. Feb 12, 2025 at 8:38 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Does the leather feel like good quality?
  15. Feb 13, 2025 at 6:48 AM
    Rdrcr
    Rdrcr New Member
    Yes. I was pleasantly surprised by the leather and overall quality of the new steering wheel.
    In fact, the leather on this steering wheel is much nicer than our new(ish) Bronco. I swear Ford is using vinyl…
    bulldog93 and HulkSmurf14 like this.
  16. Feb 13, 2025 at 7:14 AM
    HulkSmurf14
    2014 Tundra Limited
    It's a true and proper upgrade...you wouldn't be disappointed!
    Rdrcr likes this.
  17. Feb 13, 2025 at 7:28 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    The wheel is awesome I didn't do the heat but the leather feel and thickness feels just right. The pics make it look much thicker than the feel.
    Rdrcr, bulldog93 and HulkSmurf14 like this.
  18. Feb 13, 2025 at 10:44 AM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Yeah the pictures make it look thick, maybe I’m just used to the stock wheel. Now to decide if heating is worth double the price.
  19. Feb 13, 2025 at 1:22 PM
    HulkSmurf14
    2014 Tundra Limited
    if it snows in your area of life, do it...it's something I bet you wouldn't be mad about once your wallet heals...
    Rdrcr, bulldog93 and reywcms like this.
  20. Feb 13, 2025 at 2:06 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Would rather have heated seats but seems like a lot more difficult of an install.
    HulkSmurf14[QUOTED] likes this.
  21. Feb 13, 2025 at 2:07 PM
    HulkSmurf14
    2014 Tundra Limited
    Not at all, actually!
  22. Feb 13, 2025 at 2:36 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Funny thing is I use the wife's wheel heater all the time in her rig. But opted not to do it in mine lol makes no sense I know.
    RobertD and HulkSmurf14 like this.
  23. Feb 13, 2025 at 2:55 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Have you done that install before? I have a 2017 pro with leather seats but wanted to add the heating element. Haven’t found a super straight forward install or product.
  24. Feb 13, 2025 at 3:06 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wheel install isn't difficult at all. Few threads on that. Wiring the heating function is also straight forward they provide the harness etc
  25. Feb 13, 2025 at 3:12 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Sorry I was referring to heated seats install.. the wheel looks pretty straight forward.
    reywcms[QUOTED] likes this.
  26. Feb 13, 2025 at 3:30 PM
    HulkSmurf14
    2014 Tundra Limited
  27. Jun 12, 2025 at 9:18 PM
    bickz
    bickz New Member
    2017 Tundra Trd Pro
    Anyone know if the clock spring thing supplied is required or can you use the factory Toyota one?
  28. Jun 13, 2025 at 7:27 AM
    Rdrcr
    Rdrcr New Member
    A new clockspring is supplied with the Heated steering wheel and must be used for the heated function to work.
