2020 Payload Capacity?
Discussion in 'Towing & Hauling' started by dsundy, Jun 6, 2025.
  1. Jun 6, 2025 at 1:37 PM
    dsundy
    dsundy [OP] New Member
    2019 MGM Platinum
    Hey all - searched the forums but didn't see anything specific to the 2.5 Gen Pro.
    What is your payload capacity on the door jamb?
    I've heard it's reduced by a few hundred lbs and imagine it's because of the softer off-road suspension, but curious what the actual numbers are...
  2. Jun 6, 2025 at 1:42 PM
    AZBoatHauler
    So.Arizona
    It's going to be really close to 1400.
    blenton likes this.
  3. Jun 6, 2025 at 1:43 PM
    blenton
    blenton New Member
    A TRD Pro has the same GVW as other tundra trims, it just weighs a little more out of the gate. Payload just equals GVM minus curb weight, so the payload decrease is due to the vehicle being a little heavier, not due to a reduction in spring force or chassis limitations.
    AZBoatHauler likes this.
  4. Jun 6, 2025 at 1:55 PM
    Retired...finally
    Don't know if this gives you any idea but my plain jane 21 SR5 4x4 CM with the 38 gal tank package, port installed bedliner, floomats, locking tailgate and owners manuals yellow tags at 1253. I do have the steelies, stealing about 40 pounds of payload.
  5. Jun 6, 2025 at 1:58 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    The payload is absolute shit on Toyota trucks it will be under 1200 pounds most likely being a 4x4 and crewmax I’m right at 1300 pounds mine is a 4x4 double cab
  6. Jun 6, 2025 at 1:58 PM
    dsundy
    2019 MGM Platinum
    I'd be thrilled it if it was this high, but I've heard closer to 1,100-1,200 for the Pro trims...
  7. Jun 6, 2025 at 1:58 PM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    my 2021 limited crewmax 4x4 was 1040 it will say on your door jam
  8. Jun 6, 2025 at 2:47 PM
    AZBoatHauler
    So.Arizona
    Realistically - if it's 1,100, 1,200, or 1,400, will that make any practical difference?
    what are you planning to use it for?
  9. Jun 6, 2025 at 2:54 PM
    dsundy
    2019 MGM Platinum
    I carry about 500lbs of constant weight between gear for work, recovery gear, and eventual camper shell. My current truck's payload is 1,220 and it's a straight-up bouncy castle with all that. I'll use the truck for hunting, camping and daily driving in NorCal/Northern Nevada. Lots of mining roads, etc.
    So more payload gives me a better offset for that gear's weight. Regardless of what it ends up being I'll likely add the HD RAS, which according to other threads should give the right balance of maintaining off-road chops but offsetting some of that weight.
  10. Jun 6, 2025 at 2:58 PM
    AZBoatHauler
    So.Arizona
    I roll around at 7,000 lbs with just me and my daily gear. I wouldn't let a sticker deter you.
    caboj, Tripleconpanna and SharkDog like this.
  11. Jun 6, 2025 at 3:14 PM
    dsundy
    2019 MGM Platinum
    That last pic is freakin' sweet. Should be an advertistment!
  12. Jun 6, 2025 at 3:15 PM
    AZBoatHauler
    So.Arizona
    @BiggHertz getting the sick shots!
    Tripleconpanna and BiggHertz like this.
  13. Jun 10, 2025 at 10:57 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Get Deaver springs, buy once cry once.
    I had RAS HD before, and it's night and day difference after switching to Deaver springs, it rides better, tows better, carries load better, everything is better except the butt sits bit high.
    Tripleconpanna likes this.
  14. Jun 12, 2025 at 8:27 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    I put 2600 pounds of dirt in the back of mine, confirmed by the scales at the dump. it was squatted but still got up to speed just fine
  15. Jun 26, 2025 at 7:53 AM
    dsundy
    2019 MGM Platinum
    That's good to know. There's actually someone selling a set of Deaver leafs locally, brand new. May go and check them out.
